SB Strokers and 950 carbs??? #516688
11/05/09 02:04 PM
11/05/09 02:04 PM
owt west
Thread Ender1 Offline OP
owt west
Im in the process of doing a 410" SB and have most of the parts, i will be picking the heads up tommorow with flow figures the only drawback is the are the RhS 360 X heads with the max valve lift flaw. Im only going to be running approx .550" and unsure of what duration figures. I think its going to be maybe a stock elim profile. I could list more details.
The question is it seems these 4" strokers work well with a 950 carb, will that be the case for my combo.
Re: SB Strokers and 950 carbs??? [Re: Thread Ender1] #516689
11/05/09 02:13 PM
11/05/09 02:13 PM
AndyF Offline
AndyF  Offline
Depends on the application. Are you talking about a 950HP type of carb? Those are usually 750 main bodies with the choke housing removed. They are nice carbs but the venturi is smaller than a 850 DP. That might be exactly what you need or it might not, depends on the application.
I'm going to use a 650 HP on my SB stroker. This motor is 427 inches with Hughes Stage III ported heads. Bigger isn't always better and all of that you know.
Re: SB Strokers and 950 carbs??? [Re: AndyF] #516690
11/05/09 02:15 PM
11/05/09 02:15 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
How bout an 825 demon
Re: SB Strokers and 950 carbs??? [Re: AndyF] #516691
11/05/09 02:26 PM
11/05/09 02:26 PM
owt west
owt west
I was meaning the holley 950 hp, I know i know, thats what the guy who is doing the heads said also. i will post cam specs and head figures tommorow, just thought id ask, because i hope to get this project going soon.
Re: SB Strokers and 950 carbs??? [Re: AndyF] #516692
11/05/09 02:32 PM
11/05/09 02:32 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Holley list 80675 ( 750 ultra hp ) has a venturi size of 1.376" with a throttle bore of 1.688"
Holley list 80676 ( 950 ultra hp )has a venturi size of 1.376 with a throttle bore of 1.750"
While the main bodies are the same ( ie the venturi size) the baseplate is larger resulting in more overall CFM flow.
This is one area where a dyno will not accurately tell you what your car will do on the track, you are not launching the car onthe dyno, where one carb will pull the number on the dyno, that same carb might be a pig onthe car at the track.
In testing, most have found the more carb you throw at a small block stroker the happier they are!
My tests have backed that up with small block stock strokes, strokers, and big block strokers.
Re: SB Strokers and 950 carbs??? [Re: DJVCuda] #516693
11/05/09 03:11 PM
11/05/09 03:11 PM
Renton Washington
Triple Threat Offline
Renton Washington
If the main body is the same, couldn't a guy just get a 950 base plate and convert his from 750 to 950 specs? Metering blocks different?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: SB Strokers and 950 carbs??? [Re: Triple Threat] #516694
11/05/09 04:05 PM
11/05/09 04:05 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I would bet a pretty darn good amount of money that stroker mentioned above with a decent sized cam will continue to ET better with each increase in carb size from 650 to 750 to 950, and perhaps even beyond in size, depending on a couple of other factors.It will easily run its worst ON THE TRACK with the 650.
Zero doubt about it.
I have ( in a single day) track tested a pro systems 750, pro systems 1000, race demon 1025 and a 1100 pro systems dominator on a eddie headed 416 without a ton of compression( 12 to 1 ish)...the fastest two carbs were the 1025 rs race demon and the dominator, and it wasnt even close.The 1025 being 8 hundreds better than patricks 1000 hp surprised me a little.
Thanks to Patrick for allowing me to use the carbs, i bought the dominator and still have it, and sold the 1025 a short while later on Moparts.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: SB Strokers and 950 carbs??? [Re: B3422W5] #516695
11/05/09 08:36 PM
11/05/09 08:36 PM
Essex, Ont., Canada
Fishmarket Offline
Fishmarket  Offline
Essex, Ont., Canada
How does the 950 compare to the 850 having a larger venturi and what could you expect with these carbs on the street?
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: SB Strokers and 950 carbs??? [Re: Fishmarket] #516696
11/05/09 09:08 PM
11/05/09 09:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Smaller carbs have a faster reaction on the street
(better throttle response) but lack on top end almost
every time... RPM has a big factor on the size of
the carb... I run a 1050 dom on a 405ci but turn it
8200... if I had a bigger carb I'd run that
Re: SB Strokers and 950 carbs??? [Re: MR_P_BODY] #516697
11/06/09 08:12 PM
11/06/09 08:12 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
I had holley 950 HP alky i think thier now .Finally had it flowed 722 cfm wet benched .Had a 950 aresol billet built By C&S
Try 850 to 1050 as most said 850 is bigger .
Don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: SB Strokers and 950 carbs??? [Re: 10 o to go] #516698
11/06/09 08:53 PM
11/06/09 08:53 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We ran a 950 hp on a w5 headed 414, went to a 1050 dom and picked up a half second, major difference in top end performance,Have a bg 1000 that works good also,
Re: SB Strokers and 950 carbs??? [Re: Thread Ender1] #516699
11/06/09 09:37 PM
11/06/09 09:37 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Speaking of Holleys size, where does the 830 downleg HP fit?
Re: SB Strokers and 950 carbs??? [Re: HotRodDave] #516700
11/06/09 09:51 PM
11/06/09 09:51 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm running a 750 annular booster mighty demon on my 408 - 11.2:1, big hydraulic (256 and a little over .600 lift). Runs good, but I'm wondering if a bigger carb would help? Heavy automatic car.
Fastest 300
Re: SB Strokers and 950 carbs??? [Re: B3422W5] #516701
11/07/09 08:28 AM
11/07/09 08:28 AM
ccarson Offline
ccarson  Offline
I have pro systems 4150 based 1000s, I wish I would have bought one of his Dominator's
for my 420" W9, especially when i saw the size of the wilson spacer we decided to put on the intake.
Re: SB Strokers and 950 carbs??? [Re: B3422W5] #516702
11/07/09 04:42 PM
11/07/09 04:42 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not putting words in anyones mouth, but I think the SB stroker AndyF is mentioning is for a road race application, and crisp throttle response is therefore highly valued, and since I am building an almost identical SB Stroker motor and application, I am leaning towards a 750? since we are usually traction limited and most passing takes pplace at the top end.
Re: SB Strokers and 950 carbs??? [Re: jcc] #516703
11/07/09 06:15 PM
11/07/09 06:15 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I run a 1050 race demon RS on my 408 Indy head pump gas street strip Dart sport. I change the boosters from downleg to annular on the street which actually changes the carb to a 950. It runs really nice on the street & has exellent throttle response for a 260/266 @.50 solid roller. It has gone 9.87 at 136 with the downleg boosters in. I have not run it at the track with the annulars but I think the motor is alot smoother with them, has way better tip in & it does not give up much power.
Re: SB Strokers and 950 carbs??? [Re: b1dartsport] #516704
11/07/09 06:32 PM
11/07/09 06:32 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
The annular boosters are very responsive compared to the down legs, may be the ticket in a road race rig or street rig
Re: SB Strokers and 950 carbs??? [Re: jcc] #516705
11/08/09 02:28 AM
11/08/09 02:28 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
if traction is limited, would not a larger carb to soften the lower speed hit not be a positive? It'd hit the tires less and you'd have more top end charge. Just a thought.
Re: SB Strokers and 950 carbs??? [Re: dodgeboy11] #516706
11/08/09 09:11 AM
11/08/09 09:11 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
the testing i have shows a better incremental all around from larger carbs - from 60' on -
