Page 1 of 3 1 2 3
Edelbrock STR-14 #526874
11/15/09 06:23 PM
11/15/09 06:23 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I have a STR-14-4 Manifold wanting trade/buy or even make a top for a crossram 2 4 BBL. I was wondering are the bottoms the same for all the different tops? Has anyone ever made a top?
Thanks Brian
Re: Edelbrock STR-14 [Re: Bishop] #526875
11/15/09 06:32 PM
11/15/09 06:32 PM
bottoms are all the same. i made a top for 2-4bbl.
Re: Edelbrock STR-14 [Re: Bishop] #526876
11/15/09 06:47 PM
11/15/09 06:47 PM
Petersburg, Va
Darrell Offline
Darrell  Offline
Petersburg, Va
Thanks Brian
Great question, I have one with a single 4 top and have wanted a 6pack and 2x4 top but didn't know if they were the same bottoms.
Re: Edelbrock STR-14 #526877
11/15/09 06:54 PM
11/15/09 06:54 PM
the carb linkage was a real PITA though.
Re: Edelbrock STR-14 #526878
11/15/09 07:03 PM
11/15/09 07:03 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
Do you have any pictures of the one you made and some of the linkage?
Re: Edelbrock STR-14 [Re: Bishop] #526879
11/15/09 07:49 PM
11/15/09 07:49 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
Thanks Brian
Are you looking to make the Crossram version or the inline version?Check with Damon at Diamonback Engines he won't give up any secrets lol but he will help you out.Really good guy to work with and knows his stuff when it comes to STR's. http://www.diamondbackengines.com/ http://www.diamondbackengines.com/forums/index.php#2
Or I can send you demensions on the crossram top plate,but I gotta tell ya lol,the crossrams a real hair ripper to make.
As SUPERSTOCKER stated the linkage is a real PITA,But I have a set up for it (Carb/Linkage East & West set up).
Let me know.
Re: Edelbrock STR-14 [Re: kruger] #526880
11/15/09 08:49 PM
11/15/09 08:49 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
hey guys, i've got some open cnc mill time coming up and would be willing to make a few of the str tops if people are intersted. if someone can send me dimensions i can figure rough costs. any carb mounting arrangement you want. dual 4 inline or cross ram, six pack, whatever, all the same price and will be made from 6061 aluminum. i could even integrate a blow out port so the top won't crack in case of back fire.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Edelbrock STR-14 [Re: Jerry] #526881
11/15/09 08:59 PM
11/15/09 08:59 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
Huuuum,I'll give a shot Jerry.Beats rackin my brains out trying to find these tops all the time.I'll send you some deminsions on Tuesday.PM we'll discuss?
Just checked out your website
Yep he can do it
Jerry,would you make just a couple or is there a minimum?
Re: Edelbrock STR-14 #526882
11/15/09 09:15 PM
11/15/09 09:15 PM
wappinger falls new york
Jimi_Vignogna Offline
the bottoms are not all the same, i have str's that were built for just cross ram tops and str's that were built for single 4bbl and inline two four bbl, i do not know if this was a design change or if it was for different carb locations.
Re: Edelbrock STR-14 [Re: Jimi_Vignogna] #526883
11/15/09 09:37 PM
11/15/09 09:37 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I'll make one offs, there is no minimum as it will be filler work for my shop, so i can run them on an as needed basis, plus i will add it to my sales items, for the future in case anyone else needs one.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Edelbrock STR-14 *DELETED* [Re: Jimi_Vignogna] #526884
11/15/09 09:38 PM
11/15/09 09:38 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Post deleted by hemi-itis
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Edelbrock STR-14 [Re: Jimi_Vignogna] #526885
11/15/09 09:41 PM
11/15/09 09:41 PM
all str-14 bottoms are the same, the tops are all interchangeable, going by direct connection part # inside of the bottom cast into it
Re: Edelbrock STR-14 [Re: Jimi_Vignogna] #526886
11/15/09 09:45 PM
11/15/09 09:45 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
I've seen different variations of the bottoms also,small low ribs in the bottom ports where as some didn't.Mines the STR 14 crossram without the chrys stamp/no ribs and theres no support ribs on the top plate like I've seen on some.Not sure if its due to earlier Eddy STR chrysler gen vs the updated STR Eddy or top specific.
Anyone?
Re: Edelbrock STR-14 [Re: kruger] #526887
11/15/09 09:48 PM
11/15/09 09:48 PM
Anyone?
thats true about the insides of the bottoms as some had the part # and some didn't but all the tops are interchangeable. the contours for the lids are the same.
Re: Edelbrock STR-14 [Re: Jerry] #526888
11/15/09 09:49 PM
11/15/09 09:49 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
Thanks jerry,
Do I send this info through your website?or is there an e-mail address I can send the info?
(dimensions and pics)
Re: Edelbrock STR-14 #526889
11/15/09 09:53 PM
11/15/09 09:53 PM
That intake will work well with some epoxy mods to the floor. Plus the STR-15 is the only low deck cross ram available. Damon has been 9.60's with one on a low deck 493. It would be well worth making some lids for them. They would fit both intakes(str-14 and str-15) pretty sure there is a small block version (str-13?) but doubt the tops would interchange...
Re: Edelbrock STR-14 #526890
11/15/09 09:56 PM
11/15/09 09:56 PM
those intakes are absolute slugs. i ran one back in the mid 90's with every direct connection trick and was slow. best i could get out of it was a 11.08
its got a great look for nss but thats about it.
Re: Edelbrock STR-14 [Re: Bishop] #526891
11/15/09 10:02 PM
11/15/09 10:02 PM
Iowa
coronetville Offline
Iowa
all str 15 and str 14 came with two totaly diffent bottoms, one for the cross ram, and one for the single 4, inline 2 4s, six packs. I have a str 15 cross ram intake, I would like to trade for a str single 4
Re: Edelbrock STR-14 #526892
11/15/09 10:04 PM
11/15/09 10:04 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
Anyone?
So I'm assuming the intake bottoms are not specific to the amount of carbs?
Gone googlin
Re: Edelbrock STR-14 #526893
11/15/09 10:08 PM
11/15/09 10:08 PM
YOU ARE WRONG! i have owned one of every design of theses things , and they are not all interchangable!!!!!
Page 1 of 3 1 2 3
