Re: Help! Vibration Issue!!!
[Re: tech118]
#532230
07/26/14 02:01 PM
07/26/14 02:01 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A999 is a beefed up A904, bet B&M tech isn't a Mopar guy either. http://www.summitracing.com/parts/bmm-10239/overview/make/chryslerApplication info is incomplete, it fits all pre Magnum 360's with the A904/9998/999 trans, not just 74-80.
[Re: tech118]
#532232
07/26/14 04:52 PM
07/26/14 04:52 PM
RapidRobert
I've used the OE 360 harmonic dampener and the 10239 BM plate with the scallop cut out with a neutral converter on several 360/904's & works flawless
[Re: tech118]
#532234
07/26/14 06:41 PM
07/26/14 06:41 PM
Supercuda
About to go away
About to go away
up yours
Like Robert, I have used this flexplate with a 360/A998 combo. In my case the A998 was stock to the 87 Diplomat I stuck a 79 360 into. A998 is the 318 version of the A904 and 318's a neutral balance.
[Re: tech118]
#532236
08/01/14 10:12 PM
08/01/14 10:12 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Good to hear they got you on the right path.
Don't forget to post a pic of the van and toys.
