Power to Ignition dies when key is turned to start #529668
11/18/09 08:45 AM
11/18/09 08:45 AM
St. Clair Shores, Michigan
bigsbigelow Offline OP
Having a weird problem. Power to my Duster's ignition system dies when I turn the key to start. I can start the car by bumping the relay with key in the run position. Any one else had this problem and have a cure?
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Power to Ignition dies when key is turned to start [Re: bigsbigelow] #529669
11/18/09 09:12 AM
11/18/09 09:12 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
It's usually a wiring-connection issue(possibly at bulkhead harness) or ballast resistor problem. It's most likely not an ignition switch problem.
Re: Power to Ignition dies when key is turned to start [Re: buildanother] #529670
11/18/09 09:56 AM
11/18/09 09:56 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Usually the ballast resister.
Re: Power to Ignition dies when key is turned to start [Re: MoparforLife] #529671
11/18/09 10:09 AM
11/18/09 10:09 AM
Nebraska
Dodge-N-Shelby Offline
Nebraska
If its an automatic car I would check your neutral safty wiring. Ground the wire going to the neutral safty switch at the starter relay and see if it starts with the key. Careful because it will start in gear that way.
Re: Power to Ignition dies when key is turned to start [Re: bigsbigelow] #529672
11/18/09 10:18 AM
11/18/09 10:18 AM
while a helper turns the key to "start" you check voltages at the "point" of the pentastar ECU connector and at the coil positive primary terminal with your VOM & if no fire work your way back to the bulkhead via the ballast & further upstream (under the dash) if need be & can take off the brown "sol" wire at the starter relay to keep the starter from running down the batt if needed.
Re: Power to Ignition dies when key is turned to start [Re: MoparforLife] #529673
11/18/09 02:01 PM
11/18/09 02:01 PM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
if BRAKES light on cluster dims but doesn't turn off, then ballast and bulkhead are good, although is something to check.
Re: Power to Ignition dies when key is turned to start [Re: bigsbigelow] #529674
11/18/09 04:15 PM
11/18/09 04:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Where are you measuring the power? The ignition switch has two circuits, IGN1 (RUN) and IGN2 (START); it is normal for IGN1 to shut off when the key is in the START position.
Re: Power to Ignition dies when key is turned to start [Re: John_Kunkel] #529675
11/18/09 05:29 PM
11/18/09 05:29 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
my 73 duster would start and die...i thought it was the ballast resistor, i traced the problem to the bulkhead connector.
Tony
70 AARCuda Vitamin C
Re: Power to Ignition dies when key is turned to start [Re: John_Kunkel] #529676
11/18/09 05:41 PM
11/18/09 05:41 PM
IL
71383beep Offline
71383beep  Offline
IL
I thought IGN2 sends power directly to the coil therefore bypassing the Ballast resistor. I had a similar problem...the car would start as i let go of the key and it detented into the Run position. In start it would just turn and turn. Cleaning the bulkhead connectors did the trick.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Power to Ignition dies when key is turned to start [Re: bigsbigelow] #529677
11/18/09 07:31 PM
11/18/09 07:31 PM
Hawaii
Dodgeballs Offline
Dodgeballs  Offline
Hawaii
Yes. Same way on my Challenger. When you start turn the ignition key to start, the IGN1 "Run" wire that goes to the ballast resistor (the power for the coil while key is in "run" position) is not hot. Only the full voltage IGN2 "Start" wire that gives extra power to the coil while starting is hot. This is the wire that is connected to the same side of the ballast resistor as the wire that connects to the + terminal on the coil.
If you bypass the ballast resistor (say to connect the "run" wire to an MSD control) you will not get voltage while cranking. To fix this, splice the IGN2 wire to the IGN1 wire.
Re: Power to Ignition dies when key is turned to start [Re: Dodgeballs] #529678
11/18/09 08:16 PM
11/18/09 08:16 PM
Valencia, España
Valencia, España
do you have the brakes light OFF at cluster while cranking ?
Re: Power to Ignition dies when key is turned to start [Re: NachoRT74] #529679
11/19/09 07:41 AM
11/19/09 07:41 AM
None of the factory warning lights are hooked up. My under hood, dash, and column wiring harness are brand new. I took a break from working on the car yesterday (been thrashing on it since last Tuesday). I'll check and see if I have any loose connections tonight and I know I gotta make a couple more ground straps. One for the column for sure. Thanks for the tips fellas.
Re: Power to Ignition dies when key is turned to start [Re: bigsbigelow] #529680
11/19/09 01:23 PM
11/19/09 01:23 PM
Upper Midwest
Upper Midwest
make sure that you have a good ground from the rear of the engine to the fire wall too. Very important.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Power to Ignition dies when key is turned to start [Re: bigsbigelow] #529681
11/19/09 11:24 PM
11/19/09 11:24 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Try swapping out the ECU for one that you know works.
CrAzYMoPaRGuY
Re: Power to Ignition dies when key is turned to start [Re: Dodgeballs] #529682
11/20/09 03:17 AM
11/20/09 03:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That is correct. You could unplug the ballast and the car should still start but of course it will die as soon as you let go of the key. The ing 2 is the bypass for the ballast in the crank position sending battery voltage to the coil while cranking.
Does the car crank over when in the start position ? Ron
Re: Power to Ignition dies when key is turned to start [Re: 383man] #529683
11/20/09 07:52 AM
11/20/09 07:52 AM
Yes, the car will crank over just won't run. I can set the key to run and fire the car from the relay and it runs fine. I do have a dual ballast wiring harness but just have it hooked up to a single MSD ballast resistor to match my Blaster Coil. Could that be a problem?
Re: Power to Ignition dies when key is turned to start [Re: bigsbigelow] #529684
11/20/09 08:21 AM
11/20/09 08:21 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Duh
Re: Power to Ignition dies when key is turned to start [Re: CokeBottleKid] #529685
11/20/09 09:20 AM
11/20/09 09:20 AM
Duh
haha Figures. Could I splice the wires and fix them together with a single end and fix the problem or would that just mess things up more?
Re: Power to Ignition dies when key is turned to start [Re: bigsbigelow] #529686
11/20/09 10:47 AM
11/20/09 10:47 AM
connect the blue and the brown wires together on the one connector & you're set. (4 pin ECU I'm assuming) EDIT you have the OE double connectors/wiring harness that were on each end of the 4 terminal ballast and you plugged your new 2 terminal ballast into one half of each of these plastic connectors? If this is correct jump the blue to the brown.
Re: Power to Ignition dies when key is turned to start [Re: CrAzYMoPaRGuY] #529687
11/20/09 11:01 AM
11/20/09 11:01 AM
IL
71383beep Offline
71383beep  Offline
IL
The ECU does not get power when on IGN1 or start. Power is sent directly to the coil (brown wire from post 22 on FSM). When you let go of the key after the motor catches the key detents to IGN2 or Run which then sends power to the ballast resistor and in turn ECU (Blue wire from Post 23 on FSM). During start the ECU is not needed.
A classic ballast resitor or ECU problem is the car will START but not RUN. This problem is opposite to that which means something is wrong between the switch and the wiring directly to the coil or the switch itself.
