where to buy correct 4 spd linkage #531952
11/20/09 07:12 PM
11/20/09 07:12 PM
3
340dart4spd Offline OP
Parts Problem
Parts Problem
3
looking to buy correct linkage for 70 coronet 833 trans
Re: where to buy correct 4 spd linkage [Re: 340dart4spd ] #531953
11/20/09 07:16 PM
11/20/09 07:16 PM
California
mickm Offline
mickm  Offline
California
jamie passon www.passonperformance.com
brewers www.brewersperformance.com
both excellent sources
Re: where to buy correct 4 spd linkage [Re: mickm] #531954
11/21/09 09:17 AM
11/21/09 09:17 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: where to buy correct 4 spd linkage [Re: 64dodge572] #531955
11/21/09 09:49 AM
11/21/09 09:49 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
Here you go:
http://www.brewersperformance.com/proddetail.asp?prod=LRS70B
Wayne
Wayne,you're missing one piece.
Re: where to buy correct 4 spd linkage [Re: I go fast] #531956
11/21/09 10:48 AM
11/21/09 10:48 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
We have swivel for the lockout linkage available as well!!:
http://www.brewersperformance.com/proddetail.asp?prod=LS317
Wayne
FAX 937-947-4419
Re: where to buy correct 4 spd linkage [Re: 64dodge572] #531957
11/21/09 12:18 PM
11/21/09 12:18 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
Wayne
Don't take offense to this,but why would you not include it with the complete linkage package? It is required with all 70 b-body 4spd.Some may choose not to use the lockout,most will.Either way if it is included you will have it whether you do or do not use it.
Re: where to buy correct 4 spd linkage [Re: I go fast] #531958
11/21/09 07:25 PM
11/21/09 07:25 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Most people (In my experience) do not use the lockout linkage. This linkage is also used for 66-9 B body when using the PG shifter/box which would not require that swivel. If someone will be using the lockout linkage I change the swivel. Our repro column lock linkage pkg includes the double ended swivel.
Dan@Brewer's
A833 4-speeds, parts & services
