Page 5 of 7 1 2 3 4 5 6 7
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: theclutcher] #517380
11/11/09 12:33 PM
11/11/09 12:33 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
I like option #3...the .66 would be nice with my 4:10's and small polyglas tires on the street but it would be nice to see a 2:95-3:05 1'st gear for a more controlled launch with slicks. That would be the best of both worlds.
I really do like the close ratio's of my 23 spline and if that can remain with just a little more 1'st gear grunt it would be all I could ask for.
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: JamiePasson] #517381
11/11/09 03:00 PM
11/11/09 03:00 PM
Clinton Twp. MI.
ChargerDude70 Offline
super street
super street
Clinton Twp. MI.
"We are possibly considering a different 1st gear ratio as well, but it is likely that we necessitate changing 2nd and 3rd as well to accomodate. I am not sure about that yet."
A "gear-set" that was set up for drag racing(ish) and having that OD for the cruise home would be nice. I personally have a 3rd gen hemi in my car and Chyrsler put 3.59 first gear in the NAG trans to help the car out of the hole then has a .67 for 5th. Allows us to put 3:23 or 3:55 in rear and have best of both worlds. Just my
DODGE...Devistation On Driving Grounds Everywhere 69 Dart Swinger 6.1 Hemi 4-Spd 70 Charger R/T B3/B5 6.1 Hemi Auto 76 Coronet 2008 H.D. Street Glide Aniversary Model 821 of 3000 2011 Challenger R/T T.O. 6spd
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: ChargerDude70] #517382
11/11/09 08:05 PM
11/11/09 08:05 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Jamie have you contacted Long for a shifter yet or can we use the current 5-speed Hurst unit on the market now? I also like the 1.1 fifth concept like my Richmond with a 3.27 low gear.The 3.54 rear gear with that low gear works pretty well for my 3500# car with the 493 The #2 choice with a 4.10 gear would work well also You need to have a good mechanical advantage to keep the clutch from glazing on the launch.
Gus
64 Plymouth Savoy
Dana 60
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: fourgearsavoy] #517383
11/11/09 10:15 PM
11/11/09 10:15 PM
Sugarloaf, PA. USA
JamiePasson Offline
JamiePasson  Offline
Sugarloaf, PA. USA
Gus,
In keeping with the true bolt in deal. In other words being open and up front as far as costs go, the transmission will include a shifter and linkage. If we didn't do that, we wouldn't be any better than the "other" guys out there because you would need another $400+ dollars worth of shifter and linkage to be able to use the trans. It will be a HURST style shifter. Long makes good stuff, but it just isn't gonna fit where it needs to.
A note to everyone. Making a .85 OD ratio in my opinion is a waste of time. Our current OD Hemi 4 speed gearset has a .80 and I have heard people saying that it isn't enough overdrive. So, I can tell you that is out. I am on the fence about making a 3.2 first gear. That is PRETTY steep. If we make a steeper 1st gear, I am thinking something in the 2.9's.
As for Quadrini, I'll never tell.
Thanks,
Jamie
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: JamiePasson] #517384
11/11/09 11:43 PM
11/11/09 11:43 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Gus,
Thanks,
Jamie
the .8 of the 4 speed isn't steep enough only because first isn't steep enough
check out the A580 tranny ratios in the LX's....mid 3.59 for first, and IIRC, a .83 OD, coupled with a 2.82 rear, has the same gear multiplication as a 2.64 first and 3.83 rear, and the final drive of a 3.54 with a .66 OD.....to me, the big thing is this strategy keeps the driveshaft RPM down. for instance, for a 27" tall tire at 120 MPH, that's 1495 RPM at the wheel. using a 4.10 gear and .66 OD make the driveshaft RPM 6130 RPM, with the engine at 4050 RPM. a deep first/1:1 OD with a 2.71 rear has both the driveshaft and engine spinning 4050 RPM at the same speed....
the crown victoria police interceptors are actually electronically limited to 125 MPH because of driveshaft RPM....
2017 Grand Cherokee Overland
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: JohnRR] #517385
11/12/09 06:34 AM
11/12/09 06:34 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
With that release date i'm assuming Tom Quad has already tested one in his killer AAR ???
I am waiting for the call to show up with my car for the transplant...yes the product will be torture tested...I can't wait... Road racing just got better.
Thanks Jamie!
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: JamiePasson] #517386
11/12/09 08:20 AM
11/12/09 08:20 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Good luck with the new venture. Looks like a nice product.
MB
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: HPMike] #517387
11/17/09 08:45 PM
11/17/09 08:45 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
This is incredible news.Ive been driving my 6speed WS6 Trans Am all summer while getting my 66 satellite put together.Yesterday is the first day I have had my 66 running, driving,and insured and I spent a good part of the day cruising around in it.The first thing that came to mind while driving the satellite was ,"man I sure wish I had another gear or 2 for the highway".
I cant wait for the passon 5 speed,its exactly what we all have been wanting,especially with the .66 overdrive.
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: LAR_414] #517388
11/19/09 04:05 AM
11/19/09 04:05 AM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
If this McLeod 5spd comes out at around $2300, I might just have to pick one up............
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: JamiePasson] #517389
11/20/09 12:16 PM
11/20/09 12:16 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
2.93 is a nice ratio.
a red stripe set with a 2.93 1st and an od for fifth...
then a race only spread with 1-1 fifth.
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: 67autocross] #517390
12/25/09 03:56 PM
12/25/09 03:56 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
This should be great! And as far as pricing if I buy a part and it fits and works like it should I'm happy. A $3500 part that I have to spend months working out the bugs on is not half as good (to me) as say a $4500 part that works right out of the box.
And for me a $4500 trans would be out of the question as would be the same for alot of realistic budget based Mopar hotrodders.
Kudos to Passon for stepping up to the plate in developing a drop in trans for the Mopar community and the cherry on top would be that it is made in the USA but....if the pricing isnt there then for most it will not be a option.
This is only my opinion and I consider myself your average mopar hobbyist.
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: Blakcharger440] #517391
12/26/09 02:24 AM
12/26/09 02:24 AM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
For me it is going to come down to the TOTAL cost, because I want to convert from automatic. But the cost of a Keisler conversion is in the $4500-$5000 range and what stops me from doing that is the thought of hacking up the torsion bar x-member, and the fear that after all is said and done it won't line up right.
If Jamie builds a true bolt in kit for A-bodies, and the price for a conversion is comparable to the Keisler I will buy one.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: MadMatt] #517392
12/26/09 12:51 PM
12/26/09 12:51 PM
Rittman Ohio
Rittman Ohio
The BEST part of Jamie's trans is that you don't need any special custom parts to install it
Everything you need can be had from the Moparts community in good used form such as bell,flywheel,fork,Z-bar etc...
The keisler unit needs some custom parts that only they manufacture.When you do that then you have a baztard-Frankenstein unit that they only supply parts for.
Gus
64 Plymouth Savoy
Dana 60
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: fourgearsavoy] #517393
12/26/09 01:14 PM
12/26/09 01:14 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i cant wait for theese od trans to come out.all four of my cars have 4 speed in them.if they work out good,i'll buy one for every car.i use race gas in all of them,i bet money saved in gas and engine wear,will pay for the trans.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: fourgearsavoy] #517394
12/26/09 03:05 PM
12/26/09 03:05 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
X2
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: ScottSmith_Harms] #517395
01/10/10 08:37 PM
01/10/10 08:37 PM
Orlando Florida
blown572dart Offline
Orlando Florida
X2
X3
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: blown572dart] #517396
01/10/10 09:22 PM
01/10/10 09:22 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
X4
well I know someone who would...
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: Blakcharger440] #517397
01/10/10 10:08 PM
01/10/10 10:08 PM
Toronto
mshred Offline
mshred  Offline
Toronto
x2
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: mshred] #517398
02/22/10 01:10 AM
02/22/10 01:10 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
ill be watching this topic,,
im in need of a 5 speed box with a steep 1st gear and a nice OD,, i run a 33 inch trall tire,,,and drive to a lot of cruise nite,,, i justy removed a 4;56 and put in a 3;91..
with the correct gear selection,,and a 5 speed i could have just as good off the line performance and cruiseablitly,,,a stock 1st gear wont work in my application,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: JamiePasson] #517399
02/22/10 01:20 AM
02/22/10 01:20 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I have three gear ratio options. The difference is the 5th gear ratio.
Any hope for a 6 speed?
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
