tti's leak #522681
11/10/09 06:18 PM
11/10/09 06:18 PM
albemarle, NC
dusterbd13 Offline OP
albemarle, NC
and theyre annoying me.
setup is the fully coated and polished tti step headres for a body, bolted to indybrock heads with stage 8 locking header bolts.
both the collectors and head flanges are leaking. i purchased some copper gaskets from summit for replacement.
what install practices for the copper?
rtv?
torque spec?
tightening pattern?
other suggestions?
this is the third set in 2 years and 2000 miles. im starting to get annoyed.
michael
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: tti's leak [Re: dusterbd13] #522682
11/10/09 06:40 PM
11/10/09 06:40 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I've never had any luck with copper header gaskets.
There's a member that's selling what he claims are the last header gaskets you'll ever buy. I forget which section it's in. Probably the race parts for sale.
IRRC the ones I'm using now are Hooker's.
My memory aint what it used to be
Re: tti's leak [Re: WILD BILL] #522683
11/10/09 06:46 PM
11/10/09 06:46 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: tti's leak [Re: WILD BILL] #522684
11/10/09 06:47 PM
11/10/09 06:47 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Copper header gaskets???
Garbage in my books.
Use like Bill said, and maybe even treat each side to a skim of Ultra Copper RTV sealant.
I've never had a leak doing this, and FWIW, I am still using the header flange gaskets that came with my TTI's 3 years ago, and they have been off at least 4 times!!
Re: tti's leak [Re: superwrench] #522685
11/10/09 06:55 PM
11/10/09 06:55 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
With the Remflex mentioned above,you need nothing else and you don't have to fool around with sealers. :twocents
Re: tti's leak [Re: 62maxwgn] #522686
11/10/09 07:01 PM
11/10/09 07:01 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
Remflex gaskets, and your done!
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: tti's leak [Re: 62maxwgn] #522687
11/10/09 07:02 PM
11/10/09 07:02 PM
superwrench Offline
superwrench  Offline
Yes, with a Remflex no sealer....but if using the traditional types like Felpro, Hooker, or Mr.Gasket, the RTV is a saviour.
Re: tti's leak [Re: superwrench] #522688
11/10/09 07:07 PM
11/10/09 07:07 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
With the proper thickness and annealing, copper gaskets are FAR superior to anything out there. I have used plenty of copper gaskets and still use them in some cases. There are plenty of cheap copper gaskets out there without the proper annealing.
I have two sets of TTIs. My set for my 440 leaked where the tube was welded to the flange. I changed out the first set of gaskets before I figured it out.
The second time I had the header off I welded it up and put the original gaskets back on. All is good now, but is was a big pain in the azz until I fiquired it out.
I did post here about my trouble after I replaced the gasket the first time and that did not fix it. Was told to use a small diameter tubing as a machanics stefoscope. It worked and I could hear exhaust leak between the tubes not around the gasket.
I have some pictures of my repair if I can find it. I'm on a old slow computer at work and photobucket is real slow going on this computer.
In all fairness to TTI, before you jump to conclusitions that TTI are junk.
When I first started this motor it did not have enough timing and within the first minute or two of run time the headers were glowing. I bumped up the timing while it was running and turned down the idle, but the damage was more than likely done the first 2 minutes of run time.
Something to think about. MY
Re: tti's leak [Re: dusterbd13] #522689
11/10/09 11:32 PM
11/10/09 11:32 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I am using the remflex with no problems. Also, if you've over tightened the headers, they may have warped, which could have caused them to start leaking.
Re: tti's leak [Re: jbc426] #522690
11/11/09 12:21 AM
11/11/09 12:21 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
TTI flanges are pretty thick so I can't see them warping like hedmans or other headers with thin flanges.
I would recommend using copper rtv with copper gaskets. This setup is reusable forever so long as you thoroughly clean everything each time it comes apart.
I tried a set of copper gaskets without sealer years ago and I'm sure I would have pulled the threads out of the cylinder head before those things squashed and sealed like they were advertised. I wouldn't even attemp to install a dry set every again.
Re: tti's leak [Re: dusterbd13] #522691
11/12/09 02:07 AM
11/12/09 02:07 AM
Canada
Mofopar Offline
Mofopar  Offline
Canada
Remflex seal up good but be careful with them as they will crack easily if you bend them. Having said that, they sent me a new set no charge after I cracked one opening up the packaging.
That and they seem to be reusable. I pulled off the header and it was pretty tough to get the gasket off in with a scraper let alone re-use it.
My pro parts flanges are too warped to use copper.
Re: tti's leak [Re: Neil] #522692
11/12/09 02:11 AM
11/12/09 02:11 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Next time anneal the copper gaskets before you use them & you'll be suprised how soft they are...
Re: tti's leak [Re: 1_WILD_RT] #522693
11/12/09 08:33 AM
11/12/09 08:33 AM
albemarle, NC
albemarle, NC
how would you go about annealing them?
Re: tti's leak [Re: dusterbd13] #522694
11/12/09 11:54 AM
11/12/09 11:54 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I was having problems with leaking headers. Tried three different gaskets. Still leaking. Guy at the performance shop said to try Remflex gaskets. Been running them now for a few years with no leaks.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: tti's leak [Re: Junky] #522695
11/13/09 02:14 AM
11/13/09 02:14 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I bet your question got answered at FABO
likely the flange sealing bead in the wrong spot.
