Need E body brake linkage expert! #533455
11/22/09 01:11 PM
11/22/09 01:11 PM
IL
hemiclone Offline OP
mopar addict
mopar addict
IL
I just changed over my non power brake 70 Cuda to power breaks. I have a OEM rebuilt booster from Napa and I purchased the linkage(booster arm to pedal) from Tony's Parts...with everything connected my pedal is down near the floor. It looks to me that the 3" or so rod that bolts to the pedal and also bolts to the linkage is about 1" to short? Is there any way this linkage I received from Tony is for another model car? IT looks correct according to the pictures in my manual.
Thanks!
Re: Need E body brake linkage expert! [Re: hemiclone] #533456
11/22/09 02:15 PM
11/22/09 02:15 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Is the booster piston all the way in or all the way out making up for the difference?
Re: Need E body brake linkage expert! [Re: moparmojo] #533457
11/22/09 03:21 PM
11/22/09 03:21 PM
IL
mopar addict
mopar addict
IL
Yes its all the way out. According to my parts manual the linkage I have only fits 1970 cuda and challenger. There is another part number for the charger, belvidere and coronet(same picture in the manuel) I'm thinking I may have the wrong part?
Re: Need E body brake linkage expert! [Re: hemiclone] #533458
11/22/09 04:22 PM
11/22/09 04:22 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Sounds like you have pre '71 B-body linkage.
Re: Need E body brake linkage expert! [Re: DoctorDiff] #533459
11/22/09 04:56 PM
11/22/09 04:56 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Which part are you talking about?
Re: Need E body brake linkage expert! [Re: Snoopy] #533460
11/22/09 05:04 PM
11/22/09 05:04 PM
Snoopy Offline
Snoopy  Offline
Rod
Re: Need E body brake linkage expert! [Re: Snoopy] #533461
11/22/09 07:06 PM
11/22/09 07:06 PM
IL
mopar addict
mopar addict
IL
Thanks, I'm talking about part #2944289 (the Rod)...I think if this part was about 1" longer it would be correct. From what I see if the arm from the booster was any longer the top part of the LEVER would hit the brake pedal rod so I don't thing there is a problem regarding the booster and arm.
Re: Need E body brake linkage expert! [Re: hemiclone] #533462
11/22/09 07:11 PM
11/22/09 07:11 PM
IL
mopar addict
mopar addict
IL
If I knew what the length of the ROD should be I would know if I had the correct part.
There's really no other part of this set up that would cause the pedal to be 5" from the floor at its full extension.
Re: Need E body brake linkage expert! [Re: hemiclone] #533463
11/23/09 08:29 AM
11/23/09 08:29 AM
IL
mopar addict
mopar addict
IL
Re: Need E body brake linkage expert! [Re: hemiclone] #533464
11/23/09 12:12 PM
11/23/09 12:12 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You need the E-body rod. It is about 1" longer.
Re: Need E body brake linkage expert! [Re: DoctorDiff] #533465
11/23/09 12:28 PM
11/23/09 12:28 PM
IL
mopar addict
mopar addict
IL
What is the ebody rod? Are you talking about the 71-73 ebody linkage that is thinner and has the smaller pins instead of the bolts?
Re: Need E body brake linkage expert! [Re: hemiclone] #533466
11/23/09 12:32 PM
11/23/09 12:32 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I'm talking about the dog bone shaped part in the diagram called "rod".
Re: Need E body brake linkage expert! [Re: DoctorDiff] #533467
11/23/09 12:40 PM
11/23/09 12:40 PM
IL
mopar addict
mopar addict
IL
Thanks I know what part you are talking about but the problem is that from what I can tell I have the correct part(rod) the linkage/rod I have is for a 70 Ebody. Do you know if I need a different part number? The only linkage other than the part I have is the 71-73 ebody linkage..that is thinner and has pins instead of bolts and that rod is a little bit longer.
Re: Need E body brake linkage expert! [Re: DoctorDiff] #533468
11/23/09 06:29 PM
11/23/09 06:29 PM
IL
mopar addict
mopar addict
IL
So I measured the ROD it is 2 1/8"
Could any of you guys with a 1970 Challenger or Cuda help me out ..its asking alot because its a tight space to get to but I need to know the measurement of the Rod in your car I would really appreciate it!! Again this is the part that bolts to the brake pedal and then bolts to the linkage arm. I measured mine from center bolt hole to center bolt hole and it is 2 1/8" the back part of my pedal is 2" from the floor so 1" more on the rod would bring the pedal where it is supposed to be.
