Friends 440 goes bang.... Carnage pics #527135
11/15/09 09:18 PM
11/15/09 09:18 PM
Tennessee
727builder Offline OP
Tennessee
She's was together for over 2 years with 1000 plus passes. Was a 30 over stock stroke 440 with Eddy heads, Manley rods, Ross pistons. Crank came out in 3 pieces, Ruined 2 pistons and rods. I can say Manley Rods are tough!!!! Destroyed the block. Busted 6 of the 8 cylinders. All of the main webbing from # 3 was ripped out of the block. Was amazed it didnt hurt the Cam, Lifters, or pushrods. Bent one valve in the eddy's.
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527136
11/15/09 09:22 PM
11/15/09 09:22 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
wow that is amazing having all the cylinders crack in the same place.
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527137
11/15/09 09:24 PM
11/15/09 09:24 PM
Tennessee
Tennessee
Some very tough rods, And none of the rod bolts let go.
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527138
11/15/09 09:27 PM
11/15/09 09:27 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
WOW,,,,
Looks familiar,,,i grenaded mine a few weeks ago,,,,didnt smoke the block that much,,,but still with major damage...
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527139
11/15/09 09:27 PM
11/15/09 09:27 PM
Tennessee
Tennessee
another...
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527140
11/15/09 09:32 PM
11/15/09 09:32 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
man,,those rods got BENT up...
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527141
11/15/09 09:32 PM
11/15/09 09:32 PM
Tennessee
Tennessee
Anyone want a free crankshaft?
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527142
11/15/09 09:35 PM
11/15/09 09:35 PM
Tennessee
Tennessee
But the arp main bolts didnt give up.
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527143
11/15/09 09:44 PM
11/15/09 09:44 PM
Tennessee
Tennessee
I cant get over it ripping out all of the main webbing on # 3, All the way to the cam bearing.
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527144
11/15/09 09:51 PM
11/15/09 09:51 PM
ELYRIA,OH
ELYRIA,OH
did all of the caps servive not braking?
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527145
11/15/09 10:03 PM
11/15/09 10:03 PM
Ohio, USA
Dr-Dave2 Offline
Dr-Dave2  Offline
Ohio, USA
Man! those are some UGLY photos!! How hard was he running that thing? RPMs and horse power levels?
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527146
11/15/09 10:21 PM
11/15/09 10:21 PM
B.C.
mk_ Offline
mk_  Offline
B.C.
wonder if the crank broke first and took the block with it?
Re: Friends 440 goes bang.... Carnage pics [Re: Dr-Dave2] #527147
11/15/09 10:33 PM
11/15/09 10:33 PM
Tennessee
Tennessee
3700 lbs car w/driver, Around 580 hp, Shifting @ 6600 His Best et was 6.76 in 1/8 mile.
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527148
11/15/09 10:35 PM
11/15/09 10:35 PM
ELYRIA,OH
ELYRIA,OH
i dont think that is a stock block.the lifter area looks aftermarket.
Re: Friends 440 goes bang.... Carnage pics [Re: mk_] #527149
11/15/09 10:37 PM
11/15/09 10:37 PM
Tennessee
Tennessee
Beats me.
Re: Friends 440 goes bang.... Carnage pics [Re: blownzoom440] #527150
11/15/09 10:40 PM
11/15/09 10:40 PM
Tennessee
Tennessee
It was a 10/26/72 dated stock block
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527151
11/15/09 10:42 PM
11/15/09 10:42 PM
ELYRIA,OH
ELYRIA,OH
i just had to check,thanks!sorry for the loss.
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527152
11/15/09 11:42 PM
11/15/09 11:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
1000 runs + , did he ever pull the oil pan and inspect the rod and main bearings as well as look for cracks in the main webs, if not this would be a good example of why you should look after 300 to 500 runs
Re: Friends 440 goes bang.... Carnage pics [Re: Cab_Burge] #527153
11/16/09 12:17 AM
11/16/09 12:17 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
I'd have to say it's more likely the block broke first and took out the crank. If the crank broke first how could it do all that damage to the block?
Re: Friends 440 goes bang.... Carnage pics [Re: 727builder] #527154
11/16/09 08:50 AM
11/16/09 08:50 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
A little JB Weld will fix that right up.
Dave Reitz (Tom Sneden's crewchief from back in the 70's) was telling me that when they ran iron blocks on Nitro they would get about 70 runs before the main webs let go. They would crack in the same place. He would run the block when cracked; they would replace it when they had to chisle the main bearings out because they would flow into the crack meaning that it opened up enough to force the bearing into the block . I agree with Cab; regular inspections are a must.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
