What starter to ask for? #532485
11/21/09 11:47 AM
11/21/09 11:47 AM
KY
juicedcuda Offline OP
KY
My brand new 440source starter has already started making god awful noises when starting so I am going to autozone or Oreilly's to pick up a new one. What car/truck exactly do I tell them to get one that will work with a big block?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: What starter to ask for? [Re: juicedcuda] #532486
11/21/09 11:58 AM
11/21/09 11:58 AM
try 84 dodge dakota,
Re: What starter to ask for? #532487
11/21/09 12:05 PM
11/21/09 12:05 PM
FRANCE / PARIS
NENE Offline
NENE  Offline
FRANCE / PARIS
I agree, it can start my 16:1 572 B1 without pain !
'70 Cuda with a 572 Keith Black / B1 heads with a sheetmetal intake (2 dominators) Lencodrive 3 speed trans. 2350 lbs with me Run 8.04" / 168 mph 1.11" 60 ft Fastest Mopar at the Euro Mopar Nats website : http://vantastic-racing.com/
Re: What starter to ask for? [Re: juicedcuda] #532488
11/21/09 12:07 PM
11/21/09 12:07 PM
sg66mopar Offline
sg66mopar  Offline
So you're sure it's a bad starter and it's not just out of location?
Re: What starter to ask for? [Re: juicedcuda] #532489
11/21/09 12:10 PM
11/21/09 12:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I can't believe you bought one to begin with
Re: What starter to ask for? #532490
11/21/09 12:12 PM
11/21/09 12:12 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
That`ll be a pretty neat trick since Dakota didn`t come out `till 87
Re: What starter to ask for? [Re: Blown71X] #532491
11/21/09 01:25 PM
11/21/09 01:25 PM
KY
KY
So a 87 dodge Dakota starter for a v6?
The car was starting fine. It then starting make some god awful noises. It now just cranks and sounds like it is rubbing the outside of the teeth on the convertor. I got under it and the bolts were a little loose, so I tightened them and felt the outside of the teeth and you can feel where it is rubbing the converter teeth. Oh and it still makes whining noise after retightening bolts. There is no shims, etc on it. Bad starter?
Re: What starter to ask for? [Re: juicedcuda] #532492
11/21/09 01:53 PM
11/21/09 01:53 PM
Pasagetdowndena
Cranky Offline
Cranky  Offline
Pasagetdowndena
Starters from a V6 or a V8 are the same. The one for our 5.2 2000 Durango interchanges with my 95 V6 Dakota.....
Re: What starter to ask for? [Re: Cranky] #532493
11/21/09 01:56 PM
11/21/09 01:56 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I've always picked 1996 ram 4x4, 360, extended cab, power windows, cd player, receiver hitch, with a bed liner.
That always gets me the right mini starter
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: What starter to ask for? [Re: DemonDust] #532494
11/21/09 01:59 PM
11/21/09 01:59 PM
KY
KY
Does it sound like the starter is bad from what I am describing?
Re: What starter to ask for? [Re: juicedcuda] #532495
11/21/09 02:04 PM
11/21/09 02:04 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Does it sound like the starter is not engaging with flywheel? Or the gears inside the starter are junk?
SDG Motorsports
Re: What starter to ask for? [Re: DemonDust] #532496
11/21/09 02:06 PM
11/21/09 02:06 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Thats funny. I happened to own that exact truck many years back and I am glad I did. I went to unload the car and the starter was dead. We crawled under the truck and took the starter out, put in race car, raced all day and swapped them back for the tow home.
Re: What starter to ask for? [Re: DemonDust] #532497
11/21/09 03:11 PM
11/21/09 03:11 PM
KY
KY
it sounds like it isn't engaging with the flywheel and I just found out why, I got under the car and it broke a few of the ring gear teeth off the convertor.
Re: What starter to ask for? #532498
11/21/09 03:23 PM
11/21/09 03:23 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Supposedly the 360 starters are a heavier unit.Thats what I have in my 440 with 12.5 domes.Spins like a /6.My kid has the Source starter in his 413 and 2 friends have them also.No problems and they are all street driven.Rocky
Chrysler Firepower
Re: What starter to ask for? [Re: juicedcuda] #532499
11/21/09 03:37 PM
11/21/09 03:37 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
....actually there are a couple of options..advanced part#17010 fits a '90 ramcharger(5.2) or #17181 which fits a '95 ram 1500(5.2)...iirc the 17010 is the 1 i ended up using(12.5 -1 rb) because the body of the starter is a tad shorter(better header clearance)...the down side is that the 17010 is $20 bucks more ..i could have the 2 part numbers reversed but i'm sure the 2 are different...1 is shorter.just go to the store and have them compare the 2 and make sure...hope this helps.
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: What starter to ask for? [Re: DemonDust] #532500
11/21/09 03:42 PM
11/21/09 03:42 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
is that with or without a/c
Re: What starter to ask for? [Re: ro23car] #532501
11/21/09 04:12 PM
11/21/09 04:12 PM
KY
KY
Alright, I am going to Oreilly's to get a starter, what model should I tell them to get a 360 starter that will work on my big block?
Re: What starter to ask for? [Re: ro23car] #532502
11/21/09 04:14 PM
11/21/09 04:14 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Depends if you have factory mud flaps or not
SDG Motorsports
Re: What starter to ask for? [Re: juicedcuda] #532503
11/21/09 04:17 PM
11/21/09 04:17 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Any late model 96-02 ram with 5.2 or 5.9 will work.
SDG Motorsports
Re: What starter to ask for? [Re: juicedcuda] #532504
11/21/09 04:17 PM
11/21/09 04:17 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
It just depends on whats in stock is what you will get.
The Dakota starter they run will show if they have the starter in stock...maybe have 3 of them, maybe one.
Asking them for a starter for a 95 Dodge Ram 318 will point them to the same starter..
I dont know why but there is many versions of the starter..
Each a diff length also...some as short as 6" and some longer than 7". Maybe they revised it it each year
But measure the one they have, make them pull the others if in stock...If you cant find one thats short, go to another store...You can always come back..
At least this is how i roll..LOL
