02 Sensor location on turbo tube #517566
11/06/09 03:21 PM
11/06/09 03:21 PM
Tucson AZ
2
2cudabuck Offline OP
Tucson AZ
Any guidelines on where I should or should not put my wideband o2 sensor before my turbo? I was planning on putting it right in the "Y" where the two banks come together. This would put it about 16" before the turbo. Sound okay??
Buck 67 273 Dart GT 69 RT 440 Charger (SWEET!) 70 318 Cuda 74 Cuda Packin a 426 roller Hemi
Re: 02 Sensor location on turbo tube [Re: 2cudabuck] #517567
11/07/09 08:35 PM
11/07/09 08:35 PM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
It must go after the turbo,the backpresure between the engine and turbo will cause it to fail
Re: 02 Sensor location on turbo tube [Re: bigslant6fan] #517568
11/08/09 04:22 AM
11/08/09 04:22 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
post turbo only....
Re: 02 Sensor location on turbo tube [Re: CokeBottleKid] #517569
11/08/09 09:12 PM
11/08/09 09:12 PM
Tucson AZ
2
Tucson AZ
I'll make it so number one! Thanks! The heat rom the turbo won't effect the reading eh? Thanks again guys,
Re: 02 Sensor location on turbo tube [Re: 2cudabuck] #517570
11/08/09 09:49 PM
11/08/09 09:49 PM
Detroit, MI
Detroit, MI
Pre-turbo is much hotter than post. Basic thermodynamics, the turbine takes energy from the exhaust (heat, P-V work etc) and converts it to rotational work.
