426 hemi conversion motor mounts??? #539637
11/28/09 09:42 PM
11/28/09 09:42 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
has anyone tried the motor mounts that bolts a 426(or crate) hemi to a reg big block e body k frame?
i was under the impression that they were a bolt in deal but after reading a artical in new mopar mag thay cut the crap out of the sump area and on the mount tower
i do not want to hack on the k frame in the car now
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: 426 hemi conversion motor mounts??? [Re: toplescuda] #539638
11/28/09 10:48 PM
11/28/09 10:48 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
What different between the E body and b body K member/mount area. I used the Schumacher mounts with a 70 B body K member and E body oil pan with zero modes
Re: 426 hemi conversion motor mounts??? [Re: torkrules] #539639
11/28/09 11:11 PM
11/28/09 11:11 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
that i am not 100 % sure but the artical was in latest mopar enthusiast they put a hemi into a yellow cuda if that is what was gonna have to do then il pass on the mounts and look for a hemi k frame
i think it said that cut the tower because was gonna use headers(so will we)
1971 charger
Re: 426 hemi conversion motor mounts??? [Re: toplescuda] #539640
11/28/09 11:34 PM
11/28/09 11:34 PM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I put a Hemi crate motor in a 73 Challenger with stock K frame. Car had a 318 in it. I bought a set of motor mounts from schumacher cause I didn't want to have to buy a Hemi E-body K frame. They worked for me without cutting anything. I think I paid $60 or $80 for them.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: 426 hemi conversion motor mounts??? [Re: toplescuda] #539641
11/29/09 09:32 AM
11/29/09 09:32 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Might need a combination of schumacher mounts and TTI headers.
Re: 426 hemi conversion motor mounts??? [Re: torkrules] #539642
11/29/09 09:47 AM
11/29/09 09:47 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i have a 72 B body, same K member as E body, with a 572 hemi and tti headers. i used schumacher mounts without cutting anything. the schumacher mounts raise up the motor about 1/2" and move it to the passenger side about 1/4" over a stock hemi k member.
in other posts people have reported greater success and less problems with the arzura, spelled wrong, mounts. do a search on this subject and you will find several threads. this question shows up every 3 months or so.
perception is 90% of reality
Re: 426 hemi conversion motor mounts??? [Re: Mr T2U] #539643
11/29/09 09:53 AM
11/29/09 09:53 AM
VA
69 Road Runner Offline
VA
I used the Arruzza mounts, and they work fine.
http://www.arruzzahighperformance.com/Parts/Parts.html
69 Road Runner Vert
Re: 426 hemi conversion motor mounts??? [Re: bobbyb] #539644
11/29/09 11:01 AM
11/29/09 11:01 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I guess I should also include that I installed TTI headers on my E-body. They worked fine, no cutting or dinging.
Re: 426 hemi conversion motor mounts??? [Re: bobbyb] #539645
11/30/09 12:29 PM
11/30/09 12:29 PM
Davenport, IA
70shaker Offline
70shaker  Offline
Davenport, IA
I used the Arruzza mounts on my 70 Challenger when I installed the Hemi on my BB K frame. Used TTI headers and everything fit perfect with no grinding cutting etc.
Ex Hemi Racer
70 Challenger Hemi 4 speed clone
Re: 426 hemi conversion motor mounts??? [Re: toplescuda] #539646
03/05/13 11:30 AM
03/05/13 11:30 AM
an8sec70cuda Offline
Which of these conversion mounts (schumacher or aruzza) work better w/ 2 1/8" primary hooker headers? Putting a hemi in a '69 road runner. Already have the Hooker headers, just wondering if one mount works better than the other?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 426 hemi conversion motor mounts??? [Re: toplescuda] #539647
03/05/13 11:46 AM
03/05/13 11:46 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What would you expect from a Cheby magazine?
Re: 426 hemi conversion motor mounts??? [Re: toplescuda] #539648
03/05/13 12:57 PM
03/05/13 12:57 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
As I understand it, most adapter mounts position the engine slightly off of it's original position. The Arruzza mounts come the closest. But it is important to note that the Arruzza mounts have a solid left mount.
Haven't there been displays at some of the bigger shows with a Hemi with TTIs on Schumaker mounts? They seem to fit good and clear everything. The biggest concern would seem to be the engine's position regarding a fresh air hood.
After reading the posts on here and talking to as many people as I could about this, I just bought a converted K at the Indy show last weekend. Hopefully, that will not cause me any alignment problems with my Shaker.
I was considering the Arruzzas, but I just didn't want a solid left mount. And frankly when it's all said and done, there was only a few hundred dollars difference in price.
And as with any Hemi swap, a few multi-hundred dollar cost overruns is just part of the fun.
Master, again and still
Re: 426 hemi conversion motor mounts??? [Re: DaveRS23] #539649
03/05/13 07:54 PM
03/05/13 07:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
Haven't there been displays at some of the bigger shows with a Hemi with TTIs on Schumaker mounts? They seem to fit good and clear everything. The biggest concern would seem to be the engine's position regarding a fresh air hood .
If it says Hemi on it, none of them parts are cheap
Re: 426 hemi conversion motor mounts??? [Re: Cab_Burge] #539650
03/05/13 08:18 PM
03/05/13 08:18 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Cab are you a slow reader??? lol as this thread was started nov of 09.....lol
1971 charger
Re: 426 hemi conversion motor mounts??? [Re: DaveRS23] #539651
03/05/13 11:01 PM
03/05/13 11:01 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
and God help you when you start messing with external oiling...........
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 426 hemi conversion motor mounts??? [Re: astjp2] #539652
03/06/13 01:08 AM
03/06/13 01:08 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
The conversion mounts we used on the hemi in the 74 challenger worked our nice you can actually shift the motor side to side some
1971 charger
Re: 426 hemi conversion motor mounts??? [Re: toplescuda] #539653
03/06/13 01:14 AM
03/06/13 01:14 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
So why do you throw Cab under the bus? a9sec70cuda is the one who dragged it out of the dark dusty past...
Re: 426 hemi conversion motor mounts??? [Re: 1_WILD_RT] #539654
03/06/13 05:15 AM
03/06/13 05:15 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
How right you are lol sorry guys
1971 charger
Re: 426 hemi conversion motor mounts??? [Re: toplescuda] #539655
03/06/13 01:03 PM
03/06/13 01:03 PM
Canada
demon Offline
demon  Offline
Canada
I've used the Schumacher mounts on a couple of B bodies and they worked very well. Both had manual steering and TTI headers and everything clears.
I did have an issue with the 68 style urethane trans mount from Schumacher though. It's made by Imperial services. It was about 3/8-1/2" too tall and lifted the rear of the engIne up causing some header interferance with the torsion bars. Once I discovered that, I simply modified the rear crossmember pocket a bit to lower it and everything was OK
