ID this Carter carb???? #523378
11/11/09 02:47 PM
11/11/09 02:47 PM
an8sec70cuda Offline OP
Can someone tell me what this Carter carb came on? Year model, engine, cfm size, etc?
It has Carter written on it like this... CARbureTER with the "bure" being a lot smaller and inset.
Also says WCFB.
It has a cast iron base, it's HEAVY!
Anyone know what it came off of? Thanks, CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: ID this Carter carb???? [Re: an8sec70cuda] #523379
11/11/09 02:48 PM
11/11/09 02:48 PM
pic 2
CHIP
Re: ID this Carter carb???? [Re: an8sec70cuda] #523380
11/11/09 02:48 PM
11/11/09 02:48 PM
pic 3
CHIP
Re: ID this Carter carb???? [Re: an8sec70cuda] #523381
11/11/09 02:54 PM
11/11/09 02:54 PM
Denver,NC
hemiheadNC Offline
hemiheadNC  Offline
Denver,NC
...looks like a WCFB (Will Carter Four Barrel) mid to late 50's some gm and Mopar apps. They were really heavy
I'm lost in the 60's and DAMN proud of it.
Re: ID this Carter carb???? [Re: hemiheadNC] #523382
11/11/09 10:15 PM
11/11/09 10:15 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Looks like a WCFB (White cast four barrel) 4bbl from an old mopar around the 1950s, mabey another make used them also.
Re: ID this Carter carb???? [Re: HotRodDave] #523383
11/11/09 10:53 PM
11/11/09 10:53 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Actually WCFB does in fact mean William Carter Four Barrel as mentioned above.
Many of the 50's WCFB's lacked stamped in identification numbers, they usually had an attached metal tag to ID them. Does yours have a metal tag?
Here's a pair from a 57/58 Mopar. I restored them for a guy who put them on a 62 Vette, there were allot of them used on early GM's and Mopars that looked VERY much alike.
Re: ID this Carter carb???? [Re: ScottSmith_Harms] #523384
11/11/09 11:27 PM
11/11/09 11:27 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Compare the top view with yours
Re: ID this Carter carb???? [Re: ScottSmith_Harms] #523385
11/12/09 01:30 AM
11/12/09 01:30 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Brought back a tinge of nostalgia looking at those... I remember opening up the hoods of many cars seeing those carbs.....
Scott, are they a decent carb or only something for a nostalgia look or stock??????
Re: ID this Carter carb???? [Re: minivan] #523386
11/12/09 02:28 AM
11/12/09 02:28 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Power wise, no, not great carbs, they have a small CFM rating (most max out around 500cfm) which is why 2 were often used to give stouter 50's V8's enough go juice. That being said when built properly they can be very smooth and dependable on an old cruiser. The cast iron bases make them quite heavy as well, I'd say for a single 4 barrel they are the heaviest of ANY 4 barrel, combine 2 of them with a cast iron intake and it's anchors away!
