Anyone here using a Stacker Trailer?
#523078
11/11/09 01:55 AM
11/11/09 01:55 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Like it says in the title. Is anyone here towing a stacker? If so what brand and length, and what are you towing it with. We are looking at maybe buying a stacker in the not to distant future, any pros and cons? Any input is appreciated.
Post deleted by Defbob
[Re: Chris'sBarracuda]
#523081
11/11/09 02:52 AM
11/11/09 02:52 AM
Re: Anyone here using a Stacker Trailer?
#523082
11/11/09 07:01 AM
11/11/09 07:01 AM
Posts: 317 Indiana
79_W200
Indiana
Stay away from the Renegade brand. I work on primally race trailers. I see alot of the Renegade trailers broken do to lack of quality and not built strong enough, the featherlite seems to be good quality usually only replace worn out tires or brakes.
1979 W200 470
[Re: Al_Alguire]
#523083
11/11/09 07:47 AM
11/11/09 07:47 AM
Posts: 572 Shelbyville, TN USA
40ford
mopar addict
mopar addict
Shelbyville, TN USA
There are two types of trailers called "stackers"; those that lift the car once the car is inside the trailer and (2) those that lift the car using the rear door. In terms of longivity, the type with the lift door are the best but also the most expensive and require the most maintenance. Why? The design requires the "second" floor where the cars ride to be a structural floor, this makes the trailer to be far more rigid. The rear door is either hydraulic or screw type lift----both types require maintenance(cleaning/greasing) on a periodic basis. This type of trailer is usually heavier, requires more tractor to pull/stop, etc. The trailer that lifts the car once inside the trailer is really nothing more than a tall "regular" trailer with a lift insalled inside----often nothing more that a commercial four post lift. They are far cheaper to buy, are much lighter in weight but also are not nearly as strong. We have followed many of these trailers on the road and watched the trailer flex with every bump. Even though the trailers are tall, most can be towed with a heavy one ton dually safely. As a point of comparison, most Renegades are this type of trailer. We own neither type of trailer---although we saw both types at every race we ran in our former life as dirt late model racers---and know plenty of owners. The trailer we own is a 5150, built by a local company----their web site is www.5150racetrailers.com. They are very strong in dirt late models, tractor pullers and just beginning to get into drag racing----they have supplied the Pedegron brothers and have Ron Capps under construction now. I like them for their appearance and custom extruded trim----they also custom build each trailer on a jig plate.
[Re: 40ford]
#523084
11/11/09 09:25 AM
11/11/09 09:25 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
My buddy used to have one.Hiw was gigantic.He was towing with a 3500 Ram and it looked like a tinker toy when it was hooke up.He liked the way it towed but went with a totter.Rocky
Chrysler Firepower
[Re: 79_W200]
#523087
11/11/09 11:26 AM
11/11/09 11:26 AM
Challenger 1
Cincinnati, Ohio
I've never saw a Renagade product that I liked.
[Re: MR_P_BODY]
#523088
11/11/09 11:31 AM
11/11/09 11:31 AM
#523089
11/11/09 11:35 AM
11/11/09 11:35 AM
Al_Alguire
Las Vegas
No duallie here, well I still have one. However we have purchased an adequate tow rig for the job. Now looking at ways to get two cars to the track together.
[Re: Al_Alguire]
#523090
11/11/09 11:44 AM
11/11/09 11:44 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
T&E None Better
Rickster
[Re: rickstershemi]
#523091
11/11/09 12:05 PM
11/11/09 12:05 PM
Challenger 1
Cincinnati, Ohio
T&E None Better
Rickster
One of the best for sure, Gold Rush and Champion are right up there too.
[Re: 40ford]
#523093
11/11/09 01:25 PM
11/11/09 01:25 PM
Challenger 1
Cincinnati, Ohio
Seems like I find more things to say----There are two basic way that trailers are assembled:
1. The base is welded together, then the sides and roof are usually riveted to the base. Using this method, all the stresses are on the base and the sides aren't really "load bearing". This requires a much heavier base frame---more weight.
2. The base and sides are "load bearing" and are welded as a unit. The top is usually welded on as a unit as well. This results in a lighter trailer with the same load bearing strength. It also produces less flex going down the highway.
Gold Rush, All welded aluminum.
[Re: Challenger 1]
#523094
11/11/09 02:58 PM
11/11/09 02:58 PM
Posts: 3,746 Riverside, California
Lil Demon
Al - a few things: 1) Happy Birthday 2) Two cars to the track at the same time? Hmmm... 3) If Mazzolini has one for sale - I'm in riverside right now and can swing by and take a look at it. Let me know.
