Page 3 of 3 1 2 3
Re: Chinese bearings in Brewers 4-speed kit? [Re: Snoopy] #536075
12/01/09 12:07 PM
12/01/09 12:07 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
O.D. - 3.542"
I.D. - 1.376"
Measured with 6" dial caliper.
Look at this:
http://www.sizes.com/built/ball_bearings.htm
If I read this right a 308 should be 0.906" thick, 3.544" OD, 1.575" bore.
Re: Chinese bearings in Brewers 4-speed kit? [Re: 6PakBee] #536076
12/01/09 12:20 PM
12/01/09 12:20 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
According to the chart, you are correct.
According to the actual bearing, the chart is wrong.
This is from Timkens website.
This is for a 308LOE bearing and not a 308SG.
Part No: 308LOE
Description Value
Bore (B) Inches 1.378
Bore (B) MM 35
OD (D) Inches 3.5433
OD (D) MM 90
Width (W) Inches 0.7874
Width (W) MM 20
Re: Chinese bearings in Brewers 4-speed kit? [Re: Snoopy] #536077
12/01/09 12:59 PM
12/01/09 12:59 PM
Snoopy Offline
Snoopy  Offline
The 308SG seems to be a hybrid bearing.
It shares it's I.D. and width with the 307 bearing and it's O.D. with the 308.
Re: Chinese bearings in Brewers 4-speed kit? [Re: Snoopy] #536078
12/01/09 01:39 PM
12/01/09 01:39 PM
Wis., USA
Bob_Fromm Offline
Bob_Fromm  Offline
Wis., USA
Anyone check Jamie Passion to see what he is using?
Re: Chinese bearings in Brewers 4-speed kit? [Re: Bob_Fromm] #536079
12/01/09 02:20 PM
12/01/09 02:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The Chinese bearings , a member bought a couple of the last sets of USA bearings Jamie had , and he was getting a premium for them.
Re: Chinese bearings in Brewers 4-speed kit? [Re: 6PakBee] #536080
12/01/09 02:28 PM
12/01/09 02:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
O.D. - 3.542"
I.D. - 1.376"
Look at this:
this is what I am finding and it's standard numbers for a 308 bearing , but as snoopy states Timken shows it being narrower which I think is the problem which ebooger ... i think ... stated years ago in an article on rebuilding 833's .
also I think some have a different snap ring groove width .
Re: Chinese bearings in Brewers 4-speed kit? [Re: Snoopy] #536081
12/01/09 02:29 PM
12/01/09 02:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Part No: 308LOE
Description Value
Bore (B) MM 35
OD (D) MM 90
Width (W) MM 20
this is the problem , the 308SG is a hybrid and the only other available bearing is this incorrect 308LOE
Re: Chinese bearings in Brewers 4-speed kit? [Re: JohnRR] #536082
12/01/09 04:51 PM
12/01/09 04:51 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What is "a premium"? The 6308NRJ that NAPA had (that I asked them to return this morning) was $66. How much worse could it get?
Re: Chinese bearings in Brewers 4-speed kit? [Re: 6PakBee] #536083
12/01/09 05:48 PM
12/01/09 05:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I found that bearing , in my SKF book , TOO wide as you found out .
I want to say about 80 a pop , but he didn't have alot left , this MIGHT have been 2 summers ago .
Re: Chinese bearings in Brewers 4-speed kit? [Re: JohnRR] #536084
12/01/09 06:54 PM
12/01/09 06:54 PM
Snoopy Offline
Snoopy  Offline
Are there different thicknesses of snap rings that retain the bearing on the input shaft? I just measured the bearing surface on an 18 spline input shaft and it was about .800" from the front gear surface to the snap ring groove. This would place the inner bearing race .026" into the snap ring groove.
Snap ring groove is approximately .118" wide. Which would make the .097" snap ring the closest match for my application. Ideally I would need one that is .104" thick to match the bearings I got from Brewers.
The snap ring installed with the original bearing was .091" thick.
Re: Chinese bearings in Brewers 4-speed kit? [Re: Snoopy] #536085
12/01/09 09:28 PM
12/01/09 09:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
as you can see yes there are different snap rings , you'll have to shim the bearing or grind down a couple rings if you want a .104 snap ring because it looks like it does not exist .
Re: Chinese bearings in Brewers 4-speed kit? [Re: Snoopy] #536086
12/01/09 10:03 PM
12/01/09 10:03 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
We have shims available in .003 .005 and .010 to take up the slack between the bearing/snap ring, as the thicker selective snap rings have fallen victim to NS1 from Ma Mopar. As with the 308 bearings, we have had no luck with having the snap rings made. Best quote was for minimum of 10,000 pieces, and they would NOT mix thicknesses.
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Page 3 of 3 1 2 3
