Stay N/A or go Procharger??
#526770
11/15/09 03:04 PM
11/15/09 03:04 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
I need a vote...still debating if I want to stay the N/A route or go a procharger deal.. I know what it will cost to do the procharger route..the motor needs a new set of rods in around 20 to 30 so passes..the rods were the only thing we re-used..so if I am going to change to blown deal now is the time to do it.. The car is going in the Chassis shop late January or Febuary for the 25.5 or 4..I want to put a racepak in it and I am changing the ignition and rewiring it also.. I have sorta put the motor on hold for doing anything to it until I decide what to do with it..I am in no big hurry..the chassis upgrade and other things are going to put me back for next season anyway... I have also thought about not doing the 25.5 to the barracuda and start looking for a mustang coupe to put this motor in for Milan and other N/A races. Too much to ponder!!!
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
Re: Stay N/A or go Procharger??
[Re: FASTFISH420]
#526771
11/15/09 03:15 PM
11/15/09 03:15 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
Makes me remember why I became a bracket racer Good luck whichever way you go but the Procharger sounds like fun but I woudl think will require a 6.00 cert as the 7.50 cert probably wont win any races anymore, let alone two years from now.
[Re: Al_Alguire]
#526772
11/15/09 03:21 PM
11/15/09 03:21 PM
FASTFISH420
Central,Ohio
I know what you mean about the 7.50..you can be pretty competative in drag radial at Milan at 7.50..I am not going to go crazy..just a F2 blowthru deal...
www.URE-RACING.com
[Re: blownzoom440]
#526774
11/15/09 05:13 PM
11/15/09 05:13 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
BOOST! You'll never go back...
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: bigtimeauto]
#526776
11/15/09 05:47 PM
11/15/09 05:47 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Hmmmmm procharger
at least you are putting out some good HP where you will be takin more seriously for your vote.
[Re: Big B]
#526781
11/15/09 11:32 PM
11/15/09 11:32 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
I say twin turbo. Can make 2000+hp on pump gas.
Im a turbo guy as well, but I think these procharger guys can get to that 2khp also on the pump gas
[Re: FASTFISH420]
#526782
11/16/09 08:53 AM
11/16/09 08:53 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
ProCharger. If you stay N/A, you'll be regretting it later...just like I am. CHIP
[Re: bigtimeauto]
#526783
11/16/09 09:26 AM
11/16/09 09:26 AM
Posts: 325 Greenville, WI
Big B
Greenville, WI
Is that your combo? i would love to see it.
You and me both. I would like twin turbos, but will probably go with a Procharger.
[Re: Mr.Yuck]
#526785
11/16/09 10:20 AM
11/16/09 10:20 AM
FASTFISH420
Central,Ohio
I am not a huge fan of the turbo stuff..way to hard to get the launch technique down.. I love the fast N/A races..but the procharger stuff is growing on me fast...just bad azz power
www.URE-RACING.com
[Re: FASTFISH420]
#526786
11/16/09 10:52 AM
11/16/09 10:52 AM
Posts: 2,286 Hamilton,Ont
72chrgrally
Hamilton,Ont
My question is what are your intentions for the car? Do you want to run an organized, ruled, pound-per-cube class or just your own deal where you do what you want to go fast. If you are planning on getting away from Milan A/M and putting a ProCharger on are you going to try and run drag radial or something else? I think you should do what ever will make you happy. Steve
Photobucket sucks
[Re: an8sec70cuda]
#526787
11/16/09 11:04 AM
11/16/09 11:04 AM
Posts: 4,073 Mo.
racerx
Mo.
I what he said.
[Re: racerx]
#526788
11/16/09 09:33 PM
11/16/09 09:33 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Chris, I say go with the Procharger! As I think you are finding out it's hard to compete with the Mustangs with the older nostalgic body style. I'm looking for the right chassis be it a Mustang or whatever to go the Procharger route with my 430" R3/W8 turbo motor. Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#526789
11/16/09 10:24 PM
11/16/09 10:24 PM
blownzoom440
ELYRIA,OH
Mike Gray
and a huge A/W intercooler will help you get that done.
