Opinions RB Stroker Durability #541733
12/01/09 07:01 AM
12/01/09 07:01 AM
New Jersey
Randy514 Offline OP
Randy514  Offline OP
New Jersey
I woulld like to get some opinions on on my build.
74 RB-block .055 Callies Dragonslayer crankshaft, Callies H-beam rods, Diamond pistons (flat-top), Pro-Comp heads milled to achieve aprox 13.5-1 compression. Should end up 512 c.i. Camshaft will be roller specs to be determined by the builder/cam manufacturer. It will be a custom grind matched to my combo. Lifters will probably be Crower. Rockers will be determined by builder.
The motors going in a 73 Cuda 3800 lbs 727 Pro-Torque converter or ATI matched to the combo, 410 Dana Caltacs 10.5/29.5 slicks
I know the builder has painstakingly taken the time to build this motor with the best parts considering the budget I'm on (and I'm not second guessing his judgement).
My question is this, considering the output of this engine, what kind of durablility can I expect from this combo. I know the block is the weak link. The engine will never see nitrous, and will probably see 30-40 runs per season.
Thoughts/opinions Thanks Randy
Re: Opinions RB Stroker Durability [Re: Randy514] #541734
12/01/09 07:45 AM
12/01/09 07:45 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
If I was the builder and wanted the best durability out of the factory block that I could get I would do a half fill of hardblock, main studs, and aluminum main caps. Those are the best things to do to a RB block without getting a race block.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Opinions RB Stroker Durability [Re: Randy514] #541735
12/01/09 12:23 PM
12/01/09 12:23 PM
AndyF Offline
AndyF  Offline
Lightweight rotating assembly and a perfect balance job will help, but if you're making good power you'll tear the bottom end out of a stock block after awhile. A partial fill will help, aluminum main caps might help, aluminum rods would probably help on a drag motor, etc.
I've been on this board for about 10 years now and over that period of time I think most everyone who is racing with a stock block has eventually had an engine failure.
Re: Opinions RB Stroker Durability [Re: AndyF] #541736
12/01/09 12:57 PM
12/01/09 12:57 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Andy makes great points and we have seen many broken stock blocks.We are the fortunate ones at BGR since we have been building big and small block as well as Hemi strokers for more years than we can count on our hands and feet and have never had block failure.Rod or main damage or thin cylinders yes,catastrophic block failures,No.I hope I didn't just jinks ourselves.
Re: Opinions RB Stroker Durability [Re: B G Racing] #541737
12/01/09 01:01 PM
12/01/09 01:01 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
Mine failed after 4 seasons. Tall fill aluminum main caps, and aluminum rods. By the time you spend all the money on this stuff and the machine work your way better off getting a race block
Re: Opinions RB Stroker Durability [Re: B G Racing] #541738
12/01/09 01:04 PM
12/01/09 01:04 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
What mods do you like to do on your bottom ends to help them live?
Re: Opinions RB Stroker Durability [Re: mac56] #541739
12/01/09 01:17 PM
12/01/09 01:17 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have done all of the mods that Andy recommended and then some.We pay attention to every detail.Depending on the power levels and colaberation with the engine owner as to what is done.We have many stock blocks in the 600/700+ hp with little or no modifications.We have never used a girdle on any of our builds
Re: Opinions RB Stroker Durability [Re: B G Racing] #541740
12/01/09 02:26 PM
12/01/09 02:26 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Thanks Bob
Re: Opinions RB Stroker Durability [Re: mac56] #541741
12/01/09 05:26 PM
12/01/09 05:26 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
When doing a partial fill, does that affect cylinder roundness or the main bore at all?
Re: Opinions RB Stroker Durability [Re: 493_DART] #541742
12/01/09 05:35 PM
12/01/09 05:35 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
If those heads flow pretty good, compared to a good set of edelbrock Victors, like they have been copied. Your going to be in the power level were the stock block just wont be enough as mentioned by others.
But making under 50 passes a season, it might live a long time. Then again, it might be like my buddies engine. Similar build 500 inch stroker, with a killer set of 440-1's. Aluminum main caps, the whole shooting match. I think it lasted 15 passes before it split wide open.
Re: Opinions RB Stroker Durability [Re: Randy514] #541743
12/01/09 07:26 PM
12/01/09 07:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nine years on the same 72 400 truck block spinning past 7000 rpm`s a few times and it`s still kicking w/stock caps, stock forged 413 crank and eagle rods w/about a 2240 gram bob weight and no fill. Maybe I`m not makin enuff power to hurt it......
Re: Opinions RB Stroker Durability [Re: Thumperdart] #541744
12/01/09 09:49 PM
12/01/09 09:49 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
69 RB block, welded stock crank 4.15 stroke, stock main caps with ARP studs, no fill, LY rods, Ross pistons, solid cam with Stage VI heads. Same parts I've used since the mid 90's though it is on it's third freshen. My racing has dwindled in the last couple years, but I guess I'm in Thumps boat..... I'm just not making any power to hurt it.
Re: Opinions RB Stroker Durability [Re: J_BODY] #541745
12/01/09 10:08 PM
12/01/09 10:08 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I've going on 6 years on my Ohio Crank 499" kit, with only one freshen-up. I drive it a couple of thousand miles a year and race a KOS class about once a month. It dynoed at 520 RWHP and has ran a best of 6.89 and 104.1. The bottom end has iron main caps and, of course, ARP bolts. After reading accounts on here, I am very happy with its durability.
Master, again and still
Re: Opinions RB Stroker Durability [Re: J_BODY] #541746
12/01/09 10:09 PM
12/01/09 10:09 PM
Weddington, N.C.
Streetwize Online content
Streetwize  Online Content
Weddington, N.C.
As BG said, there's durability to be found in the DETAILS: Expert Machine work, Highest quality parts, maticulous assembly and attention to the details and skilled tuning go a long way toward building a B/RB stroker that will last.
Detonation under LOAD kills more motors than anything else I know.
I prefer the B motor over the RB for max effort motors and if you tune and build your motor to keep the peak torque in the 4500-4800 and the peak power in the 6200-6500 range it's likely to last a lot longer than one tuned for 5000/7000+.Stock block failures were pretty rare banck in the days because not many people and combos could get enough head on an RB and because of the restricted ports the torque fell off at a pretty rapid pace as the R's went up....now a days 360-380 CFM heads are pretty commonplace and that's enough to make 700+.
IIRC, the first motors I saw having cap walk issues and splitting bores were right about the time the few sets of Zeekers (the forerunner of the Indy-1) started showing up in the ~mid-late 80's.
The warning flag is when you get around 630-650 hp for an rb and a bit higher for the 9.98 deck B motor which generally are (though not 100% always) a bit meatier in the main webs. If you keep the head flow around ~325-340CFM you should be pretty safe...if you heed all the machining/parts/tuning advice already mentioned.
WIZE
In Car:
