S/B Strokers and Rear Gears #535401
11/24/09 12:28 PM
11/24/09 12:28 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Over the winter I'm mini tubbing my Dart and will be buying a S60 to go in it. I already have the new tires and wheels for it, Weld 15 X 10 with 3.5" bs and MT 325/50 ET Street Radials. The 8 3/4 I'm replacing had 4.30 gears in it, I'm considering going with 4.10 in the 60. This is in a street/strip 3300# 69 Dart with a pump gas 408. It's in the 550 hp range.
The 408 only has 10 passes on it including the one that shucked the ring gear teeth. The only clean pass it's made it ran (1/8) 6.61 @ 102.24 with a 1.41 60'.
I had the 340 in it when I went from 3.91 to 4.30 and it only picked up .06 and all that was in 60'. The 340 ran a best of 7.24 with the 4.30.
What do you guys think, 4.10 or 4.30? It doesn't get driven a lot, but I think 4.10s with the 28" rear tire would not be a bad drive.
Thanks, Justin
Re: S/B Strokers and Rear Gears [Re: justinp61] #535402
11/24/09 12:34 PM
11/24/09 12:34 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
When does the engine make peak power (hp and tq?) If it' a race car first, gear so it's about 100rpm higher than HP peak at the stripe. All the stroker equipped cars I had a hand in run 3.23 or 3.54 gearing. The engines like to pull against a load...lol. but if you're wanting to go as quick as you can, have the engine dyno'd when it's done (not a computer simulation...) and then pick a convertor and gear package for it.
Re: S/B Strokers and Rear Gears [Re: moper] #535403
11/24/09 12:40 PM
11/24/09 12:40 PM
W. Kentucky
W. Kentucky
The engine is already in the car. The only dyno I have is the time slip and the seat of my pants .
Re: S/B Strokers and Rear Gears [Re: justinp61] #535404
11/24/09 12:44 PM
11/24/09 12:44 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
4.30
That's what I run, but I go 1/4 mile racing, not 1/8th mile.
With 28" tires and a good converter, I'm trapping 6400rpm at the stripe at 120mph, shifting at 6200.
Re: S/B Strokers and Rear Gears [Re: LAR_414] #535405
11/24/09 12:47 PM
11/24/09 12:47 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Did you weld it in place?
I'd rather know if this is a race car. If you dont want to pull it stick 4.10s in it. That would be my guess.
Re: S/B Strokers and Rear Gears [Re: moper] #535406
11/24/09 02:18 PM
11/24/09 02:18 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I vote for 4.10 gears. That is what I put in my car. Plus, when I add more power in the near future I will not be over geared. And, I have the option of going to a taller tire since I streteched my wheel openings.
SRT DEMON ONE SEAT
Re: S/B Strokers and Rear Gears [Re: moper] #535407
11/24/09 05:39 PM
11/24/09 05:39 PM
W. Kentucky
W. Kentucky
I haul it to the track, the closest one is about 1 1/2 hour drive. I like to drive it to town and to work on occasion.
Re: S/B Strokers and Rear Gears [Re: justinp61] #535408
11/24/09 06:40 PM
11/24/09 06:40 PM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
Justin, what converter do you have and where do you shift? You know my old Dart , with the stroker I was shifting at 64-6500 and trapping at 6600, this with an 8" race verter that flashed to 5200. I ran a 4.10 gear with it and a 30" tire. Best 60 ft was 1.43, best 1/8 mi was 6.59 @ 104, best 1/4 was 10.45 @ 127.
Re: S/B Strokers and Rear Gears [Re: StrokerPost] #535409
11/24/09 06:55 PM
11/24/09 06:55 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
4.10
Re: S/B Strokers and Rear Gears [Re: Hunted Duck] #535410
11/24/09 07:25 PM
11/24/09 07:25 PM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
ive got 4;10 in mine, id like to try 30's just to see if it makes a difference
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: S/B Strokers and Rear Gears [Re: StrokerPost] #535411
11/24/09 08:38 PM
11/24/09 08:38 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Ken glad to see you here
I run 4.30s 11.5 29.5 w hoosiers shift 6600 through traps 6900 even with low gear in trans now
ran those gears with 410ci and the new 418ci
i would do 4.30s if you don't do alot of cruising .
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: S/B Strokers and Rear Gears [Re: 10 o to go] #535412
11/24/09 09:51 PM
11/24/09 09:51 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i run 4.30's in my stroker and it is a street car. hehehehehehehehe
Re: S/B Strokers and Rear Gears [Re: StrokerPost] #535413
11/27/09 11:14 AM
11/27/09 11:14 AM
W. Kentucky
W. Kentucky
Ken, the converter is a 9.5" Edge Racing, it flashes around 4800 the best I can tell. It spun the tires everytime I tried to flash it in high gear. I shift it at 6400 but haven't been able to find out what it likes. Out of the ten passes I've attempted it only hooked up on two. One broke the ring gear and the other it went 6.61 @ 102.24 with a 1.41 60'.
Ken, maybe you can come to Sikeston next year and show me how to drive this thing.
Sorry for not replying sooner guys, my internet has been down for three days. My modem was bad .
Re: S/B Strokers and Rear Gears [Re: justinp61] #535414
11/27/09 08:21 PM
11/27/09 08:21 PM
New York
polyspheric Offline
polyspheric  Offline
New York
It's only 5% difference, and the 4.10 is safer.
Boffin Emeritus
Re: S/B Strokers and Rear Gears [Re: polyspheric] #535415
11/27/09 09:02 PM
11/27/09 09:02 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
I would run a 3.91 or 3.73 gear. I ran 4.30's in the cuda and changed to 3.91 and ran faster. The stroked small blocks have a ton of low end power and dont need the tall gear. The cudas best 60' was a 1.36 with a best of 9.98 @ 134. running the MT street radial. I wanted to try the 3.73 gear but didnt get a chance to. Theres no need to wind up that long arm small block if you dont need to. Trust me, you wont be sorry. For a street strip car stay with the 3.91 and 28" tire....Phill
Re: S/B Strokers and Rear Gears [Re: 9 Sec Phill] #535416
11/27/09 09:18 PM
11/27/09 09:18 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
maybe I should try a different gear I am running 4.88 with a 32x14 M/T
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: S/B Strokers and Rear Gears [Re: 9 Sec Phill] #535417
11/27/09 09:28 PM
11/27/09 09:28 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We went fron 4.30 to 3.91 to 3.55 on our 414, race only mud truck, the more load on the engine the faster we go
Re: S/B Strokers and Rear Gears [Re: justinp61] #535418
11/27/09 09:35 PM
11/27/09 09:35 PM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
Gimme a shout buddy.
Re: S/B Strokers and Rear Gears [Re: StrokerPost] #535419
11/28/09 08:01 AM
11/28/09 08:01 AM
W. Kentucky
W. Kentucky
Count on it, you're welcome to drive it anytime you want .
Re: S/B Strokers and Rear Gears [Re: justinp61] #535420
11/28/09 08:51 AM
11/28/09 08:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
From your previous runs try to gear it so you go
through the traps at 10% above peak HP.... I run a
4.56 with a 31" tire and trap at about 8200 at 150 MPH
set you stall for around peak torque or slightly better
