trouble with 94 ram, 5.2 pop and back fire..HELP! #517583
11/06/09 03:47 PM
11/06/09 03:47 PM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
My 94 ram with 268,000 miles started pop and backfire. about a year ago plugs, cap, wires, rotor, coil, fuel pump, were replaced. Changed out crank sensor with a good used one, still does same thing. It will idle and rev in park but under load, any throttle past quarter or so and almost to wide open it backfires and pops and wont pull itself. At wide open throttle runs fine and til about quarter throttle. I am thinking throttle position sensor or pickup under distributor cap. Any other ideas before I start buying parts? Ever happen to anyone else?
Re: trouble with 94 ram, 5.2 pop and back fire..HELP! [Re: gtsdude] #517584
11/06/09 04:02 PM
11/06/09 04:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What do the codes say?
Re: trouble with 94 ram, 5.2 pop and back fire..HELP! [Re: gtsdude] #517585
11/06/09 04:04 PM
11/06/09 04:04 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
sounds like a valve train problem to me. Worn out cam?
Re: trouble with 94 ram, 5.2 pop and back fire..HELP! [Re: gtsdude] #517586
11/06/09 04:06 PM
11/06/09 04:06 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
did you ever retime the base timing, did you ever replace timing chain? id do those first
MOPAR OR NO CAR
Re: trouble with 94 ram, 5.2 pop and back fire..HELP! [Re: hemigod426] #517587
11/06/09 04:13 PM
11/06/09 04:13 PM
michigan woods
imfixinmopars426 Offline
michigan woods
what ever manifold its backfiring through,intake/exhaust...ck the valvetrain there,bent p/rods,broken springs,valve leakage,ect...or t/chain just jumped. also a comp ck might find the issue too.did you get it hot? valves wont seat after a overheat,and or cracked cyl head.
Re: trouble with 94 ram, 5.2 pop and back fire..HELP! [Re: gtsdude] #517588
11/06/09 04:33 PM
11/06/09 04:33 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
I would try hooking it up to a scanner to find out what's happening before you throw parts at it. Could be a bad O2 sensor. Sometimes the Magnum intake plenum cover gasket can blow out and cause pinging and excessive oil use. It creates a lean condition, so it could probably also cause popping/backfire.
Re: trouble with 94 ram, 5.2 pop and back fire..HELP! [Re: Reggie] #517589
11/06/09 09:29 PM
11/06/09 09:29 PM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
Never got hot, it not only backfires it doesnt run. almost quits til i let off, then it takes off. If i give it just enough gas to drive its fine, give it a little more and it surges, then a little more and backfires and pops, put it to the floor and it takes off like nothing is wrong, revs up to 5500.
Re: trouble with 94 ram, 5.2 pop and back fire..HELP! [Re: gtsdude] #517590
11/07/09 10:28 AM
11/07/09 10:28 AM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
I'd check the plug wires after dark for cross firing. I know you put a new set on a year ago but some new stuff isn't all that great. Plus it won't cost you anything to look for sparks. Maybe even mist some water on 'em. Might check the cap for carbon tracking too.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: trouble with 94 ram, 5.2 pop and back fire..HELP! [Re: gtsdude] #517591
11/07/09 11:45 AM
11/07/09 11:45 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Are you positive of good fuel pressure and flow?
Re: trouble with 94 ram, 5.2 pop and back fire..HELP! [Re: buildanother] #517592
11/07/09 02:33 PM
11/07/09 02:33 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
id look at the 02s sounds like its shorted to voltage, and the pcm is making it lean
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: trouble with 94 ram, 5.2 pop and back fire..HELP! [Re: pnypwr] #517593
11/08/09 04:53 PM
11/08/09 04:53 PM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
I checked fuel pressure, had 45psi, not sure on flow itself, how do i check voltage on 02 sensors?
Re: trouble with 94 ram, 5.2 pop and back fire..HELP! [Re: gtsdude] #517594
11/09/09 10:38 AM
11/09/09 10:38 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
if the sparkplug wires were replaced
and you didn't follow the directions and pictures in TSB 18-48-98
it is VERY easy to route wires to cylinders 6 and 8 wrong,
and this will cause the problems you describe
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
