'63 Dodge 880....C Body? #540597
11/29/09 08:59 PM
11/29/09 08:59 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Just curious...I'm kinda fuzzy on some of the early '60's cars. Is a '63 880 a B or C body? There's been a big old 4 door version in one of the local 'yards for about the last month or so.
Since it was 1/2 price weekend, I grabbed the 8 3/4 shock plates ($4.. ) & oil pan ($8.50... ) from the 361. Wasn't much else to choose from; it's a rusted hulk.
Anyway, I'm assuming it's a C?
Re: '63 Dodge 880....C Body? [Re: vdriver] #540598
11/29/09 09:30 PM
11/29/09 09:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Not my area of expertise, but I'm pretty sure they're C bodies; they're certainly big enough...
Re: '63 Dodge 880....C Body? [Re: topside] #540599
11/29/09 09:36 PM
11/29/09 09:36 PM
Eastern ohio
Alexdodge Offline
Alexdodge  Offline
Eastern ohio
Yes, its a c body. Would you be interested in selling the oil pan? Alex
Re: '63 Dodge 880....C Body? [Re: Alexdodge] #540600
11/29/09 09:42 PM
11/29/09 09:42 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Keeping the pan.
The car looked a LOT like this one, only not as nice:
http://jalopnik.com/5237747/1963-dodge-880
Re: '63 Dodge 880....C Body? [Re: vdriver] #540601
11/29/09 10:21 PM
11/29/09 10:21 PM
Andrewh Offline
Andrewh  Offline
it actually isn't a c, but full size car. c-bodies didn't start till 65.
So even though it is bigger, a few things were more b-body then c-body.
Like some of the front end apparently was compatible.
If the kickdown linkage was there, it is an adjustible setup that lets you run a 4bbl or 2bbl with the same setup.
Re: '63 Dodge 880....C Body? [Re: Andrewh] #540602
11/29/09 10:25 PM
11/29/09 10:25 PM
Iron Station, NC
furygt Offline
furygt  Offline
Iron Station, NC
I have to second what Andrewh posted.
"C Body" cars started in '65 when they started to use bolt on front sub/stub frames to the uni-body.
Bill
Re: '63 Dodge 880....C Body? [Re: furygt] #540603
11/29/09 11:04 PM
11/29/09 11:04 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Bill
Thanks! Learn something new every day.
Re: '63 Dodge 880....C Body? [Re: vdriver] #540604
11/29/09 11:51 PM
11/29/09 11:51 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
63 Dodge 880 was basically a 62 Chrysler with different front fenders and grill.
Re: '63 Dodge 880....C Body? [Re: 474218] #540605
11/30/09 12:27 AM
11/30/09 12:27 AM
My Neighbor had a really nice one that he couldn't get the rear drums off to do a brake job (nutted axles).
Guess what? E-body rears are the exact same perch to perch and drum to drum as these cars. I just happened to have an extra housing in the back yard and it bolted in!
Re: '63 Dodge 880....C Body? [Re: furygt] #540606
11/30/09 01:21 AM
11/30/09 01:21 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Bill
All the full size unibody cars have a removable stub frame back to 1960.
Re: '63 Dodge 880....C Body? [Re: NicksGarage] #540607
11/30/09 10:43 PM
11/30/09 10:43 PM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
"NOT" a C body as Andrew previously mentioned. One of my biggest pet peeves, '65 to '74 its a C, unless its an Imperial, otherwise it is not.
