Holley carb question with 440 .509 Cam.
#530522
11/19/09 12:54 AM
11/19/09 12:54 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Is it your experiences that you have to lower the stock power valves to lower than 6.5's with the .509 cam. I know, I know..."take a vacuum reading and see what it wants". But just looking for your experiences. Have you guys had more than 7-8" vacuum with this cam on a 440. pretty stock motor with maybe 9.0 compression.
Thanks for any input. Greg/
Re: Holley carb question with 440 .509 Cam.
[Re: Chargerfan68]
#530523
11/19/09 01:01 AM
11/19/09 01:01 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
My son and I both use the MP .557 cam in our street/strip cars. I have 3.5 P/V's in his 750 and my 850. Both work very good. I dont remember the idle vacum but I believe mine was about 11-12 in nuetral and about 6-7 in gear. Ron
[Re: MrFoFody]
#530526
11/19/09 08:32 AM
11/19/09 08:32 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
My old 440 pulled 8" of vacuum w/ the 509 cam. I ran 3.5 PVs front and back in the Holley 830 DP I had on it. CHIP
[Re: Dodgem]
#530528
11/19/09 11:24 AM
11/19/09 11:24 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use a 6.5 PV in my 750 Holley.383 with the 509 cam.
[Re: Chris2581]
#530529
11/19/09 12:41 PM
11/19/09 12:41 PM
Posts: 5,080 organ
maximum entropy
organ
6.5 here with a 496 and a 509. runs killer. gramma could drive it.
[Re: maximum entropy]
#530530
11/19/09 04:58 PM
11/19/09 04:58 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
3.5 in mine.auto with M1 single plane 825 M Demon idles@725/750 in drive Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#530531
11/20/09 03:33 AM
11/20/09 03:33 AM
Chargerfan68
New York, USA
Thanks for the responses, guys. It is a friend;s engine and I think I need to look for a vacuum leak. The 6.5 valve should work. When I covered the choke horn, the rpm picked up and the idle mix screws did not choke the engine down when screwed all the way in. I think we uncovered the idle transfer slot by idling up the rpm to get it to idle. I'll try spraying some carb cleaner around the carb and manifold to find it. Im pretty sure we have one. Thanks, Greg.
[Re: Chargerfan68]
#530539
11/23/09 09:26 AM
11/23/09 09:26 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks, Greg.
the 509 will not pull Donk for vacuum in a low compression engine. 9:1 is too ow for a 509 cam. If it's a vacuum carb it will be even worse. What stall is he running? what gear? it's all part of the problem. the 509 cam needs 3 things to work. Compression, gear and stall. especially the last two.
