Drive shaft length for 64 Ply Belvedere #535708
11/24/09 06:59 PM
11/24/09 06:59 PM
Ohio
V
viperakron Offline OP
V
Ohio
Anyone know the dimensions center to center for a 64 ply shaft? I've added a 65 slip yoke tail housing. The car is apart with the trans out so I can't measure and there is one for sale here which is 52" c to c. Too short?
Re: Drive shaft length for 64 Ply Belvedere [Re: viperakron] #535709
11/24/09 07:19 PM
11/24/09 07:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It would help to know, engine, trans and rear end sizes.
Re: Drive shaft length for 64 Ply Belvedere [Re: stumpy] #535710
11/24/09 07:26 PM
11/24/09 07:26 PM
Ohio
V
V
Ohio
I'm putting a hemi in a 64 Belvedere with a 64 TF/65 slip yoke tail and 8 3/4 rear. I searched but don't see anything earlier than 66? Trans will mount to orig cross member.
Re: Drive shaft length for 64 Ply Belvedere [Re: viperakron] #535711
11/24/09 08:55 PM
11/24/09 08:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Surprisingly, the drive shaft length is the same for the slip yoke and the B&T in a given car. Use the center of the pin on the B&T as a reference point for the center of the front u-joint.
Re: Drive shaft length for 64 Ply Belvedere [Re: John_Kunkel] #535712
11/24/09 10:34 PM
11/24/09 10:34 PM
Ohio
V
V
Ohio
Don't have the old shaft or trans in car. Need a dimension. The one for sale is 52"
Re: Drive shaft length for 64 Ply Belvedere [Re: viperakron] #535713
11/24/09 10:47 PM
11/24/09 10:47 PM
okla.
sam64 Offline
sam64  Offline
okla.
i'll measure my 65 in the morning and let you know.
Re: Drive shaft length for 64 Ply Belvedere [Re: sam64] #535714
11/25/09 10:36 AM
11/25/09 10:36 AM
Winlock, Wa
fshd4it Offline
fshd4it  Offline
Winlock, Wa
The D/S out of my '65 bel II measures 53 7/16" center to center of the u-joints. That's from a 318, 727, 8 3/4 (if it makes any difference).
In order to know what you want, you'll probably have to find out what you don't want.
Re: Drive shaft length for 64 Ply Belvedere [Re: fshd4it] #535715
11/25/09 10:44 AM
11/25/09 10:44 AM
Ohio
V
V
Ohio
I was thinking 52" was a little short.
Re: Drive shaft length for 64 Ply Belvedere [Re: viperakron] #535716
11/25/09 11:07 AM
11/25/09 11:07 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do yourself a favor and wait until you have the engine and trans in place and then measure for the correct shaft. A 1/2" either way can cause a multitude of problems.
