Page 11 of 18 1 2 9 10 11 12 13 17 18
Re: Jake's Challenger/Rust [Re: jake71] #519405
01/09/10 11:44 AM
01/09/10 11:44 AM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
I cleaned it all out and treated the metal. Got started on the patch which I had to make from three pieces due to the complex shape. Even 16 gauge metal was no problem for the shrinker!
Re: Jake's Challenger/Rust [Re: jake71] #519406
01/09/10 11:46 AM
01/09/10 11:46 AM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
Another piece of the puzzle.
Re: Jake's Challenger/Rust [Re: jake71] #519407
01/09/10 11:47 AM
01/09/10 11:47 AM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
Little bit of smooting with the Roloc disc and not too bad.
Re: Jake's Challenger/Rust [Re: jake71] #519408
01/09/10 11:48 AM
01/09/10 11:48 AM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
Different angle.
Re: Jake's Challenger/Rust [Re: jake71] #519409
01/09/10 11:51 AM
01/09/10 11:51 AM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
There were a few more patches made but you pretty much get the picture.
Removed all the rust with the wire wheel and treated with POR15.
Re: Jake's Challenger/Rust [Re: jake71] #519410
01/09/10 11:56 AM
01/09/10 11:56 AM
Jake
the work you are doing is simply awesome.
Re: Jake's Challenger/Rust [Re: jake71] #519411
01/09/10 12:01 PM
01/09/10 12:01 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
After all my experiences with the after market panels, this was a nervous point. Test fit the AMD skin and was pleasantly surprised that with minimal massaging, it fit!
The only problem was that I had no clue what to use for bonding it to the center roof support. Off to Ed's Auto Paint to find out.
We came up with SEM #39977. It's called panel vibration control material. It has about 45 to 60 minutes working time so you can get things all lined up and stays somewhat pliable. It's not the same color but I really don't care as long as it does the job.
After many trial runs at setiing the roof in exactly the right position, I applied the SEM product and carefully set the panel in place once and for all. Here's a shot of the adhesive.
Re: Jake's Challenger/Rust [Re: jake71] #519412
01/09/10 12:02 PM
01/09/10 12:02 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
Now to go around and clamp and weld.
Re: Jake's Challenger/Rust [Re: jake71] #519413
01/09/10 12:05 PM
01/09/10 12:05 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
And where it met the quarters was exactly the same amount of screwed up (quarters) as the stock roof. Luckily I had split the quarters to spread them out prior to setting the roof in place.
Re: Jake's Challenger/Rust [Re: jake71] #519414
01/09/10 12:09 PM
01/09/10 12:09 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
All the way through the install, I was impressed with the fit and quality of the AMD panel. It was a nice change of pace.
Well, I'm off to get the door gaps straight. More sectioning of the Goofmark quarters. They are really bad around the door gaps. They get further and closer all the way down the side. Oh well, it's still fun right?
Re: Jake's Challenger/Rust [Re: ] #519415
01/09/10 12:10 PM
01/09/10 12:10 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
Thanks Superfreak, I really am enjoying it.
Re: Jake's Challenger/Rust [Re: jake71] #519416
01/09/10 03:38 PM
01/09/10 03:38 PM
Louisville KY.
redmay Offline
redmay  Offline
Louisville KY.
Jake your doing one hell of a job and the results of your labor will be top notch when you are finished .Keep up the great work and thanks for the pictures .
Re: Jake's Challenger/Rust [Re: redmay] #519417
01/09/10 04:21 PM
01/09/10 04:21 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
Thanks Joe, I sure hope you're right!
Re: Jake's Challenger/Rust [Re: jake71] #519418
01/11/10 01:39 AM
01/11/10 01:39 AM
St. Louis, MO
DodgeMaterial Offline
St. Louis, MO
Jake - Amazing work!
DodgeMaterial - Dave JS29U0B - FK5 - 440-4 Auto WS23V0A - EB5 - 440-6 Auto
Re: Jake's Challenger/Rust [Re: jake71] #519419
01/11/10 10:29 AM
01/11/10 10:29 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
I ran out of poster board for making templates so I ran to the "craft store" and got some more.
ROTFLOL now I know how you keep your nerves in check on this project!
Keep up the good work!
Re: Jake's Challenger/Rust [Re: JS29R0B] #519420
01/12/10 11:54 AM
01/12/10 11:54 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Awesome
Re: Jake's Challenger/Rust [Re: SRT6776] #519421
01/12/10 02:10 PM
01/12/10 02:10 PM
KS
68SportSatvert Offline
KS
Jake,
Truly first class work!!!! What HF spot welding gun did you use? How well did it work? You really inspire me to get mine done. Too bad I'm in Afghanistan until December!!! I'll have to look you up when I get back to Cheyenne. You should have it close to finished by then.
Re: Jake's Challenger/Rust [Re: 68SportSatvert] #519422
01/12/10 08:17 PM
01/12/10 08:17 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
Jake,
It was the 230 volt one but as I said, it didn't make very far before it burned up. The rest of the welding has been done with a mig welder. Do look me up when you get home and I'll share more experiences and money saving tips. Be safe!
Re: Jake's Challenger/Rust [Re: jake71] #519423
01/13/10 12:44 PM
01/13/10 12:44 PM
KS
KS
Thanks!!! I can't wait to see your handy work.
Re: Jake's Challenger/Rust [Re: jake71] #519424
01/13/10 09:10 PM
01/13/10 09:10 PM
Loveland Colorado
jake71 Offline OP
jake71  Offline OP
Loveland Colorado
I'm still having fun. How 'bout you folks?
I did get a bunch of work done on the door gap on the drivers side and have some pics but I haven't put them on the computer yet. I'll put them up soon though.
Anybody know how you're supposed to fill the void where the quarter meets the roof? I don't really want to learn how to lead it in but I don't think filler is OK to do to a void that deep. Suggestions would be greatly appreciated.
Thanks all!
