my rear diff going away #541917
12/01/09 02:18 PM
12/01/09 02:18 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
had a hard time getting both wheels to do a burn out on sunday. this also happened when i let someone borrow my car for the bracket finals and he went out 1st round.
i really dont have any money for a locker so i was thinking mini spool because its something i think i could do myself.
i dont know what unit i have in my rear either. i cant tell one from another
what should i do?
i did manage to run a bunch of 6.30s capped up, when i opened the cutouts it went to blowing off the tires
Re: my rear diff going away [Re: sixpackgut] #541918
12/01/09 03:15 PM
12/01/09 03:15 PM
organ
maximum entropy Offline
organ
put a spool in it and be done! i agonized over which type of posi, and finally went with a spool. i am VERY happy. it's obvious in parking lots and so on, but for worry free "motoring", nuttin' beats a full spool.
Re: my rear diff going away [Re: maximum entropy] #541919
12/01/09 03:18 PM
12/01/09 03:18 PM
Renton Washington
Triple Threat Offline
Renton Washington
Yep, time for a spool. You already have aftermarket axles I assume, put one in and be done with it.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: my rear diff going away [Re: Triple Threat] #541920
12/01/09 03:39 PM
12/01/09 03:39 PM
Charleston
Charleston
i was thinking the same thing but the people i know agonize over setting up a dana. then there is the different carriers that i have no idea what to buy. thats why im thinking just putting a mini spool in it. but i dont know if its durable enough
for example, me and elvis both have 4.10s in our dana's. he wanted a set of 3.55s to run a radial class event so i said i have them and i will send them to you. they didnt fit his carrier, why, i have no clue. the 3.55s came out of my car. its just not something i have experience with
Re: my rear diff going away [Re: sixpackgut] #541921
12/01/09 03:41 PM
12/01/09 03:41 PM
organ
organ
time to call dr diff. i wouldn't even consider a mini spool- scary.
Re: my rear diff going away [Re: maximum entropy] #541922
12/01/09 03:53 PM
12/01/09 03:53 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
use a full spool. if your gear is a richmond 4.10 it takes a different carrier than the dana spicer 4.10.
Re: my rear diff going away [Re: mopar dave] #541923
12/01/09 04:02 PM
12/01/09 04:02 PM
under a rock
flathood Offline
flathood  Offline
under a rock
Yun the full spool
Re: my rear diff going away [Re: sixpackgut] #541924
12/01/09 04:19 PM
12/01/09 04:19 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Hey Ray
I have a friend that has a few used spools,he might sell for a good price. I know one or two of them has stock 30 spines also...
Pm me if your interested.. Im thinking $50-$75 would get you one of these.
Re: my rear diff going away [Re: flathood] #541925
12/01/09 04:22 PM
12/01/09 04:22 PM
Az
Crizila Offline
Crizila  Offline
Az
Another one of those decisions that seperates a street car from a race car.
Fastest 300
Re: my rear diff going away [Re: Bob_Coomer] #541926
12/01/09 04:59 PM
12/01/09 04:59 PM
Charleston
Charleston
Hey Ray
mine is 35 spline. i thought all Danas are 35. i will pull the cover and try to figure out what i have and let you know
Re: my rear diff going away [Re: sixpackgut] #541927
12/01/09 05:04 PM
12/01/09 05:04 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Hey Ray
They are...I was thinking you still had a 8 3/4...thats what these spools are..sorry...I tried
Re: my rear diff going away [Re: sixpackgut] #541928
12/01/09 05:07 PM
12/01/09 05:07 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i think there are 2 different ring gears (thick) . Cant remember if there are 2 diff spools . We ran into that issue with my dana 60 .
Re: my rear diff going away [Re: sixpackgut] #541929
12/01/09 05:09 PM
12/01/09 05:09 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
The factory '68 B-body Dana in my wife's '70 Barracuda has 23 spline axles if I remember correctly.
Re: my rear diff going away [Re: sixpackgut] #541930
12/01/09 05:19 PM
12/01/09 05:19 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Go ahead and stick a spool in there. It's not like it's a "real" street car, right? /
Re: my rear diff going away [Re: BradH] #541931
12/01/09 05:21 PM
12/01/09 05:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
sorry to hear that Ray you think it could be setting the pinion angle like a 4 wheel drive could have caused it?
Re: my rear diff going away [Re: BradH] #541932
12/01/09 06:27 PM
12/01/09 06:27 PM
Charleston
Charleston
mine can do whatever yours can do only faster
Re: my rear diff going away [Re: Quicktree] #541933
12/01/09 06:29 PM
12/01/09 06:29 PM
Charleston
Charleston
go play with your carburator
Re: my rear diff going away [Re: sixpackgut] #541934
12/01/09 06:56 PM
12/01/09 06:56 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Imjust picking on you. you did it to me
Re: my rear diff going away [Re: sixpackgut] #541935
12/01/09 08:03 PM
12/01/09 08:03 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Stock '66-'69 passenger car Dana 60: 23 spline axles
Stock '70-'72 passenger car Dana 60: 35 spline axles
Re: my rear diff going away [Re: sixpackgut] #541936
12/01/09 08:34 PM
12/01/09 08:34 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
If you want to go cheap....if your suregrip is the bolt together type (powerlock)...then you could just throw new clutches in it to freshen it up.
