Intake height difference. #517803
11/06/09 08:50 PM
11/06/09 08:50 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Hi all.
I have an RPM intake on my RB right now, and may be going to a single plane instead.
Does anyone know the height difference between the RPM, the M1 single plane (4150 base), and the Holley SD?
Any help is greatly appreaciated. BTW, I cannot go any taller than the RPM that's on it now. I'm tapped for space as it is
codfish
Re: Intake height difference. [Re: codfish] #517804
11/06/09 09:27 PM
11/06/09 09:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The RPM is .60 to .70 taller than the SD.
Re: Intake height difference. [Re: BSB67] #517805
11/06/09 10:48 PM
11/06/09 10:48 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is a pic of the Holley Street Dominator on my 63. Ron
Re: Intake height difference. [Re: 383man] #517806
11/06/09 11:06 PM
11/06/09 11:06 PM
UK
602heavy Offline
602heavy  Offline
UK
Ran into this problem a while ago , as said , the M1 is 1/4" taller than the RPM.
Re: Intake height difference. [Re: codfish] #517807
11/06/09 11:27 PM
11/06/09 11:27 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Re: Intake height difference. [Re: RussW] #517808
11/06/09 11:56 PM
11/06/09 11:56 PM
Renton Washington
Triple Threat Offline
Renton Washington
Any decent machinist could mill 1/4" off the top of an intake without trouble or harm to HP.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Intake height difference. [Re: codfish] #517809
11/07/09 12:16 AM
11/07/09 12:16 AM
85086
moparpollack Online penguin-006
Lil Herman
moparpollack  Online Penguin-006
Lil Herman
85086
Does the K-member have spacers yet? Wayne "Big Squeeze" is running them on his car. It's good for an extra inch of clearance. PM him and he'll give you the scoop on the spacers.
Re: Intake height difference. [Re: codfish] #517810
11/07/09 02:00 AM
11/07/09 02:00 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Go with the ported Holley Street Dominator intake.
You will probably still have enough room to run the SD and a 1" tapered spacer... which your RB stroker would appreciate very much.
SD is shorter than the RPM
M1 is Taller than the RPM
Here is some SD porting info from Streetwize:
I generally raise the outside port walls (runners # 1-2-7-8) about 1/4"
higher than the inside (3-4-5-6) runners and I also widen the walls of the
inside runners. Most of the work is in the plenum transition, there's a lot
of "Dead Area" in the roofs as cast. Can't get the camera in there but I go
into the roof about 2", there's a pretty bad dogleg as cast you can feel
with your finger, particularly the #1 and #2 Ports. #7 is a little
trapezoidal (think Gumby's head) with a slightly higher roof on the #5 port
side, this gives 7 a little more fighting room to compensate for the 5-7
firing order at high RPM
Do a search on SD porting or PM streetwize or firefighter3931 for tips.
