Just curious, but for you guys who are using a Volare front end, were you able to pretty much just mount up the front end to your existing frame and use the rubber k-frame isolators? Or did you cut off the front of your frame and then build up a stub to mount the Volare front end onto? The pic of the '48 looks like it could be the latter.
Thanks,
