Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: Project 1972 Satellite [Re: moopa] #534094
01/17/10 07:31 PM
01/17/10 07:31 PM
An Island in the Pacific N.W.
moopa Offline OP
moopa  Offline OP
Hinge area with the famous bondo weld repair!
2015 TorRed Challenger Hellcat,A8 2013 Plum Crazy Challenger SRT8,6 Spd 2013 Black Challenger R/T Classic,auto (2)72 Satellites, one on hold,one under resto on the rotisserie.
Re: Project 1972 Satellite [Re: moopa] #534095
01/17/10 07:38 PM
01/17/10 07:38 PM
moopa Offline OP
moopa  Offline OP
Battery area looking ruff!
Re: Project 1972 Satellite [Re: moopa] #534096
01/18/10 02:03 AM
01/18/10 02:03 AM
Last time I checked........ around $240 for the inner fender wells for a 69 b-body.
Re: Project 1972 Satellite [Re: moopa] #534097
01/25/10 10:51 PM
01/25/10 10:51 PM
moopa Offline OP
moopa  Offline OP
I'm going to get two new AMD inner fenders. What is the difference between the 71 B Body and the 72 B Body? There two different part numbers, but I can't see the difference. Any way, I got epoxy on the firewall/cowl and on the front frame rails to protect them while I'm waiting for the new inners to arrive.
Frame question [Re: moopa] #534098
01/25/10 10:59 PM
01/25/10 10:59 PM
moopa Offline OP
moopa  Offline OP
Due to the fact that my inner fenders and rad support are bent up fairly bad,the door to fender gaps were really out of whack, and it looks like there's been some work on the front of the frame rails, I'm wondering if I should get this thing on a frame machine now before the new inner fenders are welded on, just in case there's some work that needs doing. Will a frame shop be able to get it nearly perfect( within spec) without re-mounting the outer front fenders, hood and header panel,etc?
Re: Frame question [Re: moopa] #534099
01/25/10 11:45 PM
01/25/10 11:45 PM
Take some good pics and go to a frame shop near you and talk to them.
While waiting for frame guy to show up..... [Re: moopa] #534100
03/01/10 12:44 AM
03/01/10 12:44 AM
moopa Offline OP
moopa  Offline OP
I've been kinda on hold waiting for the frame guy to show up to let me know if the frame needs work. 10 days, now...so I'm back at making some patches and trying to finish off the roof.
Mark
Re: While waiting for frame guy to show up..... [Re: moopa] #534101
03/01/10 12:45 AM
03/01/10 12:45 AM
moopa Offline OP
moopa  Offline OP
forgot the pics!
Re: While waiting for frame guy to show up..... [Re: moopa] #534102
03/01/10 12:47 AM
03/01/10 12:47 AM
moopa Offline OP
moopa  Offline OP
The back piece wasn't too bad to make....
Re: While waiting for frame guy to show up..... [Re: moopa] #534103
03/01/10 12:48 AM
03/01/10 12:48 AM
moopa Offline OP
moopa  Offline OP
Rear view
Re: While waiting for frame guy to show up..... [Re: moopa] #534104
03/01/10 12:49 AM
03/01/10 12:49 AM
moopa Offline OP
moopa  Offline OP
But this piece is very tricky, gonna be a challenge
Re: While waiting for frame guy to show up..... [Re: moopa] #534105
03/01/10 12:50 AM
03/01/10 12:50 AM
moopa Offline OP
moopa  Offline OP
Started of with some paper to get a rough pattern, then cut a piece of sheet metal
Re: While waiting for frame guy to show up..... [Re: moopa] #534106
03/01/10 12:51 AM
03/01/10 12:51 AM
moopa Offline OP
moopa  Offline OP
Used the bead roller to put in the flange...
Re: While waiting for frame guy to show up..... [Re: moopa] #534107
03/01/10 12:52 AM
03/01/10 12:52 AM
moopa Offline OP
moopa  Offline OP
Getting tricky!
Re: While waiting for frame guy to show up..... [Re: moopa] #534108
03/01/10 12:54 AM
03/01/10 12:54 AM
moopa Offline OP
moopa  Offline OP
It's gotta fill the gap under and join up to the gutter some how(( copper colored stuff is weld-thru primer)
Re: While waiting for frame guy to show up..... [Re: moopa] #534109
03/01/10 12:58 AM
03/01/10 12:58 AM
moopa Offline OP
moopa  Offline OP
Once that piece is done, then the outer overlapping piece is next(should be easier)...Wish I knew what I was doing...it'd be alot less frustrating!
Still struggling, done for the night...
Mark
Re: While waiting for frame guy to show up..... [Re: moopa] #534110
03/01/10 01:43 AM
03/01/10 01:43 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I kind of think your frame guy would like the doors and fenders (along with the original inners) on it when he pulls it. I recommend doing that before welding the new inners on. Frame work is cheap really and then you'll know you won't have issues with it.
Sheldon
Re: While waiting for frame guy to show up..... [Re: RUNCHARGER] #534111
03/01/10 01:55 AM
03/01/10 01:55 AM
moopa Offline OP
moopa  Offline OP
Sheldon
That's what I was thinking, too...get the frame work done first, that way it won't mess up the new inners. The only thing I was hoping to avoid is handling the fenders and hood too much, as I'm still trying to save the paint...likely a lost cause, now!! I'm thinking, there's now way to put them on and off a number of times,while tweaking the frame without screwing the paint up.
Mark
Re: While waiting for frame guy to show up..... [Re: moopa] #534112
03/01/10 01:57 AM
03/01/10 01:57 AM
moopa Offline OP
moopa  Offline OP
The doors are still on...and the door to 1/4 panel gap doesn't look too bad...hate to disturb it.
Mark
Re: While waiting for frame guy to show up..... [Re: moopa] #534113
03/01/10 11:03 PM
03/01/10 11:03 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Mark: Just use lots of masking tape on the fenders, especially on the edges. You're a finicky guy, I know you can do it!
Sheldon
