Z Bar Adjustment? #540169
11/29/09 12:55 PM
11/29/09 12:55 PM
midwest
sg333e Offline OP
super street
sg333e  Offline OP
super street
midwest
Hey guys,
Installing the Z Bar on my 70 Ebody today. When put in according to the manual, it seems like it is biased towards the center of the car. The arm that hangs down that would activate the clutch pivot arm is actually bound up by the bellhousing, allowing maybe 3" of travel total.
Is there something I can do to adjust this? I measured the Z bar and it is 9 1/8" long, if that helps. I guess I'm wondering if I have the correct one?
Thanks,
EW
Hobbies and associated message boards: 1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com 1987 Grand National (422rwhp/566tq)> TurboBuick.com 2008 BMW 335 TT 6MT> E90Post.com 2008 Gary Fisher HiFi Plus 29er > MTBR.com 2008 German Shorthair Pointer > Shorthairs.net
Re: Z Bar Adjustment? [Re: sg333e] #540170
11/29/09 03:23 PM
11/29/09 03:23 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
In 70 there were different tab positions on the Z-bar.. Maybe other years as well..
In my 70 RR I had a similar problem went to the local Mopar guru and he pulled out 3 Z-bars all were the same width but with different tab positions.
You mite check out www.brewersperformance.com
They had pictures of each..
Just my $0.01...
Re: Z Bar Adjustment? [Re: Sinitro] #540171
11/29/09 09:00 PM
11/29/09 09:00 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
From Brewer's website.
Re: Z Bar Adjustment? [Re: Snoopy] #540172
11/30/09 01:46 PM
11/30/09 01:46 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hej ,do you have a big block or small block.and what bellhousing do you use.ive got a -70 big block with 11" bellhousing i could meassure it but no point if youve got small block or 1o,5"bellhousing,i guess.
Re: Z Bar Adjustment? [Re: cuda-sweden] #540173
11/30/09 11:32 PM
11/30/09 11:32 PM
midwest
sg333e Offline OP
super street
sg333e  Offline OP
super street
midwest
I have a big block, 11" BH I believe although I've never really checked. My Z bar looks like the second one up from the bottom shown above.
Thanks again, for any ideas.
Re: Z Bar Adjustment? [Re: sg333e] #540174
12/01/09 12:43 AM
12/01/09 12:43 AM
Snoopy Offline
Snoopy  Offline
Is your bellhousing aluminum or cast iron?
Re: Z Bar Adjustment? [Re: Snoopy] #540175
12/01/09 08:32 PM
12/01/09 08:32 PM
midwest
sg333e Offline OP
super street
sg333e  Offline OP
super street
midwest
Aluminum, definitely.
Re: Z Bar Adjustment? [Re: sg333e] #540176
12/02/09 08:32 AM
12/02/09 08:32 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
did you get the snap ring installed correctly,in the groove of the framerail side bushings.maybe the snap ring thing missed the grooves and is positioned on the inside of the bushings
