How many grooves for 383 A/C crank pulley no pwr steer? #518432
11/07/09 07:25 PM
11/07/09 07:25 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
The A/C crank (belt) pulley I have for my '68 383 Road Runner has four (4) belt grooves but my car doesn't have power steering, is this pulley correct?
Would anyone have a belt and tensioner layout for a '68 383 rr engine with A/C and no power steering. My altenator has a two (2) groove pulley and I thought the crank pulley should only have three (3) grooves (one for the water pump/fan and two for the A/C-Alt), is there a pulley for no power steering or is it just not used when you don't have pwr-str?????? Do I need to find a different A/C pulley TIA.
MikeR
Re: How many grooves for 383 A/C crank pulley no pwr steer? [Re: A12] #518433
11/07/09 08:09 PM
11/07/09 08:09 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
A/C cars with/without power steering used the same 4 groove crank pulley.
Part # 2465326 Used in all B and C body B-block ac equipped cars.
440 engines used a different pulley.
The outside groove is for the water pump.
The next groove is for the power steering.The two inside grooves is for the alternator & A/C compressor
Here is a copy of a factory assembly blueprint:
Hope this helps.
Keep in mind that is with the Chrysler alternator.
There is a three groove alternator pulley with the Leese/Neville alternator.
Which alternator you have???
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: How many grooves for 383 A/C crank pulley no pwr steer? [Re: 68Cbarge] #518434
11/07/09 11:06 PM
11/07/09 11:06 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Hope this helps.
WOW! THANKS! That's great, just what I needed, no that's more than I ever expected
Thanks again.
MikeR
Re: How many grooves for 383 A/C crank pulley no pwr steer? [Re: A12] #518435
11/08/09 12:31 AM
11/08/09 12:31 AM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
You are welcome.
I am in the process of rebuilding my 383 C body and I bought the blueprint copies that make assembly easy.
