66 Valiant /6 to 318 #515446
11/03/09 06:25 PM
11/03/09 06:25 PM
Spring Grove, PA, US
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
Hi,
I am in the process of putting a 318 in my 66 valiant that had a 225 w/ automatic. I have some questions for the guys that have done the same thing to a 66 dart,valiant or cuda. What headers have you guys had luck with? dougs, hooker,tti? I want ceramic coated and yes i saw the prices already.ouch..lol. i would like headers with a 3" collector and work with automatic linkage and a 904 trans. also what about the center drop link for the steering.. do i need a lower one?
thanks in advance, Kevin
1996 cummins diesel ext cab, long bed
1966 Valiant 4dr(318- 3.55gears, 13.31@ 102mph),
1974 Duster(360- 13.63@ 99.96 w/3.23 gears),
1933 Dodge DP (201)
Re: 66 Valiant /6 to 318 [Re: Mr.Mopar] #515447
11/03/09 06:37 PM
11/03/09 06:37 PM
California
darkrider2 Offline
darkrider2  Offline
California
I'm looking at doing a similar swap. 3" may be overkill for a stock 318. From what I understand it is a simple swap. I would check the 904 and make sure everything looks good internally for the added power. I'm really interested on your input during and after the swap.
Re: 66 Valiant /6 to 318 [Re: Mr.Mopar] #515448
11/03/09 06:38 PM
11/03/09 06:38 PM
you need the 64-66 A body V8 center link (which is dropped), an oe 64-66 A body V8 CABLE throttle bracket or a common 67 up throttle bracket/cable & redrill a couple of holes in the firewall. As you know 64-66 A body 273 (V8) motor mounts are needed and the insulators are the same between the /6 & V8(64-66 A body) though most of the time when you buy a set of these V8 motor mounts they come with the rubber insulators as they(the insulators) are very common. There was a good thread yesterday about header choices for this, might see if you can find it.
Re: 66 Valiant /6 to 318 [Re: RapidRobert] #515449
11/03/09 06:47 PM
11/03/09 06:47 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
thanks for the centerlink info, any ideas where to get one?? at the moment the throttle pedal is the least of my worries.. i can conjur something up when i get that far.. I have a pair of motor mount brackets on order from schumacher. and for the headers my engine should be putting out from 275-300hp so i would really prefer 3" collectors
1933 Dodge DP (201)
Re: 66 Valiant /6 to 318 [Re: Mr.Mopar] #515450
11/03/09 06:51 PM
11/03/09 06:51 PM
Go thru the A body parts for sale ads and put in a wanted ad there also and search over at www.forabodiesonly.com
Re: 66 Valiant /6 to 318 [Re: Mr.Mopar] #515451
11/03/09 08:29 PM
11/03/09 08:29 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
You already have the dropped V8 link on your '66, '65 was the last for the two separate links.
Re: 66 Valiant /6 to 318 [Re: B5 Bee] #515452
11/03/09 08:36 PM
11/03/09 08:36 PM
Gettysburg Pa
roadrunnerreds Offline
Gettysburg Pa
if you are looking for engine mounts and headers i have the hooker semi fender well 5208 coated headers and oringinal engine mounts. Brad
Re: 66 Valiant /6 to 318 [Re: roadrunnerreds] #515453
11/03/09 08:37 PM
11/03/09 08:37 PM
Gettysburg Pa
Gettysburg Pa
headers they are only 2 1/2 collector. Brad
Re: 66 Valiant /6 to 318 [Re: B5 Bee] #515454
11/03/09 08:44 PM
11/03/09 08:44 PM
If you already have this one you're all set. 20 & 15/16 C to C (the outer holes)
Re: 66 Valiant /6 to 318 [Re: B5 Bee] #515455
11/03/09 08:47 PM
11/03/09 08:47 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
My car was made in 12/65 and the link doesnt have much of a drop in it.. does anyone have the pics of the 2 different ones. or tomorrow i can take a pic of mine and let u double check it, just want to make sure before the motor wont fit!! lol
1933 Dodge DP (201)
Re: 66 Valiant /6 to 318 [Re: roadrunnerreds] #515456
11/03/09 08:53 PM
11/03/09 08:53 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
so are these fenderwell headers? that number is one of the 3 choices i was looking at.. but i want a regular exhaust system. do they fit pretty well?
1933 Dodge DP (201)
Re: 66 Valiant /6 to 318 [Re: Mr.Mopar] #515457
11/03/09 09:03 PM
11/03/09 09:03 PM
Gettysburg Pa
Gettysburg Pa
I never bolted them on i got the tti headers and the starter they tell you to buy DOES NOT WORK.tti are a time consuming job to put on.they are fender well type some tubes wrap around frame and some tubed follow engine. Brad
Re: 66 Valiant /6 to 318 [Re: Mr.Mopar] #515458
11/04/09 01:37 AM
11/04/09 01:37 AM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
I have installed 3 SB's in 65 and 66 (Valiant’s/Dart’s) in the last 2 years.
If you have power steering, I would recommend changing it out before you start. No matter what headers you want to use the PS Unit makes it real tight fit also the "Universal" on the steering rod for the PS unit will get in the way of the header. Dinging up a set of $700.00 headers makes you cringe.
Changing to a Manual Steering will do 2 things for you. 1) you will have more clearance, 2) you will not need to worry on mounting the PS Pump on the engine. 2 Different Style PS Pumps were used. The Original on the 65/66’s were the Federal Pumps, however if your using a water pump newer then a 65/66 you will not be able to mount the pump on the engine. Changing the water pump restricts the flow.
Earlier SB's water pumps outlet is on the driver’s side so finding a Radiator for a 65/66 V8 dart will be hard. The later pumps are on the passenger’s side. 67-68 Barracuda Radiators work well with later Small Blocks water pumps.
I run a 66 Dart with a Mopar 402 Crate, I kept the PS but if I had to do it again it would be out.
I'm using Doug Headers Ceramic coated and they are good quality and fit with minor massaging. Keep in mind the car is close to 45 Years old so thing change a little. Running Dual exhaust will require minor modification to the Trans Cross Member if you want to keep it tucked under. Basic notch cut then weld it back together.
While the I6 Starter will bolt in, you may find it a PITA to change once it is in the car with headers. Change it out for the newer ‘Denso” Starter.
I am running Dual 2 1/4" exhaust with H pipe. The engine pulls hard to 6800 I’m not sure why you would want to go 3".
You will need a V8 904 since the I6 904 has different bell housing. The 904 will hold up to a stout 318/5.2 with a normal rebuild and upto 500 HP if built correctly. If you have "Push Button or Column Shifters" dump them and go to the Floor Shifter. Column shifter linkage will not work, and Push Button Trans for a V8 is a rarity. Trying to get the Throttle Pressure Linkage hooked up correctly is another PITA, I have used LOKAR cables on one, and the other 2 have Manual Valve Bodies in them.
The 7 1/4 will last a few weeks, but start shopping for an A-Body 8 1/4. I'm currently running one with 4.11 sure-grip. It holding fine, but if it goes, I'll go to ford 9". Cheaper and more available then an A-Body 8 3/4, leave them for the restorers. I have one if you know anyone needing one.
Driveshaft length will depend on the Tranny and Rear but you will need a different one. You will not know the required length until you get your combo together.
Front brakes should be upgraded to disks since the drums will be questionable once the car gets rolling. At a minimum you will want to upgrade to a Dual master.
If you’re getting a 5.2 vice a 318 there is a difference in the balancing, so you will need a torque converter for a 5.2 or you can get a FlexPlate to use a neutral converter. 5.9's and 360's have the same requirement.
You will need a 90 Degree Oil Adapter.
Schumacher has the Mounts that you need, you will find that the Rubber Mounts provided are thinner then the /6’s. However you can use either one.
Even with the V8 Center link you may have some interference with the Oil pan. You will find out once it is all put together and you crank the steering lock to lock. A quick hit with a 3lb Ball Peen will correct those issues. Do Not DRIVE it with it hitting, it will only take a few time until you dump you oil in the middle of the street. DAMHIK
Good Luck and Have Fun.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: 66 Valiant /6 to 318 [Re: Noblewk] #515459
11/04/09 06:44 AM
11/04/09 06:44 AM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
wow, lots of info..
i dont have power steering and dont plan on it.
i do have the older water pump on it...
glad to hear dougs headers are nice, there were my first choice, and my car sits up high, not to worried about tucking in the exhaust, i do already have a mini starter.
as for the 3" exhaust.. i went from 2 1/4 to 3 on my duster with a basically stock 360 and it took off 3/10ths at the track... just everything i built i put 3" on.
I was already running an 8 3/4 in it out of a B-body when i pulled everything, so the driveshaft should be the same as long as i use the 904.
I will have to post some pics tonight when i get home from work, thanks guys
1933 Dodge DP (201)
Re: 66 Valiant /6 to 318 [Re: Mr.Mopar] #515460
11/04/09 12:11 PM
11/04/09 12:11 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
In my opinion, 3 inch collector is not really needed at your desired power level. I've got a 65 Barracuda with a 360, auto, bla, bla, bla with a set of "D" Dart headers; I've gone 11.14 so far and I don't think my headers are holding me up. Bigger might be nice, but there are alot more important things to be looking at than collector size.
Good luck,
Jim Burch
Re: 66 Valiant /6 to 318 [Re: RapidRobert] #515461
11/04/09 08:37 PM
11/04/09 08:37 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
I believe i have the wrong centerlink... anybody have the v8 one for sale??
1933 Dodge DP (201)
Re: 66 Valiant /6 to 318 [Re: Mr.Mopar] #515462
11/04/09 08:48 PM
11/04/09 08:48 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
here is a pic of the car
1933 Dodge DP (201)
Re: 66 Valiant /6 to 318 [Re: Mr.Mopar] #515463
11/04/09 09:02 PM
11/04/09 09:02 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
here is the engine, good ole 318
1933 Dodge DP (201)
Re: 66 Valiant /6 to 318 [Re: Mr.Mopar] #515464
11/04/09 09:12 PM
11/04/09 09:12 PM
Yes you will need a V8 dropped centelink like the one in my pic. That beats a cherry picker all to heck That is an excellently detailed eng (sure you dont want to add a 4" crank before you drop it in).
Re: 66 Valiant /6 to 318 [Re: RapidRobert] #515465
11/04/09 09:19 PM
11/04/09 09:19 PM
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
yes, its the only time ive seen a ford pull a mopar. haha. yes, this is the 3rd 318 that i built.. each gets more power, the next one i plan to put a 360 crank in(i somehow aquired a bunch of these) and see what it does
1933 Dodge DP (201)
