440 Pushrods with oil hole #538815
11/27/09 11:20 PM
11/27/09 11:20 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
I bought a set of Comp pushrods (ball/cup) to cut to length. They have a oil hole through both ends -- the original ones do not. I am running roller lifters and adjustable rockers
Will this cause problems?
Re: 440 Pushrods with oil hole [Re: jsully] #538816
11/27/09 11:31 PM
11/27/09 11:31 PM
okla.
sam64 Offline
sam64  Offline
okla.
i wouldn't think so they probablby just make them to work with or without push rod oiling.
Re: 440 Pushrods with oil hole [Re: sam64] #538817
11/28/09 10:34 AM
11/28/09 10:34 AM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
Thanks for the reply.
Have not found any pushrods with oil hole in my 'chrysler' past.
I was worried / thinking they would 'drain' needed oil from the rocker (?) when engine is shut down.
Re: 440 Pushrods with oil hole [Re: jsully] #538818
11/28/09 11:03 AM
11/28/09 11:03 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
My buddy had issues w/that. I would have Smith Bros. or Manton make you the right ones in the correct length.
Re: 440 Pushrods with oil hole [Re: jsully] #538819
11/28/09 11:31 PM
11/28/09 11:31 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I have been running pushrods with holes in them for 9 years on the street, no problems at all.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
