What does a Volare front-end fit? #529925
11/18/09 05:27 PM
11/18/09 05:27 PM
Eyewa
330Scott Offline OP
330Scott  Offline OP
Eyewa
A few years ago I pulled a complete Volare front-end thinking that it would fit under my '46 WC. From what I have been able to find out it would be a very difficult & expensive way to go, so I was just wondering if it may fit some other old Mopar.
I know that these front-ends were the hot item for the older Ford F-1 & F-100 pickups for a few years, but that is all I have been able to determine so far.
So any ideas if this front-end will work on a Mope?
Thanks,
Scott
Re: What does a Volare front-end fit? [Re: 330Scott] #529926
11/18/09 06:22 PM
11/18/09 06:22 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Dodge Aspens?
It would probably fit pickups with flat frame rails better than the swoopy-framed IFS equipped '34 and later Mopars.
Maybe a good match for someone with a 50's and earlier Mopar pickup truck?
Re: What does a Volare front-end fit? [Re: rabid scott] #529927
11/18/09 06:29 PM
11/18/09 06:29 PM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
F,M, J- body K-frames were used for a lot of street rods prior to more convenient alternatives that are seen today. They had been used under late 40'5 and 50's era mopars to get disk brakes up front and some people like a torsion bar suspension.
But today there are Dakotas which have a rack and pinion steering and can be adapted to some of these trucks easier. As those F,M,J body cars get older parts get more expensive which makes them less desirable swaps.
The other answer is something fitting may have more to do with the tools you have at hand and your ability to make something fit. A persons ability to fabricate is often defines the limit of what "fits" and what doesn't when it comes to street rods.
Brian
Re: What does a Volare front-end fit? [Re: bohmer2] #529928
11/18/09 07:01 PM
11/18/09 07:01 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Mine fits fine and was easy install...ride is good and with the disc brakes it stops when I want it to,unlike with the drum brakes..only problem was with the headers not clearing the P/S box..but after some %$#@*& ,it now fits..the car is 1956 Plymouth
Re: What does a Volare front-end fit? [Re: dynamite] #529929
11/19/09 09:18 AM
11/19/09 09:18 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
a friend of mine has one under a 48 dodge coupe he is working on,,a previous owner did the work,
you need a fat fenderd car or truck to use that front end, or the torsion bars will be visable,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: What does a Volare front-end fit? [Re: fstfish66] #529930
11/19/09 09:14 PM
11/19/09 09:14 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I put one under a 35 Dodge sedan, but the front sheetmetal was modified a lot. In most cases, you have to cut off the front frame and build something to mount the cross torsion bar (F, M, & J body) suspension to. Like stated above, you need to have a fat fender body or truck newer then 48 for the F, M, & J clip to work without sheetmetal modification. Gene
Re: What does a Volare front-end fit? [Re: poorboy] #529931
11/20/09 12:52 AM
11/20/09 12:52 AM
Eyewa
330Scott Offline OP
330Scott  Offline OP
Eyewa
Thanks, guys. I figured that the best candidates would be post-war cars primarily because they are wider.
Very nice '56, Dynamite.
So what to do with this front-end I have?
What to do?
single choice
Votes accepted starting: 11/19/09 11:52 PM
Re: What does a Volare front-end fit? [Re: 330Scott] #529932
11/21/09 01:35 AM
11/21/09 01:35 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
pics under a 48 dodge
2015 cherokee
2013 R/T classic
Re: What does a Volare front-end fit? [Re: fstfish66] #529933
11/21/09 04:22 PM
11/21/09 04:22 PM
Pa. bucks county
cuhemida Offline
cuhemida  Offline
Pa. bucks county
HEY THAT IS A PIC'S OF MY 48 DODGE WITH THE DESOTO HEMI IN IT NICE LOOKING FIT
Re: What does a Volare front-end fit? [Re: 330Scott] #529934
11/21/09 05:35 PM
11/21/09 05:35 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Thanks 330 Scott,,I didn't mention my 56 has a 440 mounted on that K-frame and t-flight,8 3/4 rear and runs 12.50 @107.
Re: What does a Volare front-end fit? [Re: cuhemida] #529935
11/22/09 01:29 AM
11/22/09 01:29 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
get off of the computer tom,,and get that car together,,LOL
2015 cherokee
2013 R/T classic
Re: What does a Volare front-end fit? [Re: dynamite] #529936
11/22/09 01:31 AM
11/22/09 01:31 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
thats kool looking,, is that a plaza or a belvedere ?
2015 cherokee
2013 R/T classic
Re: What does a Volare front-end fit? [Re: dynamite] #529937
11/22/09 01:56 AM
11/22/09 01:56 AM
Under the big sky
stateline Online content
stateline  Online Content
Under the big sky
Cool looking car !!- great color combo !!!
Re: What does a Volare front-end fit? [Re: fstfish66] #529938
11/22/09 08:46 AM
11/22/09 08:46 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
It's a Belvedere...and thanks
Re: What does a Volare front-end fit? [Re: dynamite] #529939
11/23/09 08:56 AM
11/23/09 08:56 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
love that forward look emblem on the gas fill area you get the dare to be different award,,very kool,,
2015 cherokee
2013 R/T classic
Re: What does a Volare front-end fit? [Re: fstfish66] #529940
11/24/09 07:39 PM
11/24/09 07:39 PM
Eyewa
330Scott Offline OP
330Scott  Offline OP
Eyewa
Just curious, but for you guys who are using a Volare front end, were you able to pretty much just mount up the front end to your existing frame and use the rubber k-frame isolators? Or did you cut off the front of your frame and then build up a stub to mount the Volare front end onto? The pic of the '48 looks like it could be the latter.
Thanks,
Re: What does a Volare front-end fit? [Re: 330Scott] #529941
11/24/09 09:50 PM
11/24/09 09:50 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The 3 I've done I cut off the original frame and built a 2" x 4" subframe to bolt the clip to. The front 2 bolt holes are wider then the rear 2 bolt holes by 4", Thought I had a picture of the 54 truck's frame but can't find it right now. Gene
Re: What does a Volare front-end fit? [Re: 330Scott] #529942
11/25/09 12:16 AM
11/25/09 12:16 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
you will have to slice and dice,it wont bolt up to any thing like it does the factory volare,,,you will have to make sure it is square,,and figure in where you want your ride height to end up,all tho you can get dropped spindles for that front end from fat mans
2015 cherokee
2013 R/T classic
Re: What does a Volare front-end fit? [Re: 330Scott] #529943
11/26/09 08:31 AM
11/26/09 08:31 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
As for the Volere type K frame.In my 56 I did make a new sub frame,only because a friend of mine who was a master welder wanted to...and it came put beautiful,,,but if I had to do it again I think I would use the original frame..easier to align up the front clip etc..each car is different..
Re: What does a Volare front-end fit? [Re: dynamite] #529944
03/09/10 03:23 AM
03/09/10 03:23 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
any one with extra parts?? looking for the drivers side rotor dust shield 11 in rotors ,please E MAIL ME ON THIS thanks fstfish66@aol.com
2015 cherokee
2013 R/T classic
