hurst 4 speed shifter #522835
11/10/09 08:07 PM
11/10/09 08:07 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
anyone have good diirections on rebuilding the shifter mechanism?
68 Satellite Wagon and a few other ones
Re: hurst 4 speed shifter [Re: mro] #522836
11/10/09 08:18 PM
11/10/09 08:18 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
1) take it apart
2) clean all the parts
3) grease all the parts
4) put it back together
Re: hurst 4 speed shifter [Re: Stanton] #522837
11/10/09 09:09 PM
11/10/09 09:09 PM
duster408 Offline
duster408  Offline
do you need a pistol grip?
Re: hurst 4 speed shifter [Re: duster408] #522838
11/10/09 11:01 PM
11/10/09 11:01 PM
wisconsin
swifter Offline
swifter  Offline
wisconsin
Send it to Jamie passon-Passon Performance and be done with it
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: hurst 4 speed shifter [Re: Stanton] #522839
11/11/09 08:48 AM
11/11/09 08:48 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
1) take it apart
it's not as hard as it looks , just pay attention to the direction and order the pieces come out , maybe take pictures for reference , you can put it together incorrectly if you put your mind to it
Re: hurst 4 speed shifter [Re: JohnRR] #522840
11/11/09 01:13 PM
11/11/09 01:13 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The above directions are spot on, but one thing you may see is wear on the gate selector where it contacts the reverse detent. If you see excessive wear turn the selector over and reuse UNLESS there is also excessive wear on the other side of the selector and then you will need a replacement and it might be time to send it to Hurst.
Re: hurst 4 speed shifter [Re: mro] #522841
11/11/09 03:40 PM
11/11/09 03:40 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
I tried this about 4 years ago and it didn't work any better afterwords. I think having a shifter rebuilt costs more than you can buy a brand new one for. Unless you're trying to retain a 100% original car, buy a new one. I bought a new Hurst Comp. Plus from Jegs for $150, then a new pistol grip handle from Brewers for $170. From the prices I've seen, the total of those 2 is not much more than having an original rebuilt, and the benefits are a new shifter. Just my 1.5 cents worth.
Jeff Adams 64 426 Polara
