Re: S/B Strokers and Rear Gears
[Re: justinp61]
#535402
11/24/09 12:34 PM
11/24/09 12:34 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
When does the engine make peak power (hp and tq?) If it' a race car first, gear so it's about 100rpm higher than HP peak at the stripe. All the stroker equipped cars I had a hand in run 3.23 or 3.54 gearing. The engines like to pull against a load...lol. but if you're wanting to go as quick as you can, have the engine dyno'd when it's done (not a computer simulation...) and then pick a convertor and gear package for it.
[Re: LAR_414]
#535405
11/24/09 12:47 PM
11/24/09 12:47 PM
moper
Columbia, CT
Did you weld it in place? I'd rather know if this is a race car. If you dont want to pull it stick 4.10s in it. That would be my guess.
[Re: moper]
#535406
11/24/09 02:18 PM
11/24/09 02:18 PM
Posts: 1,880 USA
Ron Silva
USA
I vote for 4.10 gears. That is what I put in my car. Plus, when I add more power in the near future I will not be over geared. And, I have the option of going to a taller tire since I streteched my wheel openings.
SRT DEMON ONE SEAT
[Re: Hunted Duck]
#535410
11/24/09 07:25 PM
11/24/09 07:25 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
ive got 4;10 in mine, id like to try 30's just to see if it makes a difference
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: StrokerPost]
#535411
11/24/09 08:38 PM
11/24/09 08:38 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
Ken glad to see you here I run 4.30s 11.5 29.5 w hoosiers shift 6600 through traps 6900 even with low gear in trans now ran those gears with 410ci and the new 418ci i would do 4.30s if you don't do alot of cruising . don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: StrokerPost]
#535413
11/27/09 11:14 AM
11/27/09 11:14 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Justin, what converter do you have and where do you shift? You know my old Dart , with the stroker I was shifting at 64-6500 and trapping at 6600, this with an 8" race verter that flashed to 5200. I ran a 4.10 gear with it and a 30" tire. Best 60 ft was 1.43, best 1/8 mi was 6.59 @ 104, best 1/4 was 10.45 @ 127.
Ken, the converter is a 9.5" Edge Racing, it flashes around 4800 the best I can tell. It spun the tires everytime I tried to flash it in high gear. I shift it at 6400 but haven't been able to find out what it likes. Out of the ten passes I've attempted it only hooked up on two. One broke the ring gear and the other it went 6.61 @ 102.24 with a 1.41 60'.
Ken, maybe you can come to Sikeston next year and show me how to drive this thing.
Sorry for not replying sooner guys, my internet has been down for three days. My modem was bad .
[Re: justinp61]
#535414
11/27/09 08:21 PM
11/27/09 08:21 PM
Posts: 4,206 New York
polyspheric
New York
It's only 5% difference, and the 4.10 is safer.
Boffin Emeritus
[Re: 9 Sec Phill]
#535416
11/27/09 09:18 PM
11/27/09 09:18 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
maybe I should try a different gear I am running 4.88 with a 32x14 M/T
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: justinp61]
#535418
11/27/09 09:35 PM
11/27/09 09:35 PM
Posts: 6,847 Missouri
StrokerPost
Missouri
Gimme a shout buddy.
[Re: StrokerPost]
#535419
11/28/09 08:01 AM
11/28/09 08:01 AM
justinp61
W. Kentucky
Count on it, you're welcome to drive it anytime you want .
[Re: justinp61]
#535420
11/28/09 08:51 AM
11/28/09 08:51 AM
Posts: 52,972 Romeo MI
MR_P_BODY
From your previous runs try to gear it so you go through the traps at 10% above peak HP.... I run a 4.56 with a 31" tire and trap at about 8200 at 150 MPH set you stall for around peak torque or slightly better
