Re: How to get carbon off piston top while in block?
[Re: VanishPt]
#526731
11/15/09 02:19 PM
11/15/09 02:19 PM
RapidRobert
put the piston at BDC to keep the particles contained, grease the piston perimeter to keep them from going down into the rings and a small wire wheel brush on a 1/4" drill
[Re: mark7171]
#526733
11/15/09 03:54 PM
11/15/09 03:54 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
I used to steam clean my engine...I would take a soda can and fill it half with water and the other half with mineral spirits. get it mixed well and let the engine warm up for about 5 minutes. With your right hand bring rpm's up with the throttle linkage and with your left hand pour the solution a little bit into the throat of the carb. Only a little bit, don't pour too much each time. The engine will choke a little as you progress, keep it under higher RPMs and rod check between drops. It should take 7-8 instances to pour that can out into the engine. Keep rod checking between.
If you want to see what gets thrown out of your exhaust, put cardboard behind your tail pipes. I did this to a slant six and my 440. I learned this trick from an aircraft mechanic that use to race back in the 70s.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#526735
11/15/09 04:52 PM
11/15/09 04:52 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
I was told by an automotive professor that using water is more likely to break the carbon off in chunks and to use seafoam instead as it will dissolve the carbon better. Can't tell you if its true or not but theres my
[Re: Pyper70]
#526736
11/15/09 04:59 PM
11/15/09 04:59 PM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
Water ? ...good idea .. but a BESTer way is to use water-injection. It will clean-up EVERYTHING ..... ports, combustion chambers, valves and PISTON tops in a more gradual way.
[Re: BeEtLeJuIcE !]
#526737
11/15/09 05:10 PM
11/15/09 05:10 PM
RapidRobert
Similar: I had heard dribble in diesel fuel at a fast idle for a bit then dump in the rest & drown it, let it sit overnite then take it out on the interstate & let er rip then change plugs & you're done.
[Re: Blue66Charger]
#526740
11/16/09 01:16 AM
11/16/09 01:16 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Sea foam. If the engine is running dribbl it in till you used up about 3/4ths of it then drown it and let it sit over night, fire it up an blow it out. If it won't fire put in a new set of plugs then blow it out on the freeway. If the heads are off then put sea foam on the pistons with a paper towl let it soak for a while and scrape it off with a razor blade. Then vacume it out with a good vacume then blow the rings out with a good air compressor. All this time you need to have the valley covered good with a bunch of duct tape
[Re: VanishPt]
#526743
11/16/09 02:00 PM
11/16/09 02:00 PM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
I'd be more worried about what looks like a gouge in the cylinder wall rather than the carbon buildup on the piston. CHIP edit...Just saw the other thread you had about this gouge in the cylinder wall. Did you build this engine the last time? If not, I'd take the piston out of that cylinder and have a look at the rings and the piston itself. And the seapage you mentioned from the head gaskets could be from the rough surface on the deck left behind by the old broach style cutter that block was decked on. CHIP
