Page 2 of 4 1 2 3 4
Re: A12 “Mr. Six-Pack” Camshaft... #53587
01/28/08 12:54 PM
01/28/08 12:54 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Bob is good people. He gave me tons of free advice on my PS built 440-6 and yes, I'm running one of his cams too. Should hit the road/track this spring!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: A12 “Mr. Six-Pack” Camshaft... #53588
01/28/08 03:17 PM
01/28/08 03:17 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
And I think he has two cams. One for an automatic and one for a manual. The manual being a mechanical cam.
That's kind of odd, considering the factory only used one particular hydraulic cam regardless of the trans type.
Re: A12 “Mr. Six-Pack” Camshaft... [Re: BradH] #53589
01/28/08 05:18 PM
01/28/08 05:18 PM
midwest
sg333e Offline
super street
sg333e  Offline
super street
midwest
Brad is right, that is not correct.
Hobbies and associated message boards: 1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com 1987 Grand National (422rwhp/566tq)> TurboBuick.com 2008 BMW 335 TT 6MT> E90Post.com 2008 Gary Fisher HiFi Plus 29er > MTBR.com 2008 German Shorthair Pointer > Shorthairs.net
Re: A12 “Mr. Six-Pack” Camshaft... [Re: sg333e] #53590
01/28/08 05:33 PM
01/28/08 05:33 PM
P
Paul_Fancsali Offline
P
Regarding small blocks Bob recommeneded a cam to a friend of mine who had it custom ground?I ended up with it after he sold the car and never installed it All I know is the cam works terrific. I have run a dozen different makes and model cams, this one is by far one the best. Loads of bottom end and goes right to 6K with ease.
Re: A12 “Mr. Six-Pack” Camshaft... [Re: sg333e] #53591
01/28/08 06:16 PM
01/28/08 06:16 PM
Anonymous OP
Anonymous OP
Sorry if that was misinformation. I was just going by what moparts.com user (AZ-Nick) said. In the old moparts.com post I linked above, AZ-Nick said that he bought the 4-Speed cam from bob and that it is a solid cam. I don't exactly have a Bob K. camshaft catalog to reference that, so I took it at face value.
Re: A12 “Mr. Six-Pack” Camshaft... #53592
01/28/08 07:03 PM
01/28/08 07:03 PM
BradH Offline
BradH  Offline
I don't exactly have a Bob K. camshaft catalog to reference...
Neither does Bob, from what I've determined. It's all in his head so the "secret recipe" can't be stolen.
The PSMCDR rules for their Certification process states the cam must be within 1% of factory .050 duration and have the correct factory cam lift per NHRA stock class rules.
Given those rules, any "legal" '68-71 383-440 HP 4/6BBL engine cam should measure...
Intake: 214 @ .050" +/- 1% = 212 / 216
Exhaust: 226 @ .050" +/- 1% = 224 / 228
Max Lift: .455"/.470" (NHRA "blueprinted" lift specs)
LSA: 115
Re: A12 “Mr. Six-Pack” Camshaft... [Re: BradH] #53593
01/28/08 07:21 PM
01/28/08 07:21 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
For factory stock, I think the only thing they will check is that you have acceptable vacuum at correct idle setting. I wonder if they they would do a tear down for class certification unless you are protested??
Re: A12 “Mr. Six-Pack” Camshaft... [Re: RoadRunnerJD] #53594
01/28/08 07:24 PM
01/28/08 07:24 PM
BradH Offline
BradH  Offline
I'd expect that unless you are trying to get the car Certified (it's voluntary), there's something of a "don't ask, don't tell" thing going on re: how "stock" some of those cars' cams are.
However, given the constraints outlined by the rules above, I could still spec out something using modern lobes that could be worth a few ponies over the OEM cam of yours we measured.
Re: A12 “Mr. Six-Pack” Camshaft... [Re: BradH] #53595
01/28/08 07:32 PM
01/28/08 07:32 PM
Warrenton, VA
Warrenton, VA
Mine's definitely coming out! I take it you're not going to try a Mr. Sixpack's?
Re: A12 “Mr. Six-Pack” Camshaft... [Re: RoadRunnerJD] #53596
01/28/08 07:36 PM
01/28/08 07:36 PM
BradH Offline
BradH  Offline
More likely a Mr. Snackpacks!
OK, I'll let this thread get back on topic now...
Re: A12 “Mr. Six-Pack” Camshaft... [Re: BradH] #53597
01/28/08 07:37 PM
01/28/08 07:37 PM
DPelletier Offline
DPelletier  Offline
However, given the constraints outlined by the rules above, I could still spec out something using modern lobes that should be worth a few ponies over the OEM cam of yours we measured.
I know it bugs you that Bob won't come up with the specs to his cam, but as far as the rules go:
http://www.geocities.com/psmcdr/rules.html
Lift and duration as well as adequate vacuum is the only thing tested. Several cars that have been Certified under the rules (voluntarily) run Bob's cam.
Is there something modern out there that has factory lift, duration and gets 16" plus vacuum? I don't know. What I DO know is that Bob has run a 12.09 and Jim has run an 11.97 using that cam and that is good enough for me.
Re: A12 “Mr. Six-Pack” Camshaft... [Re: DPelletier] #53598
01/28/08 07:47 PM
01/28/08 07:47 PM
BradH Offline
BradH  Offline
I know it bugs you that Bob won't come up with the specs to his cam...
No, it really doesn't... because I know exactly what lobes he uses and could call up the same cam grinder right now and have them send me exactly the same thing as a custom grind for myself.
My point is - without going into any of the actual specs - his cam does not pass the Certification process as described above. If there are cars that run his cam that have passed it, then they weren't checking the cams very closely during the inspection.
BTW, don't anybody bother to PM me asking for the specs of Bob's cam. It's obvious it works well as proven by the number of folks who run it with extremely good results. If you want one, buy one from him... he's the one who figured it out.
I'm equally impressed by how smoothly his car idles with it... sounds like Gradma's 318 w/ "hot rod" mufflers!
Re: A12 “Mr. Six-Pack” Camshaft... [Re: DPelletier] #53599
01/28/08 07:58 PM
01/28/08 07:58 PM
BradH Offline
BradH  Offline
From a major cam company's Master Lobe catalog:
272 @ .004" / 216 @ .050" / 127 @ .200" / .454" (1.5)
286 @ .004" / 226 @ .050" / 134 @ .200" / .471" (1.5)
Compared to John D's OEM A12 cam (IIRC):
292 @ .004" / 214 @ .050" / 124 @ .200" / .449" (1.5)
310 @ .004" / 226 @ .050" / 133 @ .200" / .459" (1.5)
Re: A12 “Mr. Six-Pack” Camshaft... #53600
01/28/08 09:49 PM
01/28/08 09:49 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
And that was a Good Face you got it from.....
Yes I did buy a 4sp Six Pack mechanical lifter cam from Bob and here is a Picture of the box that the cam is still in, I never opened it because I changed my plans and no one wanted to buy it when I tried to sell it.
You were right I did say it and here is the pic of the box......
71 GTX 4sp Dana GY9 HD Road King
Re: A12 “Mr. Six-Pack” Camshaft... [Re: AZ-Nick] #53601
01/30/08 02:14 PM
01/30/08 02:14 PM
BradH Offline
BradH  Offline
... Yes I did buy a 4sp Six Pack mechanical lifter cam from Bob and here is a Picture of the box that the cam is still in, I never opened it because I changed my plans and no one wanted to buy it when I tried to sell it.
Yes, I recall that you advertised that particular cam that Bob K. spec'd out for you. Did he say it was effectively a solid equivalent of his hydraulic cam, i.e. intended for the same application? Or was there something different about how he expected it would used?
Re: A12 “Mr. Six-Pack” Camshaft... [Re: BradH] #53602
01/30/08 02:50 PM
01/30/08 02:50 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
I know this is supposed to be about the Mr Six Pack cam, but if I were to call Bob to pretty much try to get a custom grind, do you think hed come up with something? Or does he just stick with the cams hes been selling or...?
Re: A12 “Mr. Six-Pack” Camshaft... #53603
01/30/08 04:06 PM
01/30/08 04:06 PM
Mesa, Arizona
6pak2go Offline
6pak2go  Offline
Mesa, Arizona
I, too, can echo those comments about Bob K. Very personable to speak with on the phone and full of great ideas for a stock appearing and sounding big block.
I have one of his cams for my project and can't wait to see how it performs. I pick the engine up this Friday. :-)
Robert R
Mesa, AZ
70 Challenger R/T 440-6 4-Sp Cruiser
67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
Re: A12 “Mr. Six-Pack” Camshaft... [Re: BradH] #53604
01/31/08 10:19 AM
01/31/08 10:19 AM
Anonymous OP
Anonymous OP
I have a hydraulic cam from Bob that I purchased for my Six Pack Bee. Before I got around to installing it, I purchased another for my 440-6 Superbird, which I did install. I am now getting ready to get back onto the Six Pack Bee and Bob told me that the cam that I had would take more converter, which would make it harder to 60' I purchased another cam, which is what he is running now. I would think that the cam I didn't use would be good for a 4 spd or for street use with a slightly higher stall converter than stock? I have the spec. sheet for that cam. The other cams are classified.
Re: A12 “Mr. Six-Pack” Camshaft... [Re: BradH] #53605
01/31/08 10:19 AM
01/31/08 10:19 AM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
I told him I wanted one of his cams ground for a 4sp solid lifter set up, engine is a 71 Six pack and he said that I would be amazed at the power this was going to have. He also said that he grinds Hemi cams too.....
Re: A12 “Mr. Six-Pack” Camshaft... [Re: AZ-Nick] #53606
01/31/08 10:31 AM
01/31/08 10:31 AM
Anonymous OP
Anonymous OP
I have a 69 RR 4 spd car. I don't have a 383, but I do have a Hemi and some 440's. If I go with a 440, I will use the extra cam myself. If I go with the Hemi, I will try to sell it. I have to finish the Bird,the Bee, and the Dart, before I think about working on the RR.
Page 2 of 4 1 2 3 4
