How much paint? #519555
11/08/09 02:28 PM
11/08/09 02:28 PM
Lost in Pooler, GA
Gumbydammit Offline OP
Lost in Pooler, GA
68 dart - complete repaint. Engine compartment, door jambs, trunk, body, 2 hoods. Base/clear. Going with a honda Silver. About how much paint/clear do I need? Any suggestions on a brand for a novice?
OR
How much to do engine compartment, door jambs, trunk, and then let a body shop do the rest?
Anyone in the Savannah, GA area want to paint a car?
I'm Gumby dammit!
Re: How much paint? [Re: Gumbydammit] #519556
11/08/09 06:01 PM
11/08/09 06:01 PM
Az
Crizila Offline
Crizila  Offline
Az
Single stage enamel, 1 quart to do the eng. compt, jams, etc, and 1 gallon to do the body and any insidentals.
Fastest 300
Re: How much paint? [Re: Gumbydammit] #519557
11/08/09 06:37 PM
11/08/09 06:37 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
68 dart - complete repaint. Any suggestions on a brand for a novice?
Check this website out: http://autobody101.com/forums/index.php
There is tons of information on everything from air compressor requirements, spray gun and paint recommendations, as well as sanding materials and techniques. From body work to cut and buff.
Most would recommend a base coat clear coat for a novice painter. Single stages take a little more finesse/experience to apply properly.
As for products that are user friendly - RM Diamont for base coat and SPI for primers and clears.
Re: How much paint? [Re: 68CoronetRT] #519558
11/08/09 07:23 PM
11/08/09 07:23 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
My advice would be to get 2 gallons of base and mix them together in a 5 gallon bucket.
Re: How much paint? [Re: Gumbydammit] #519559
11/08/09 07:29 PM
11/08/09 07:29 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Cheaper brands of paint don't cover as well. What brand of paint are you planning on using? Lotsa variables that need answering.
