Re: SB Strokers and 950 carbs???
[Re: AndyF]
#516691
11/05/09 02:26 PM
11/05/09 02:26 PM
Posts: 2,679 owt west
Thread Ender1
owt west
Depends on the application. Are you talking about a 950HP type of carb? Those are usually 750 main bodies with the choke housing removed. They are nice carbs but the venturi is smaller than a 850 DP. That might be exactly what you need or it might not, depends on the application.
I'm going to use a 650 HP on my SB stroker. This motor is 427 inches with Hughes Stage III ported heads. Bigger isn't always better and all of that you know.
I was meaning the holley 950 hp, I know i know, thats what the guy who is doing the heads said also. i will post cam specs and head figures tommorow, just thought id ask, because i hope to get this project going soon.
[Re: DJVCuda]
#516693
11/05/09 03:11 PM
11/05/09 03:11 PM
Triple Threat
Renton Washington
If the main body is the same, couldn't a guy just get a 950 base plate and convert his from 750 to 950 specs? Metering blocks different?
[Re: Triple Threat]
#516694
11/05/09 04:05 PM
11/05/09 04:05 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
I would bet a pretty darn good amount of money that stroker mentioned above with a decent sized cam will continue to ET better with each increase in carb size from 650 to 750 to 950, and perhaps even beyond in size, depending on a couple of other factors.It will easily run its worst ON THE TRACK with the 650.
Zero doubt about it.
I have ( in a single day) track tested a pro systems 750, pro systems 1000, race demon 1025 and a 1100 pro systems dominator on a eddie headed 416 without a ton of compression( 12 to 1 ish)...the fastest two carbs were the 1025 rs race demon and the dominator, and it wasnt even close.The 1025 being 8 hundreds better than patricks 1000 hp surprised me a little.
Thanks to Patrick for allowing me to use the carbs, i bought the dominator and still have it, and sold the 1025 a short while later on Moparts.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#516695
11/05/09 08:36 PM
11/05/09 08:36 PM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
How does the 950 compare to the 850 having a larger venturi and what could you expect with these carbs on the street?
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
[Re: Fishmarket]
#516696
11/05/09 09:08 PM
11/05/09 09:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Smaller carbs have a faster reaction on the street (better throttle response) but lack on top end almost every time... RPM has a big factor on the size of the carb... I run a 1050 dom on a 405ci but turn it 8200... if I had a bigger carb I'd run that
[Re: MR_P_BODY]
#516697
11/06/09 08:12 PM
11/06/09 08:12 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
I had holley 950 HP alky i think thier now .Finally had it flowed 722 cfm wet benched .Had a 950 aresol billet built By C&S Try 850 to 1050 as most said 850 is bigger . Don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: Thread Ender1]
#516699
11/06/09 09:37 PM
11/06/09 09:37 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Speaking of Holleys size, where does the 830 downleg HP fit?
[Re: HotRodDave]
#516700
11/06/09 09:51 PM
11/06/09 09:51 PM
Posts: 7,506 Az
Crizila
Az
I'm running a 750 annular booster mighty demon on my 408 - 11.2:1, big hydraulic (256 and a little over .600 lift). Runs good, but I'm wondering if a bigger carb would help? Heavy automatic car.
Fastest 300
