Av-gas question #534431
11/23/09 11:22 AM
11/23/09 11:22 AM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
I've read up on the av-gas threads and I think the 100LL seems like a cheap alternative (way cheaper actually) to all out race gas and at 100 octane is enough for my 12:1 motor on the street.
There were some concerns about it being a "dry" fuel (whatever that means) and that adding fuel treatment like Marvel Mystery Oil would be good insurance and not detrimental either.
I can't seem to find the MMO up here in Canada. Any suggested alternatives? Should I even bother?
Re: Av-gas question [Re: Mofopar] #534432
11/23/09 12:53 PM
11/23/09 12:53 PM
100LL here in the states has a very low specific gravity, usually around .690. It also has additives to increase the shelf life to 18 months It was not design or intended to be ran much above 2700 RPM(burn time?) also so that seems to be a problem. I use to use the 115/1345 and when that went away we used the 115/130 octane. I found that all of my stock Mopar M.W. intake and exhaust valves where pitted after using that fuel for two years of drag racing only at or close to twice a month Needless to say I don't use it anymore in a high compression motor, I have mixed it with pump gas on occasion to improve the shelf life for sitting over the winter in cars that I don't drive in the winter I would not add any oil to any gas unless it was for a two stroke motor Alcholol race fuel is a different story
Re: Av-gas question [Re: Mofopar] #534433
11/23/09 01:05 PM
11/23/09 01:05 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I ran it for a few years in a 12.2:1 440 iron headed motor on the street and strip. Ran 11.40s at 117 mph on AvGas and the same on VP 110. I'd run it mixed 50/50 with pump 93 on the street. I never added any oil to the fuel and never had any problems. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Av-gas question [Re: an8sec70cuda] #534434
11/23/09 01:22 PM
11/23/09 01:22 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Just get a top lube...This stuff is available were race fuel (Methonol) is sold..We run it with alky..
Re: Av-gas question [Re: Bob_Coomer] #534435
11/23/09 02:58 PM
11/23/09 02:58 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Everytime I see a post about AV gas I have to bit my lip.But I just got to know.
1 When people are building a street motor/ strip why make the compression more than 10 to 1? Any body heard of Pump Gas Motors and the HP that can be made?
2 Knowing that you have a 12 to 1 motor and you have to run "race gas" and it cost alot of money why try to cheap out by running AV gas? You had the money to build the motor now pay for the right gas.
3 AV stands for??????? Not race car fuel.I have never seen a airplane at a dragstrip try to run a 1/4 mile.
4 Why would you want to add oil to AV gas so you can run it?Put the oil rings in wrong and run all the AV gas you want to.
RANT OVER
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Av-gas question [Re: Mofopar] #534436
11/23/09 03:31 PM
11/23/09 03:31 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I ran it in my Hemi on the street in the 80's when good street fuel went away. I used to mix it half and half with street fuel. I don't see any good reason to use it now though. It's easy enough to buy race fuel and that's what I would do. Buy a drum of race fuel and mix it with street fuel.
Sheldon
Post deleted by Defbob [Re: Mofopar] #534437
11/23/09 03:53 PM
11/23/09 03:53 PM
Re: Av-gas question [Re: slippery440] #534438
11/23/09 04:00 PM
11/23/09 04:00 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
RANT OVER
OK
Race fuel in my area for 110 is only about $1 more per gallon than high test pump fuel.
I also never understood why people would build there Pump gas engine pushing the limits of fuel octane requirements, pulling timing out of a engine to keep it from hammering the pistons and valves. The gains the won by adding the little extra compression is loss by pulling timing out and having a "less" than idea timing curve.
I just decide to build the engine with plenty of compression and make the power it can make, not sacrificing ignition timing one iota.
I just by a drum of the correct fuel and when that runs out I buy another.
As far as airplanes at the drag strip comment. The engine doesnt know what its in or pulling. Those engine are very compact and make awesome power for internal combustion engine.
Not only do they make great power they obviously need to be durable, and take lots and lots of abuse.
What was that auto maker that actually played with the idea of selling his cars with these Plane engines?
The AV fuel is design to keep the fuel from freezing at high altitudes. but this isnt entirely true.
The aircraft engine must make great power on the ground also, to propel/accelerate the engine for take off. So this can and will be at sea level D/A figures.
Im not so sure the octane rating scales is the same between the two.
Fact is people has been running it for years, and years in the auto engines. If it kills a engine it would be conman knowledge by now.
If you decide to run the av fuel just tune it like you would a unknown carb, and stick with it.
I would run some alky top lube too.. A ounce and a half per gallon will do fine.
Re: Av-gas question #534439
11/23/09 04:18 PM
11/23/09 04:18 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I've ran it for over 2 seasons so far without any trouble. Ran 11.35 at 118mph in my wife's 390cid (318 stroker) with Eddy heads. I built the motor to be able to run on the street, 10.8 - 11 to 1 compression but since we race it hard with a lot of timing I figured the extra octane would help prevent detonation.
I run it straight but towards the end of the year I may add some of the top lube that I used in my alcohol just for some extra lubrication.
We are getting it for around $3.50 and 110 at the track is $8 so I like it just fine. I'll pull the heads off this winter and look for pitting or other damage and if I see any I'll stop using it.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Av-gas question [Re: Mofopar] #534440
11/23/09 04:36 PM
11/23/09 04:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Well, one thing you can count on with each new avgas thread is the misinformation it generates.
Re: Av-gas question [Re: WadeMetzinger] #534441
11/23/09 04:43 PM
11/23/09 04:43 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Have been running 100LL at 50/50 to pump fuel this year and have been pleased with the results. I gradually backed it off where it is sitting at about 30% Av gas and still have no problems.
I can say the difference was noticible in my 340 as far as starting, throttle response, and a bit more power.
I believe that there is less screwing around by the petroleum distillers making Av gas. Pump fuel on the other hand, they don't care.......water it down, put filler in it, whatever, just call it gas.
Mo' Farts
Moderated by "tbagger".
Re: Av-gas question #534442
11/23/09 05:13 PM
11/23/09 05:13 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
e-85 ??
cheaper than both gas types and will easily support 12.1 comp
raceone85.com spells it out
and car runs cooler
if it is available by you
WAXER
Re: Av-gas question [Re: Bob_Coomer] #534443
11/23/09 06:06 PM
11/23/09 06:06 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Bob the air plane thing was a joke you know airplane with wings on a dragstrip. I have seen many aircraft motors in tractor pullers association pulls.I still bet they either run alcohol or race fuel.
Re: Av-gas question [Re: Grizzly] #534444
11/23/09 06:12 PM
11/23/09 06:12 PM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
I tried it and it didnt work out very well...I was always having to tune from day to day, just never seemed to like it. I know it has worked well for some. I'd go E85 if it was readily available here
Re: Av-gas question [Re: slippery440] #534445
11/23/09 06:24 PM
11/23/09 06:24 PM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
For many years in the late sixies and the seventies we ran it in a 63 Plymouth max wedge super stock that was going 10:90 and never had any trouble.I now run it mixed 50 50 with pump gas in my 440 six pack with 11:5 to 1 comp. and it loves it with no problems. I would trust it any day over any pump gas since planes full out the air when not running so it can't be half bad.
Thanks Moparts
Re: Av-gas question [Re: 72 RR DUDE] #534446
11/23/09 06:33 PM
11/23/09 06:33 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Pssh, 12:1 is pump gas territory with the proper cam/converter/gear. If anything you can mix it 50/50 with your favorite pump gas and be perfectly safe.
Also keep in mind 100 is NOT the (R+M)/2 rating so you CANNOT just straight compare it to other race gases/pump gas.
I've run 50/50 mix in my 12:1 496 and it ran great.
The Haze ran it exclusively for years pushing 24 psi and 1000+HP... Don't listen to the nay sayers.
Re: Av-gas question [Re: CokeBottleKid] #534447
11/23/09 08:10 PM
11/23/09 08:10 PM
SWEET HOME ALABAMA
I
ITSDUSTA416 Offline
ITSDUSTA416  Offline
I
SWEET HOME ALABAMA
I have been running 100LL av-gas for 20yrs with no problems. I just started mixing MMO to the av-gas for an upper cylinder lube. My motor has 12.5 comp. and runs deadly consistant. I have won run for the money 10 times this year.
71 DUSTER 416 ET 6.33 @ 107 1.33 60FT
Re: Av-gas question [Re: ITSDUSTA416] #534448
11/23/09 11:12 PM
11/23/09 11:12 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Regarding the cost issue, at roughly 3X the price of av, race gas feels like a complete and total fleecing. I too skeptical to buy into the idea that you need race gas and only race gas after 10:1 comp ratio and it seems more agree with this than don't.
I didn't build this thing myself but bought the car as-is to get my feet wet racing.
Although I did have had the car WOT to 6800rpm on the street a couple times and didn't notice any detonation running 94.
Thanks for the input!
Re: Av-gas question [Re: Mofopar] #534449
11/24/09 10:01 AM
11/24/09 10:01 AM
Detroit, MI
Detroit, MI
Mix it 50/50 and you'll be totally fine (and barelly paying above premium)...
Re: Av-gas question [Re: Mofopar] #534450
11/24/09 11:01 AM
11/24/09 11:01 AM
NC
440Jim Offline
440Jim  Offline
NC
That is one reason I switched to E85 (ethanol) in 2008, the cheap hot rod fuel. And my engine is 13.5 CR.
I don't know about AV gas other than the "100" octane rating uses a different test than car gasolines and the specific gravity etc may require a different mixture (jetting). After running pump gas, race gas, alky, and E85, I can't help but believe a properly setup engine can run AV gas too.
