Edelbrock Heads - Help needed
#524843
11/13/09 10:34 AM
11/13/09 10:34 AM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
I purchased a valve cover stud kit from the local speed shop. After driving the car for a few days it developed a massive oil leak from the valve covers (trashing my ceramic coated TTi's). When I removed the covers I found that 6 or 8 of the studs broke. I was able to extract all but 2 of the broken studs, and am currently faced with pulling one of the heads. If I have to go that route I was thinking about getting some work done while I have the heads off the car. I remembered reading on the board that someone was doing CNC porting of the 440 EB heads, and getting 300+cfm on the intake side. - Any suggestions for removing broken studs? I've tried a left hand hardened bit and a "kobalt" bit.
- Tips or tricks for removing burned on oil stains from ceramic coated headers?
- Who is the preferred CNC head porter? Will you take an exchange? How long does it take? Price? ETC...
Thanks, Greg
Re: Edelbrock Heads - Help needed
[Re: gsmopar]
#524844
11/13/09 10:46 AM
11/13/09 10:46 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Is there any of the stud protruding from the hole? Even if its just a little bit? It would be easy to take a 5/16 nut and mig the stud to the nut.Heat the area up around the stud and it will fall out. If nothing else its possible to blow the stud out with a torch set without hurting or burning the head.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: gsmopar]
#524850
11/13/09 12:42 PM
11/13/09 12:42 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
If he has Eddy heads I would not try burning the studs out.He will have instant junk as aluminum melts a lot easier than steel will.Pull the head before you screw them up.Rocky
Chrysler Firepower
[Re: Dodgem]
#524851
11/13/09 12:43 PM
11/13/09 12:43 PM
Posts: 810 Sidney Ohio
9SecRoadRunner
Sidney Ohio
now thats customer service! modern cylinder head !
You Thinking It's So Doesn't Make It a Fact
