Page 7 of 10 1 2 5 6 7 8 9 10
Re: While waiting for frame guy to show up..... [Re: RUNCHARGER] #534114
03/02/10 12:30 AM
03/02/10 12:30 AM
An Island in the Pacific N.W.
moopa Offline OP
moopa  Offline OP
Mark: Just use lots of masking tape on the fenders, especially on the edges. You're a finicky guy, I know you can do it!
Sheldon
Thanks for the vote of confidence, Sheldon, but I'm no body guy, But I'm not as worried about myself handling them as much as some dudes at the shop that don't give a rat's behind if they chip or scratch something. I'm wonderin if this frame guy from the body shop will ever show,or if I gotta shop somewhere else.Hate chasing people around so I can throw money their way!
Mark
2015 TorRed Challenger Hellcat,A8 2013 Plum Crazy Challenger SRT8,6 Spd 2013 Black Challenger R/T Classic,auto (2)72 Satellites, one on hold,one under resto on the rotisserie.
Re: While waiting for frame guy to show up..... [Re: moopa] #534115
03/02/10 12:32 AM
03/02/10 12:32 AM
moopa Offline OP
moopa  Offline OP
One more little step closer to patching up the hole...
Re: While waiting for frame guy to show up..... [Re: moopa] #534116
03/08/10 12:01 AM
03/08/10 12:01 AM
moopa Offline OP
moopa  Offline OP
Closed up! That lil sucker was tricky...hope it holds!
Re: While waiting for frame guy to show up..... [Re: moopa] #534117
03/08/10 12:03 AM
03/08/10 12:03 AM
moopa Offline OP
moopa  Offline OP
More trouble with this patch, than the rest of the car so far. I'll move onto roughing it up, more epoxy then some fiberglass filler....
Re: While waiting for frame guy to show up..... [Re: moopa] #534118
03/08/10 12:05 AM
03/08/10 12:05 AM
moopa Offline OP
moopa  Offline OP
Still no frame guy ...waited over 2 weeks, I'll look somewhere else...
Mark
Re: While waiting for frame guy to show up..... [Re: RUNCHARGER] #534119
03/08/10 09:00 PM
03/08/10 09:00 PM
north wisconsin
shadow456 Offline
shadow456  Offline
north wisconsin
on the diff. 71/72 inners, what i know is on drivers side top on 72 there is bulge for battery hold down bolt, to top of inner fender as your is. early 71's didn't have bulge as battery bolted down different. but i have seen some 71's from diff. plants that do have bulge ,but no threaded nut for hold down. for what its worth.
Re: While waiting for frame guy to show up..... [Re: shadow456] #534120
03/08/10 09:38 PM
03/08/10 09:38 PM
moopa Offline OP
moopa  Offline OP
Interesting...I'll have to check my repo's...not that it matters on this satellite, if it's not there, but a high-dollar correct resto might be a different story. The repos, at first look, seem to be nice, though.
Mark
Get my mind outta the GUTTERS! [Re: moopa] #534121
03/14/10 10:13 PM
03/14/10 10:13 PM
moopa Offline OP
moopa  Offline OP
Well I couldn't stand looking at the swiss cheeze gutters any longer, decided to play a little and make a couple of patches thanks to my 74 donor Charger parts car. It would have been simpler to order repo gutters from AMD. but this way I get to practice metal work and welding
Here's a pic before the epoxy primer went on to show the extent of the gutter rot.
Re: Get my mind outta the GUTTERS! [Re: moopa] #534122
03/14/10 10:16 PM
03/14/10 10:16 PM
moopa Offline OP
moopa  Offline OP
Cut out the rust....
Re: Get my mind outta the GUTTERS! [Re: moopa] #534123
03/14/10 10:18 PM
03/14/10 10:18 PM
moopa Offline OP
moopa  Offline OP
Now onto the Charger to ask for a donation....
Re: Get my mind outta the GUTTERS! [Re: moopa] #534124
03/14/10 10:19 PM
03/14/10 10:19 PM
moopa Offline OP
moopa  Offline OP
Using the rotted piece as a template...
Re: Get my mind outta the GUTTERS! [Re: moopa] #534125
03/14/10 10:20 PM
03/14/10 10:20 PM
moopa Offline OP
moopa  Offline OP
Surgically removed the good gutter...
Re: Get my mind outta the GUTTERS! [Re: moopa] #534126
03/14/10 10:22 PM
03/14/10 10:22 PM
moopa Offline OP
moopa  Offline OP
Checking to see how much to trim....
Re: Get my mind outta the GUTTERS! [Re: moopa] #534127
03/14/10 10:24 PM
03/14/10 10:24 PM
moopa Offline OP
moopa  Offline OP
Not too bad...
Re: Get my mind outta the GUTTERS! [Re: moopa] #534128
03/14/10 10:25 PM
03/14/10 10:25 PM
moopa Offline OP
moopa  Offline OP
Tacking it into place...
Re: Get my mind outta the GUTTERS! [Re: moopa] #534129
03/14/10 10:27 PM
03/14/10 10:27 PM
moopa Offline OP
moopa  Offline OP
Back to the GRIND!....
Re: Get my mind outta the GUTTERS! [Re: moopa] #534130
03/14/10 10:29 PM
03/14/10 10:29 PM
moopa Offline OP
moopa  Offline OP
Pretty much done this one....Now onto another patch....Darn that trunk floor is starting to bother me,now!!!
Re: Get my mind outta the GUTTERS! [Re: moopa] #534131
04/03/10 11:02 AM
04/03/10 11:02 AM
moopa Offline OP
moopa  Offline OP
Another patch...
Can you tell I'm just wanting a bump?!
Re: Get my mind outta the GUTTERS! [Re: moopa] #534132
04/03/10 11:05 AM
04/03/10 11:05 AM
moopa Offline OP
moopa  Offline OP
2
Re: Get my mind outta the GUTTERS! [Re: moopa] #534133
04/03/10 11:06 AM
04/03/10 11:06 AM
moopa Offline OP
moopa  Offline OP
Ground down!
