Best way to strip paint from an engine? #541167
11/30/09 02:55 PM
11/30/09 02:55 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
I'd like an aerosol solution preferably, but if they just don't work like brush-on or foaming agents, that's fine. I just want to know what works best!
Re: Best way to strip paint from an engine? [Re: sharpie] #541168
11/30/09 03:06 PM
11/30/09 03:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Hot tank works best...but I suspect that's not a option. Good old aircraft remover brushed on and then pressure washed off should do it.
Re: Best way to strip paint from an engine? [Re: Challenger 1] #541169
11/30/09 03:09 PM
11/30/09 03:09 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Cool, I think I'll use aircraft stripper. You're right hot tanking probably isn't an option. Basically, what happened was I painted the motor blue about a year ago now, but I want it orange. I am going to take out the drivetrain to work on the transmission this winter, so I might as well paint it.
Re: Best way to strip paint from an engine? [Re: sharpie] #541170
11/30/09 03:13 PM
11/30/09 03:13 PM
Cincinnati, Ohio
Cincinnati, Ohio
If it were clean I wouldn't hesitate painting over the old paint if it was stuck good.
Re: Best way to strip paint from an engine? [Re: Challenger 1] #541171
11/30/09 03:31 PM
11/30/09 03:31 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Any paint stripper will work, but it might not do your gaskets any favors.
Re: Best way to strip paint from an engine? [Re: Neil] #541172
11/30/09 03:35 PM
11/30/09 03:35 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Do you have a place that dips cars near you ? dip stripper is by far the best method of removing all crud and paint from an engine.
logan426
Re: Best way to strip paint from an engine? [Re: MLR426] #541173
11/30/09 03:42 PM
11/30/09 03:42 PM
scratchnfotraction Offline
I use the ez off oven cleaner and it will strip the paint,oil,grit,grim right off
I then rinse and blow dry them and paint
I get it at the dollor store for a buck a can and use 2-3 cans and do it a least 2x for stripping the paint down
cheap and fast
Re: Best way to strip paint from an engine? [Re: scratchnfotraction] #541174
12/01/09 02:45 PM
12/01/09 02:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you just painted it a year ago, I would just hose it with engine degreaser, let it soak for 15 minutes or so then hit it with the pressure washer. If any paint didn't stick good, you'll know. And good paint from a year ago can just be covered over IMO.
