trouble with 94 ram, 5.2 pop and back fire..HELP!
#517583
11/06/09 03:47 PM
11/06/09 03:47 PM
Posts: 903 S.E. Minnesota
gtsdude
S.E. Minnesota
My 94 ram with 268,000 miles started pop and backfire. about a year ago plugs, cap, wires, rotor, coil, fuel pump, were replaced. Changed out crank sensor with a good used one, still does same thing. It will idle and rev in park but under load, any throttle past quarter or so and almost to wide open it backfires and pops and wont pull itself. At wide open throttle runs fine and til about quarter throttle. I am thinking throttle position sensor or pickup under distributor cap. Any other ideas before I start buying parts? Ever happen to anyone else?
Re: trouble with 94 ram, 5.2 pop and back fire..HELP!
[Re: gtsdude]
#517590
11/07/09 10:28 AM
11/07/09 10:28 AM
Posts: 601 Clintwood VA
johnedod
Clintwood VA
I'd check the plug wires after dark for cross firing. I know you put a new set on a year ago but some new stuff isn't all that great. Plus it won't cost you anything to look for sparks. Maybe even mist some water on 'em. Might check the cap for carbon tracking too.
Johnedod 68 Road Runner 71 Road Runner 78 Power Wagon
[Re: buildanother]
#517592
11/07/09 02:33 PM
11/07/09 02:33 PM
Posts: 4,872 connecticut
pnypwr
connecticut
id look at the 02s sounds like its shorted to voltage, and the pcm is making it lean
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: gtsdude]
#517594
11/09/09 10:38 AM
11/09/09 10:38 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
if the sparkplug wires were replaced and you didn't follow the directions and pictures in TSB 18-48-98 it is VERY easy to route wires to cylinders 6 and 8 wrong, and this will cause the problems you describe
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
