Re: Drive shaft going back in...but first...
[Re: ashburnmike]
#519172
11/08/09 01:57 PM
11/08/09 01:57 PM
RapidRobert
Hello Michael. I clean the bolts/holes w a shot of starting fluid to clean them (a bit overkill but I'm anal on things) & blue loctite on the bolts & nothing has come undone (yet). I would move the front yoke back & forth thru both planes of travel & check that it move free w NO binding, same w the rear ujoint in one plane of travel back & forth on the shaft. Screw the bolts in 1st to make sure they go in freely so there's no excessive friction/binding from bad thread that will erroneously make you think you have em tight enough when they're not. Snug them up fairly tight & you're good. I put a light smear of wheel bearing grease inside each cap ahead of time and some on the outside of the caps and on the yoke half moon seat and the straps for rust prevention.
[Re: MoparforLife]
#519177
11/08/09 10:05 PM
11/08/09 10:05 PM
Posts: 455 Ashburn, Virginia
ashburnmike
Ashburn, Virginia
Is it an optical illusion or isn't that end cap far enough into the shaft yoke in the top picture. Looks to me to have too much on the outside of the yoke. Remember to have the circlips on all the caps and that they should be on the yoke side of the yoke and not on the clamp side. Any dealer should have clamps. You shouldn't have to order them from a specialty house and pay a premium for them.
here's another (poor quality) picture from a different angle. I will go by a dealer tomorrow and see of they have the straps and bolts.
also,
I was also told the same about the circlips. when I install it make sure the circlips are facing the yoke and not the straps. Why does this matter?
[Re: ashburnmike]
#519178
11/11/09 12:46 PM
11/11/09 12:46 PM
ashburnmike
Ashburn, Virginia
Thanks for all advice on why my drive shaft fell out. I am almost ready to put it back in. The new u-joint is in place on the shaft but upon inspection of the pinion yoke and the straps, they will need to be replaced. The Yoke seems to be fine. When I get the new straps and bolts, what do I not know about putting the shaft back in place? I can't afford anymore roll back rides for my car. thanks Mike
I called year one and they have two versions of these straps....large and small....anyone know which size these would be for an 8 3/4" rear
