What's the Verdict on Hardblock? #529624
11/18/09 02:04 AM
11/18/09 02:04 AM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
Is it a good idea or not? Some seem to like the idea, others don't
I'm pulling my Indy headed 408 this winter and making some changes to hopefully put in into the 10.0 -9.90 range (currently runs 10.30s-.40s). I'm running a factory 76 360 block... Should i do a short fill while i have it apart? thanks-Andy
Re: What's the Verdict on Hardblock? [Re: 340_Dart] #529625
11/18/09 07:22 AM
11/18/09 07:22 AM
wappinger falls new york
Jimi_Vignogna Offline
if you are going to bore and hone the block again it will be ok. the block need to sit a month or better before you machine anything on it.also have the mains torqued and fill one side at a time keeping the deck level for at least 24 hours, torque the heads down with the fasteners you would normally use after you fill the water jacket.i only use hardblock none of the other fillers stay together inside the block like hardblock.
Re: What's the Verdict on Hardblock? [Re: Jimi_Vignogna] #529626
11/18/09 09:39 AM
11/18/09 09:39 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i had my indy headed 408 half filled last year about 1 gallon and no issues here, even runs same temp in 80* weather.
Re: What's the Verdict on Hardblock? [Re: mopar dave] #529627
11/18/09 10:20 AM
11/18/09 10:20 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
For regular street driving it's not a good idea. For strip and limited street is works well.
Re: What's the Verdict on Hardblock? [Re: 340_Dart] #529628
11/18/09 10:33 AM
11/18/09 10:33 AM
an8sec70cuda Offline
Water temperature isn't the problem, it's the oil temperature you have to watch with a filled block if you're still going to drive it on the street. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What's the Verdict on Hardblock? [Re: an8sec70cuda] #529629
11/18/09 02:36 PM
11/18/09 02:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Anything you can do to stabilize the bores is a good idea, since you're gonna work that stock block pretty hard to get 10-ohs.
Re: What's the Verdict on Hardblock? [Re: topside] #529630
11/18/09 03:02 PM
11/18/09 03:02 PM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
It's just a drag car, so I think I'll look into doing a short fill this winter
Re: What's the Verdict on Hardblock? [Re: topside] #529631
11/18/09 03:03 PM
11/18/09 03:03 PM
sg66mopar Offline
sg66mopar  Offline
I ran a filled iron block for years. It actually made the motor cool faster between rounds. As stated earlier, this is for race use only, not the street. I also agree that Hardblok is the only product to use.
Get the block VERY level and keep the filler at least 1" below the water jackets. One of my blocks was done by a local machine shop. They had the block on an engine stand that drooped in the front and got the filler up too high in the back, blocking one of the rear water jackets. I didn't catch the problem until it had caused two heads to crack from the overheating. It took me over 8 hours to dig the Hardblok out of that water jacket and make a hole for the water to circulate.
Re: What's the Verdict on Hardblock? [Re: sg66mopar] #529632
11/18/09 08:01 PM
11/18/09 08:01 PM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
What form does hardblok come in? I see it comes in 2 different sizes, one to do a short fill, and one to do a tall fill. There's only 10$ difference in price though....
Re: What's the Verdict on Hardblock? [Re: 340_Dart] #529633
11/18/09 08:14 PM
11/18/09 08:14 PM
organ
maximum entropy Offline
organ
it's a powder (like cement, without gravel- you'll have to add that yourself ) that you add water to. it's quite easy to work with.
Re: What's the Verdict on Hardblock? [Re: 340_Dart] #529634
11/18/09 08:26 PM
11/18/09 08:26 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
It's just a drag car , so I think I'll look into doing a short fill this winter
For that reason you should be doing a tall fill. Mopar blocks are particularly thin and it's really hard to find one with real sturdy walls. IMO a short fill is little more than a "better than nothing" deal on a dedicated drag car. It's not just for durability sake, there is power to be had in stable bores.
MB
Re: What's the Verdict on Hardblock? [Re: sg66mopar] #529635
11/18/09 10:37 PM
11/18/09 10:37 PM
oregon
savoyracer Offline
savoyracer  Offline
oregon
...........same thing happened to me, I caught it in time, and made the machinist dig it out.
Re: What's the Verdict on Hardblock? [Re: savoyracer] #529636
11/18/09 10:42 PM
11/18/09 10:42 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
what happined to embeco 885 grout?
Re: What's the Verdict on Hardblock? [Re: blownzoom440] #529637
11/18/09 10:49 PM
11/18/09 10:49 PM
orange,tx
O
onebadstepside Offline
O
orange,tx
I have a question about the hardblock....Can you get away with a short fill on limited street driving with a oil cooler...say no more than 30-40 miles at a time?thanks for any information
Small blocks rule!!!!!
Re: What's the Verdict on Hardblock? [Re: onebadstepside] #529638
11/18/09 11:02 PM
11/18/09 11:02 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Run an extra capacity oil pan and that oil cooler isn't a bad idea either. The hard blok also stabilizes the bottom of the block and keeps the bearing clearances constant. I say go for it and run an oil temp gauge.
Re: What's the Verdict on Hardblock? [Re: dodgeboy11] #529639
11/19/09 06:57 AM
11/19/09 06:57 AM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
What's considered a tall fill and how do you cool the heads ?
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: What's the Verdict on Hardblock? [Re: 65dragnet] #529640
11/19/09 08:36 AM
11/19/09 08:36 AM
A tall fill is usually up to an inch or so below the deck surface. The heads always have water circulating through them like normal, that doesn't change. Unless you fill the block too high and the water gets blocked from getting up to the heads. CHIP
CHIP
Re: What's the Verdict on Hardblock? [Re: an8sec70cuda] #529641
11/19/09 08:42 AM
11/19/09 08:42 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We did a short fill to the bottom of the freeze plugs. Now I do still dirve the car on the street. I take it to cruse nights all the time around here. Which I live in the middle of no-where so its a 30 to 40 min trip one way. I do run an oil cooler also. I've had no problems at all.
Re: What's the Verdict on Hardblock? [Re: 70dusterjohn] #529642
11/19/09 11:50 AM
11/19/09 11:50 AM
Kewaskum, WI
K
Kelob_pie Offline
Kelob_pie  Offline
K
Kewaskum, WI
I have mine filled 1/2" above the tops of the freeze plugs on my 440, no issues yet, except that my cooling is almost too good now.
Re: What's the Verdict on Hardblock? [Re: Kelob_pie] #529643
11/19/09 02:24 PM
11/19/09 02:24 PM
Cab_Burge Online work
Cab_Burge  Online Work
The bad thing about using any filler in a block is that the cylinder walls above the filler are at a different tempature than the wall portion below the filler do to coolant circulation, there is no coolant flow in the fill I have measured a block on the engine dyno that was 120 F above the fill and 180 F at and below the fill level, that makes the cylinder walls expand differently also. The measurements where done with a hand held infra red gun You can feel the heat differences with your hand also I know guys that run filled blocks and swear by them, I have also out ran them in the same NHRA Stock class(B/SA) with no fill in my motor
