Ebay HEI distributors? #516380
11/05/09 12:30 AM
11/05/09 12:30 AM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
Ok, laugh it up now if i made a big mistake for buying one, but i figured i would give one a try, its made by Procomp i'm sure, its for a SB, they have 2 styles, i went with the large cap unit with everything in one for 72.00 bucks, it takes all GM parts, so if something goes bad, i can replace it with GM stuff, it comes with an adj. canister, my question is, is anyone useing one of these, any feedback, i'm hopeing it clears the firewall in the Dart.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Ebay HEI distributors? [Re: joedust451] #516381
11/05/09 01:00 AM
11/05/09 01:00 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Best thing GM did... Had many of them in many different GM cars... Always worked great...
Re: Ebay HEI distributors? [Re: minivan] #516382
11/05/09 02:08 AM
11/05/09 02:08 AM
stratford,ontario,canada
JD340 Offline
JD340  Offline
If it looks anything like this, you should be pretty happy with it. We finally put one in Dad's 69 Dart 318 this summer. Starts better, easy install,stable timing, and 12 volts to coil! When I get a couple bucks together, the Aspen is gonna get one too.
Nothing to see here. Carry on.
Re: Ebay HEI distributors? [Re: JD340] #516383
11/05/09 02:08 AM
11/05/09 02:08 AM
JD340 Offline
JD340  Offline
Inside...
Re: Ebay HEI distributors? [Re: joedust451] #516384
11/05/09 02:12 AM
11/05/09 02:12 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Is the seller in Santa Barbera or Goleta, CA ???
I know a guy that just got some of those in and sells them at Pomona and Long Beach swap meets.
Re: Ebay HEI distributors? [Re: autoxcuda] #516385
11/05/09 09:40 AM
11/05/09 09:40 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
They are in Iowa. Now i feel alittle better about getting one, its not the one in the pics, its another larger style, just like a GM HEI, just has the mopar shaft, i hope it clears the firewall, if not, he said i can return it for the other unit.
That one pictured, does it need an external coil? The one i'm getting has the coil built in.
Re: Ebay HEI distributors? [Re: joedust451] #516386
11/05/09 10:02 AM
11/05/09 10:02 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
External. You can see the coil terminal on the cap in the first pic. OEM GM had the coil in the cap.
Re: Ebay HEI distributors? [Re: joedust451] #516387
11/05/09 12:50 PM
11/05/09 12:50 PM
Az
Crizila Offline
Crizila  Offline
Az
Been running one for about 3 years now ( mine is a D.U.I unit ). Works great. No problems.
Fastest 300
Re: Ebay HEI distributors? [Re: Crizila] #516388
11/05/09 02:43 PM
11/05/09 02:43 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I'm running one problem-free as is my friend who's running one on his 318 dodge pickup.
Re: Ebay HEI distributors? [Re: DaytonaTurbo] #516389
11/05/09 05:11 PM
11/05/09 05:11 PM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
I was about to post a thread asking about these too lol. I didnt know you could get one with a built in coil... would it be good for a mild 340 build?
Re: Ebay HEI distributors? [Re: derekeh] #516390
11/05/09 06:49 PM
11/05/09 06:49 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
I'll be getting it tomorrow, i will post pics, from what i gather, it looks just like a GM HEI, big cap, coil on top, i just hope it clears the firewall.
Re: Ebay HEI distributors? [Re: joedust451] #516391
11/05/09 06:54 PM
11/05/09 06:54 PM
I think the ones with the big caps/coil may create a problem with the firewall but I got the one with the internal electronics for my 64. Runs good but I did notice the rotor points to a different location than stock and I had to move the wires on the cap.
Re: Ebay HEI distributors? [Re: joedust451] #516392
11/05/09 08:17 PM
11/05/09 08:17 PM
Az
Crizila Offline
Crizila  Offline
Az
Pics would be good. I would be interesterd in what coil and module ( I'm sure it will be a 4 pin ) are in it - manufacturer / brand name. Would be very interested in the Primary and secondary ohm readings on the coil. Is it a one wire hook up?
Fastest 300
Re: Ebay HEI distributors? [Re: Crizila] #516393
11/05/09 08:52 PM
11/05/09 08:52 PM
IA
landon1 Offline
landon1  Offline
IA
i've had one in my 440 over a year...2 wires, both to coil...i run a 12 volt accel coil, no ballast
'71 Satellite Sebring 440
Re: Ebay HEI distributors? [Re: Crizila] #516394
11/06/09 01:20 AM
11/06/09 01:20 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
He said one goes to 12v & the other to ground on this unit.
Re: Ebay HEI distributors? [Re: joedust451] #516395
11/06/09 01:36 AM
11/06/09 01:36 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
WOW, those DUI distrabators are pretty spendy.. Seems like I looked at them but was put off by the price.....
Re: Ebay HEI distributors? [Re: minivan] #516396
11/06/09 02:40 AM
11/06/09 02:40 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
DUI= "Driving under the influence", that can get pretty pricey
BTW, whats a "distrabator"
Re: Ebay HEI distributors? [Re: joedust451] #516397
11/06/09 02:41 AM
11/06/09 02:41 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
What we call distributors after a couple of beers.......
Re: Ebay HEI distributors? [Re: minivan] #516398
11/06/09 09:50 AM
11/06/09 09:50 AM
Az
Crizila Offline
Crizila  Offline
Az
Yes, they are pricey. That's why I'm interested in exactly what is in the $72.00 unit he purchased on E-bay. Tip: Make sure the 12vlt wire to the distributor is directly off the alternator charge wire so you get the highest voltage available to the distributor - they like 14 volts. I run mine through a relay and use the ignition run wire from the column ignition switch to fire the relay.
Fastest 300
Re: Ebay HEI distributors? [Re: joedust451] #516399
11/06/09 10:22 AM
11/06/09 10:22 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What is the advantage? I though HEI dists were limited to around 5000 RPMS?
