K-member advice #517502
11/06/09 12:52 PM
11/06/09 12:52 PM
Somewhere Over the Hill
Mr. Dodge Offline OP
Hey guys
I need some advise on what K-member I should buy for My 69 Coronet R/T. I have the stock K-member in the car now and im wondering if I should beef up the stock K-frame or should I upgrade to the C.A.P one or the Alter-K-tion????
The engine is 588cid Hemi.
Unfortunately the car wont see as much drag time as I would like to closest drag strip is Mission in Canada
What's your recommendations, anything is appreciated
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison) 69 Hemi Coronet R/T 70 456 Dart Swinger
Re: K-member advive [Re: Mr. Dodge] #517503
11/06/09 01:07 PM
11/06/09 01:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what are you going to do with the car ??? autocross ?? just cruise around ??
Re: K-member advive [Re: Mr. Dodge] #517504
11/06/09 01:09 PM
11/06/09 01:09 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
my friend has a alter-K ation in his 70 roadrunner in his car. really nice piece.
Re: K-member advive [Re: JohnRR] #517505
11/06/09 01:24 PM
11/06/09 01:24 PM
Drag the car when I get a chance but mostly cruse it. Mission is roughly 1.5 hrs from me and Pacific is 2.5 so I can run her.
Re: K-member advive [Re: Mr. Dodge] #517506
11/06/09 04:40 PM
11/06/09 04:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you want to spend money you could replace it , or if you want to get more room for headers , feel like you want to upgrade to rack and pinion , otherwise I wouldn't bother .
Re: K-member advive [Re: JohnRR] #517507
11/06/09 05:17 PM
11/06/09 05:17 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Send the stock Kmember to Bobspro fab he will make the old one good as new and give you more room up front with his improvments
Re: K-member advive [Re: scottb] #517508
11/06/09 07:01 PM
11/06/09 07:01 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
www.bobsprofab.com
Bob sells a nice tubular K frame made from 4130 chromemoly or he does a nice slice and dice job on the stock K like the SS/AH cars.
Both take alot of weight off the front and add lotsa clearance for headers.
Re: K-member advive [Re: 340RICK] #517509
11/06/09 08:12 PM
11/06/09 08:12 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Alterkation supports the upper shock mount so you can use it on the street without adding anything
If its mostly a street car, that might be your best bet ..
Race car ,,, Bobs stuff all looks great
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: K-member advive [Re: 340RICK] #517510
11/06/09 08:13 PM
11/06/09 08:13 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
If you have a cage, I would use a motor plate and cut the mounts off of the stock k-member. rebuild the steering box. The stock steering is good for a cruising car. I have never had problems with the stock suspension or steering. I am using a stock'ish k-member on my car
Re: K-member advive [Re: Defbob] #517511
11/07/09 09:52 PM
11/07/09 09:52 PM
Cool guys THANKS a million
I think im gonna give Bill a call about the Alter-K-tion. I like the Idea of re-enforcing the shock towers.
Re: K-member advive [Re: Defbob] #517512
11/08/09 11:23 AM
11/08/09 11:23 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
That is what I did. Originally I was going to use the motor mount but went to a motorplate, Otherwise the k-frame would be modified differently.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: K-member advive [Re: Kam*Kuda] #517513
11/09/09 12:57 PM
11/09/09 12:57 PM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
AlterKtion was the single BEST thing I've ever added to my car! Can not go wrong with it.
Re: K-member advive [Re: silverfish] #517514
11/09/09 01:19 PM
11/09/09 01:19 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Alterkation, well worth every penny I spent
Re: K-member advive [Re: B1KILLER] #517515
11/09/09 11:47 PM
11/09/09 11:47 PM
How do you like the Rack and pinion ??? How awkward is the steering???
