putting the coronet on a diet #525774
11/14/09 01:20 PM
11/14/09 01:20 PM
Northern MN
Not a bee Offline OP
Northern MN
Thinking of putting my 69 coronet on a diet this winter.Which fiberglass company makes the nicest six pack hood and bumper, and how much weight do you think I would lose. Car weighs 3700 with driver, and yes the driver is on a diet also.
Re: putting the coronet on a diet [Re: Not a bee] #525775
11/14/09 02:09 PM
11/14/09 02:09 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
typical 'glass street hood: 20-25 lbs. stock hood 60+. No opinion on who is best, avoid Unlimited.
Re: putting the coronet on a diet [Re: forphorty] #525776
11/14/09 08:25 PM
11/14/09 08:25 PM
Northern MN
Northern MN
Thanks. So hopefully between hood and bumper maybe a 100 lbs.
Re: putting the coronet on a diet [Re: Not a bee] #525777
11/14/09 09:51 PM
11/14/09 09:51 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
I just handled my 69 coronet bumber this afnoon and I would guess it weighs about 30-35lbs.
Re: putting the coronet on a diet [Re: repad] #525778
11/14/09 10:28 PM
11/14/09 10:28 PM
Northern MN
Northern MN
I suppose the brackets don't wiegh that much.
Re: putting the coronet on a diet [Re: Not a bee] #525779
11/15/09 01:14 AM
11/15/09 01:14 AM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
I put a fiberglass hood, ft & rear bumpers on my 69 Satellite. I think the hood saved 40 pounds, ft bumper 30 pounds & rear 25 pounds. My car is a strip only car & it helped the et
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: putting the coronet on a diet [Re: Not a bee] #525780
11/15/09 12:23 PM
11/15/09 12:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
bumber brackets are heavy. Most people make their own out of aluminum. Here's the thing...depending on your car and et the 100lbs you take off may or may not help squat. So before you spend $$$$ and time, ask yourself how much et am I going to get? and is it worth it. Upgrades to the drive train will get you better results than spending all that money on glass parts.
Coming soon!!!!
Re: putting the coronet on a diet [Re: Mr.Yuck] #525781
11/15/09 12:41 PM
11/15/09 12:41 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
" Here's the thing...depending on your car and et the 100lbs you take off may or may not help squat. So before you spend $$$$ and time, ask yourself how much et am I going to get? and is it worth it"
Seems to me the old rule of thumb is every 100 lbs. lost is worth a .10 of a second in E.T.
Re: putting the coronet on a diet [Re: pacifica] #525782
11/15/09 12:49 PM
11/15/09 12:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you'd think that but my 1st hand experience tells me different. then there's sprung vs. un-spriung weight. I had a 67 cornet. mild 440. It ran 12.90. I thought wow I'll drop some weight and see if I can get it to run 12.70. So I lost the PS, moved to a smaller optima battery in the trunk, changed out my 15x6 cragars and radials up front for 14x5.5 w/ bais plys (cragars w/ radials) were 45lbs heavier, raced w/ a little over a 1/4 tank than 1/2 and what happend??? same et, same mph everytime. Car was done at 12.90.
Re: putting the coronet on a diet [Re: Mr.Yuck] #525783
11/15/09 01:23 PM
11/15/09 01:23 PM
Truckville, the capital of NY
85_Ram_4speed Offline
Good points, also just moving the weight around will help also. 100 lbs placed right in the car can be more benificial than removing it. It depends on what you want to do with the car. Thefe are alot of things you can do, but some people dont want to compromise some safety on the car to get a lighter weight.
Outcast Dodge guy.
Re: putting the coronet on a diet [Re: Not a bee] #525784
11/15/09 02:03 PM
11/15/09 02:03 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Personally, I think the brackets probably weigh more than the bumper by itself. Shame no one is repopping the brackets in 'glass' to go with the 'glass' bumpers.
Re: putting the coronet on a diet [Re: Jwilli500] #525785
11/15/09 02:32 PM
11/15/09 02:32 PM
Brackets are a great place to lighten the load too. I would not want a glass bracket, but aluminum will work just fine. Heck, even just windowing out a set of stock brackets will take a bunch of wheight off. On my A-body, it had inner and outer brackets. The outers weighed less of the two pairs, so i took them and cut a bunch out of them. I think it was something silly like 20 lbs overall i took off. I was down to 3lbs a pair on my aluminim brackets when it was all said and done.
Outcast Dodge guy.
