Holley carb question with 440 .509 Cam. #530522
11/19/09 12:54 AM
11/19/09 12:54 AM
New York, USA
Chargerfan68 Offline OP
New York, USA
Is it your experiences that you have to lower the stock power valves to lower than 6.5's with the .509 cam. I know, I know..."take a vacuum reading and see what it wants". But just looking for your experiences. Have you guys had more than 7-8" vacuum with this cam on a 440. pretty stock motor with maybe 9.0 compression.
Thanks for any input.
Greg/
Re: Holley carb question with 440 .509 Cam. [Re: Chargerfan68] #530523
11/19/09 01:01 AM
11/19/09 01:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My son and I both use the MP .557 cam in our street/strip cars. I have 3.5 P/V's in his 750 and my 850. Both work very good. I dont remember the idle vacum but I believe mine was about 11-12 in nuetral and about 6-7 in gear. Ron
Re: Holley carb question with 440 .509 Cam. [Re: 383man] #530524
11/19/09 02:46 AM
11/19/09 02:46 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I have a 4.5" pv . I have the .590 cam. I have 9" of vacuum at idle. I also run 20* of initial timing.
Re: Holley carb question with 440 .509 Cam. [Re: Joshs68] #530525
11/19/09 03:53 AM
11/19/09 03:53 AM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
I have a 3.5 power valve in my 383 which has the "509". It idles at 7" vacuum
Re: Holley carb question with 440 .509 Cam. [Re: MrFoFody] #530526
11/19/09 08:32 AM
11/19/09 08:32 AM
an8sec70cuda Offline
My old 440 pulled 8" of vacuum w/ the 509 cam. I ran 3.5 PVs front and back in the Holley 830 DP I had on it. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Holley carb question with 440 .509 Cam. [Re: an8sec70cuda] #530527
11/19/09 10:13 AM
11/19/09 10:13 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I used to run a 5.5 on my 509 advance the cam a bit and the bottom end and idle improve a hole lot so a 6.5 would be fine!
Re: Holley carb question with 440 .509 Cam. [Re: Dodgem] #530528
11/19/09 11:24 AM
11/19/09 11:24 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use a 6.5 PV in my 750 Holley.383 with the 509 cam.
Nautilus Racing-
Re: Holley carb question with 440 .509 Cam. [Re: Chris2581] #530529
11/19/09 12:41 PM
11/19/09 12:41 PM
organ
maximum entropy Offline
organ
6.5 here with a 496 and a 509. runs killer. gramma could drive it.
Re: Holley carb question with 440 .509 Cam. [Re: maximum entropy] #530530
11/19/09 04:58 PM
11/19/09 04:58 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
3.5 in mine.auto with M1 single plane 825 M Demon
idles@725/750 in drive
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Holley carb question with 440 .509 Cam. [Re: tex013] #530531
11/20/09 03:33 AM
11/20/09 03:33 AM
New York, USA
New York, USA
Thanks for the responses, guys. It is a friend;s engine and I think I need to look for a vacuum leak. The 6.5 valve should work. When I covered the choke horn, the rpm picked up and the idle mix screws did not choke the engine down when screwed all the way in. I think we uncovered the idle transfer slot by idling up the rpm to get it to idle.
I'll try spraying some carb cleaner around the carb and manifold to find it. Im pretty sure we have one.
Thanks,
Greg.
Re: Holley carb question with 440 .509 Cam. [Re: Chargerfan68] #530532
11/20/09 07:03 PM
11/20/09 07:03 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Make sure the initial timing is sufficient before bothering with anything else. If it's got less than about 18 initial, it doesn't have enough.
Re: Holley carb question with 440 .509 Cam. [Re: RobX4406] #530533
11/20/09 08:20 PM
11/20/09 08:20 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
wouldn't a vacuum gauge help to determine the best idle advance and vacuum?
Re: Holley carb question with 440 .509 Cam. [Re: blownzoom440] #530534
11/20/09 09:46 PM
11/20/09 09:46 PM
Pasagetdowndena
Cranky Offline
Cranky  Offline
Pasagetdowndena
Where is the cam degreed in at?
Re: Holley carb question with 440 .509 Cam. [Re: Cranky] #530535
11/22/09 12:47 AM
11/22/09 12:47 AM
New York, USA
New York, USA
This is one of those "I have no idea. The guy I bought it from said it's a worked to the balls 440...." I have a feeling this is a stock low compression 440 with way too big of a cam bleeding off too much cyl pressure.
I am just trying to help him out as much as I can, but he doesn't know too much about the motor. Just know he installed the 509 cam and put back the performer 440 manifold. I just put on a fresh 750 holley and needed to use a 1" spacer with the fuel line he wanted to use. The vacuum leak was detected between the spacer and manifold. I think the transition slot is uncovered and the power valve will be fine once I can turn out the idle speed screw to cover up the transition slots.
Thanks.
Re: Holley carb question with 440 .509 Cam. [Re: RobX4406] #530536
11/22/09 12:51 AM
11/22/09 12:51 AM
New York, USA
New York, USA
Thanks. When I took a look at the engine, the vacuum advance canister was planted up against the heater hoses. Someone installed the dist way out of phase. I have to pull it out and move the oil pump driveshaft around to rephase the distrib. so that I can correctly dial in more advance.
I hate messing with things I haven't built
Re: Holley carb question with 440 .509 Cam. [Re: Chargerfan68] #530537
11/22/09 12:59 AM
11/22/09 12:59 AM
ELYRIA,OH
ELYRIA,OH
as long as you have the dist out put a lock coller on the dist shaft to keep the timing steady holding down the intermediat shaft from floating.Granger sells the coller for about 3$ 1/2"
Re: Holley carb question with 440 .509 Cam. [Re: maximum entropy] #530538
11/22/09 11:58 AM
11/22/09 11:58 AM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
I use a 6.5 PV in my 750 Demon. 440 with the .509" cam.If you have an older Holley. you may need do drill 1/8" holes in the primary throttle blades to get it to work off the idle system.
Re: Holley carb question with 440 .509 Cam. [Re: Chargerfan68] #530539
11/23/09 09:26 AM
11/23/09 09:26 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Thanks,
Greg.
the 509 will not pull Donk for vacuum in a low compression engine. 9:1 is too ow for a 509 cam. If it's a vacuum carb it will be even worse. What stall is he running? what gear? it's all part of the problem. the 509 cam needs 3 things to work. Compression, gear and stall. especially the last two.
Coming soon!!!!
