70 Challenger Brake Question #515834
11/04/09 11:49 AM
11/04/09 11:49 AM
Los Angeles CA
ChrisD Offline OP
ChrisD  Offline OP
Los Angeles CA
I recently restored my 70
challenger with new front brake calipers and rotors. When I first push on the brakes it seems to want to lean right a little , when I continue to press the brake it brakes straight, but the first press seems to lean the car right a little. Does it need another bleed? Proportion valve issue? Any Help ?
Chris
Re: 70 Challenger Brake Question [Re: ChrisD] #515835
11/04/09 12:18 PM
11/04/09 12:18 PM
Tucson AZ
2
2cudabuck Offline
2cudabuck  Offline
Tucson AZ
How are the rear brakes? Any chance a bad wheel cylinder on the opposite corner is causing what appears to be a front end dive?
Buck 67 273 Dart GT 69 RT 440 Charger (SWEET!) 70 318 Cuda 74 Cuda Packin a 426 roller Hemi
Re: 70 Challenger Brake Question [Re: ChrisD] #515836
11/04/09 12:43 PM
11/04/09 12:43 PM
Mopars4Mark Offline
Mopars4Mark  Offline
Did you replace the brake caliper hoses? As they age they'll tend to swell up on the inside causing the fluid the enter the caliper or wheel cylinder at a reduced flow. Giving one caliper more fluid at a faster rate than the other. Just an idea!!!!
Re: 70 Challenger Brake Question [Re: Mopars4Mark] #515837
11/04/09 12:53 PM
11/04/09 12:53 PM
I'd open up the LF & a good visual inspection & see if anything jumps out at you as being not right then I'd jack up the front & spin each wheel (forward) by hand as a helper plays w the pedal & see what you see
Re: 70 Challenger Brake Question [Re: Mopars4Mark] #515838
11/04/09 08:23 PM
11/04/09 08:23 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I would also pull the pads to see if they are wearing similarly L to R
